Hii
i want to test Ble mesh Light switch demo using cmake with nRF51 controller.i m facing below error.
Please suggest me ASAP.
Nikunj
Hii
Nikunj
Hello Nikunj,
I note that in your current setting, the "path" in the system environment variable only contains with GNU ARM embedded toolchain, you should not remove all the other setting, and you should also add the path of the Ninja. The "path" in the system environment variable should look similar like this.
same error found
Have you tried to reboot your PC after changing system variable?
yes i have restart my system every time when i change in system environment variable.
