s120 with TWI
I'm trying to use the TWI master example with the S120 soft device. It looks like there is a known problem trying to get the S110 working with the hardware TWI. It seems the TWI doesn't play well with the S120 either. I found this thread to get it working with the S110:
devzone.nordicsemi.com/.../
I tried the fix, but it doesn't seem to work with the S120. The TWI initializes now, but when I try to perform a read, it's causing a hard fault.
Does anyone know how to get the TWI master example working with the S120?
  • Hi Audun, I am using the S110 v7 using twi_sw_master with no problems. I want to change to hw so I am using your library hal_twi as suggested. I have 10k external pullups, but just to make sure I changed also your config to pullup. I am getting an NRF_ERROR_INTERNAL error on hal_twi_init().
    The params are: twi_conf.scl_pin = SCL_PIN; twi_conf.sda_pin = SDA_PIN; twi_conf.frequency = hal_twi_freq_100khz; twi_conf.ppi_chn = 0;
    I would guess that your library worked for you. What do you think could be my problem? Thanks!
1 2
