I use sdk14.2 nrf52832 as the primary, connect two iphone peripherals, iphone is connected to broadcast, when I turn on both peripherals, sometimes everything is normal, sometimes the first time the service is found Just stuck, please help me
But I just used a service. I was scanning. After I matched, I stopped scanning and started to connect. I started to discover the service after I connected. I discovered that the service was completed and then scanned. I don't know if there is any competition.
in fact i find this situation is also happen only one device can be connect , so , my peripheral is iphone, it is After the connection is still broadcast, but I filtered the mac,
Hmm.. can you check out the following two links, if any issues may explain what you experience:
https://devzone.nordicsemi.com/f/nordic-q-a/29796/what-are-sdk-14-x-0-known-issues
hi ,This still did not help , thiis
Sometimes the service is found to be no problem, sometimes the situation shown in the figure above appears
