Setting the GAZZELL Transmission power to 500 meters using BT832X module
I am using Fansttel BT832X SoC with SDK 14.2 ( Soft Device Version S132 5.0 ). i have configured PA/LNA mode in  BT832X module. If i use only BLE advertisement i can see the  device name upto 200 meters. i wanted to transmit the data using GAZZELL protocol upto 100m range. i am using the same procedure as i used in BLE advertisement. The BT832X module is unable to transmit the data upto 100m range using the GAZZELLE protocol, but i am able to see the advertisement in nrfconnect android mobile app more than that range. i have two questions :
1- Can we increase the GAZZELL transmission range upto 500 meters using Fansttel BT832X SoC.???
     if yes, than please suggest me the alternative way to transmit the data upto 100 meters using GAZZELL protocol with Fansttel BT832X SoC.
2- is the Fansttel BT832X SoC module  having  support to communicate with two same device each of them having BT832X using GAP/GATT???
     Does it have support for GAZZELL also with a range of 500 meters???
