Adding nRF52 DK to gitHub mesh demo for thingys
Hello everyone,
I`ve 4 thingys and ran the https://github.com/NordicPlayground/Nordic-Thingy52-mesh-demo. That works well.
Now I`m trying to add the nRF52 DK as a Node to the bluetooth mesh network in order for it to receive the periodic messages sent by the sensor nodes.
As a first step, I was trying to program the light_switch_example_server_nrf52832_xxAA_s132_3_1_0 from the nRF5 SDK for Mesh v1.0.1 onto the Chip (using SEGGER Embedded Studio) to see whether it is being provisioned by the bridge. Unfortunately it is not.
My question is: Why doesn`t the nRF5 DK get provisioned by the bridge? And what do I have to change to add it to the mesh and to receive the messages of the thingys?
Michael
  • Hello Michael,
    Would you please check the link again? Since the link should work now Slight smile
    And please let me to add some comments:
    In the "Thingy mesh demo" project, there are ten "simple Thingy client" in the "Thingy bridge"., and each one has been configured to publish the message to the corresponded "simple Thingy server" in those ten Thingy node. Once if one of the Thiny node got the "read sensor back" command, it will send the sensor information to the corresponded "simpleThingy client" in the "Thingy server", and the callback function will send the sensor data to through Nordic UART Service to the mobile device (this is the old design).
    According to the upon information, it would be better to turn your DK as a Thingy bridge Slight smile
    But I would like to suggest you to use our latest Mesh SDK, and check here to create the model for your application.
    Hope the upon information can do help.
  • Hello Rick
    yes, the link works now. But that`s exactly how I initialized the model. Unfortunately it still doesn`t work.
    /* Copyright (c) 2010 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include <stdint.h>
    #include <string.h>
    #include "simple_thingy_server.h"
    #include "ble_uis.h"
    /* HAL */
    #include "nrf.h"
    #include "boards.h"
    #include "nrf_mesh_sdk.h"
    #include "nrf_delay.h"
    #include "simple_hal.h"
    /* Core */
    #include "nrf_mesh.h"
    #include "nrf_mesh_events.h"
    #include "log.h"
    #include "access.h"
    #include "access_config.h"
    #include "device_state_manager.h"
    #include "nrf_mesh_node_config.h"
    #include "simple_on_off_server.h"
    #include "light_switch_example_common.h"
     * Definitions
    #define LED_PIN_NUMBER (BSP_LED_0)
    #define LED_PIN_MASK   (1u << LED_PIN_NUMBER)
     * Static data
    //static simple_on_off_server_t m_server;
    static simple_thingy_server_t m_server;
    /* Forward declaration */
    static bool get_cb(const simple_on_off_server_t * p_server);
    static bool set_cb(const simple_on_off_server_t * p_server, bool value);
    static ble_uis_led_t led_get_cb();
    static ble_uis_led_t led_set_cb(const simple_thingy_server_t * server, ble_uis_led_t led_config);
    static void sensor_set_cb(const simple_thingy_server_t * server, sensor_config_t sensor_cfg);
     * Static utility functions
    static void configuration_setup(void * p_unused)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
    //    m_server.get_cb = get_cb;
    //    m_server.set_cb = set_cb;
        m_server.led_get_cb = led_get_cb;
        m_server.led_set_cb = led_set_cb;
        m_server.sensor_set_cb = sensor_set_cb;
    //    ERROR_CHECK(simple_on_off_server_init(&m_server, 0));
        ERROR_CHECK(simple_thingy_server_init(&m_server,0));
        ERROR_CHECK(access_model_subscription_list_alloc(m_server.model_handle));
       // hal_led_mask_set(LEDS_MASK, true);
    static void provisioning_complete(void * p_unused)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
        hal_led_mask_set(LEDS_MASK, false);
        hal_led_blink_ms(LED_PIN_MASK, 200, 4);
     * Simple OnOff Callbacks/ Simple Thingy Callbacks
    //static bool get_cb(const simple_on_off_server_t * p_server)
    //    return hal_led_pin_get(LED_PIN_NUMBER);
        // Dummy method just to get simple thingy model initialized and nRF5 DK provisioned
        ble_uis_led_t led_cmd;
        led_cmd.mode = BLE_UIS_LED_MODE_CONST;
        led_cmd.data.mode_const.r = 0x0f;
        led_cmd.data.mode_const.g = 0x0f;
        led_cmd.data.mode_const.b = 0x0f;
        return led_cmd;
        return led_config;
       __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- sensor set callback -----\n");
    //static bool set_cb(const simple_on_off_server_t * p_server, bool value)
    //    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Got SET command to %u\n", value);
    //    hal_led_pin_set(LED_PIN_NUMBER, value);
    //    return value;
    void mesh_stack_init(void)    // von Thingy_node kopiert, um gleiches Setup des provisionees zu gewährleisten
        static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
        static nrf_mesh_node_config_params_t config_params;
        config_params.prov_caps.num_elements = ACCESS_ELEMENT_COUNT;
        config_params.prov_caps.algorithms = NRF_MESH_PROV_ALGORITHM_FIPS_P256EC;
        config_params.prov_caps.oob_static_types = NRF_MESH_PROV_OOB_STATIC_TYPE_SUPPORTED;
        config_params.p_static_data = static_auth_data;
        config_params.complete_callback = provisioning_complete;
        config_params.setup_callback = configuration_setup;
        config_params.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST;
        config_params.lf_clk_cfg.source = NRF_CLOCK_LF_SRC_XTAL;
        config_params.lf_clk_cfg.xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM;
        nrf_mesh_node_config(&config_params);
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
        hal_leds_init();
    //   static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
    //    static nrf_mesh_node_config_params_t config_params =
    //        {.prov_caps = NRF_MESH_PROV_OOB_CAPS_DEFAULT(ACCESS_ELEMENT_COUNT)};
    //    config_params.p_static_data = static_auth_data;
    //    config_params.complete_callback = provisioning_complete;
    //    config_params.setup_callback = configuration_setup;
    //    config_params.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST;
    //#if defined(S110)
    //    config_params.lf_clk_cfg = NRF_CLOCK_LFCLKSRC_XTAL_20_PPM;
    //#elif SD_BLE_API_VERSION >= 5
    //    config_params.lf_clk_cfg.source = NRF_CLOCK_LF_SRC_XTAL;
    //    config_params.lf_clk_cfg.accuracy = NRF_CLOCK_LF_ACCURACY_20_PPM;
    //#else
    //    config_params.lf_clk_cfg.xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM;
    //#endif
     //   ERROR_CHECK(nrf_mesh_node_config(&config_params));
        mesh_stack_init();
        while (true)
            (void)sd_app_evt_wait();
    I posted my new code for reference.
    Might there be any problem with the bearer? While checking the code I realized, that there is a difference between the bearer of the light_switch_example and the one of the thingy_mesh_demo.
    Other than that I don`t have an idea whatsoever.
    : Implementing the DK as the bridge makes more sense indeed, but I would like to first solve the provisioning problem before I change the architecture and have to start over again.
    Michael
  • Hello Michael,
    Have you seen any error log from the provisioner or the server node itself?
    Since there's no error log, so I cannot give more help on this.
    And the reason why we should use "bridge" node as a reference is that the bridge contains with "simple_thingy_client", which has the sensor_status_cb() for handling the sensor information Slight smile
  • Hello Rick,
    This is the log I get by debugging the thingy with the bridge software while I have a thingy with node and the development kit with my modified code ( which can be seen in my previous response).
    This is the log I get from the thingy node:
    And this is what the debugging of the dk with the simple_thingy_server results in:
    Both the thingy server and the dk server initialize the simple_thingy_server-model, however, only the one implemented in the thingy is provisioned. Say you were right and the problem would be during the configuration process, shouldn`t then the provisioning process be successful and the following configuration process report an error?
    Since the provisioning process doesn`t even start (at least in the log I cannot see that it starts) I think the problem is already located in the provisioning process.
    I then checked the configuration parameters used to configure the node with nrf_mesh_node_config() and they are similar as well. (Same authentication key and static, same setup_callback() etc.). I finally realized that during the initialization of the provisionee model different bearer types are used. Might that be the reason, why the bridge doesn`t even seem to recognize the dk?
    Regards Michael
  • Hello Michael,
    May I know how you create the project for running "simple Thingy server" on the nRF52-DK? E.g. Are you using the workspace base on the "Thingy node" project in Thingy mesh demo, or are you using the example project in the mesh SDK v1.0.1?
    And would you please explain more about the "different bearer types" mentioned in the previous message? :)
