nRF52 Mesh DFU questions
Hello everybody,
I am trying to exercise the DFU for mesh following the DFU quick start guide (v2.0.1). To put you in context I have four nRF52840 devkits, three of them are running the light_switch example (provisioner, client and server) and if I understand correctly the fourth one will have the DFU example with serial support. My purpose is to be able to update at least the server and client applications using the mesh network. A couple of questions have arise from the guide:
1. In the step three I need to generate the zip file containing the update, Should I generate one for each application (server/client) with different application-id and an application-version greater that 1?, in addition to this I am assuming that I need to generate a device page (step four) for each device modifying the JSON accordingly.
2. What is the correct value for the --sd-req parameter in this last two steps? I am using softdevice s140_v6.0.0 and I found that the value is 0x00A9, Is this correct?
3. On step seven I am flashing the same bootloader on all four devices with path ...\nrf5_SDK_for_Mesh_v2.0.1_src\bin\bootloader\armcc\mesh_bootloader_serial_armcc_nrf52840_xxAA.hex. Is this correct?
4. Should I flash the devices that will not be connected to a serial interface with ...\nrf5_SDK_for_Mesh_v2.0.1_src\bin\bootloader\armcc\mesh_bootloader_armcc_nrf52840_xxAA.hex?
5. On step eight there is an IMPORTANT message, I am not able to find the build/examples/dfu/dfu_no_serial_<target>_<SoftDevice>.hex mentioned there. Also I don't want all my devices to have the DFU example, only the one that will be connected to the computer and will receive the image to propagate, or am I understanding this the wrong way.
6. After I flash all the devices I can provision the client and the server, but the DFU doesn't join the network I only see the UUID that the provisioner receives. After provisioning, with the purpose of testing, I try to execute the command nrfutil --verbose dfu serial -pkg bin\lss-3_2.zip -p com4 -b 115200 -fc --mesh` this is the zip file containing the light switch server update, I receive a couple of errors in the terminal and also errors on the RTT Viewer for the DFU devkit. I am attaching all the logs:
- Provisioner:
<t:         54>, main.c,  550, ----- BLE Mesh Light Switch Provisioner Demo -----
<t:         57>, mesh_softdevice_init.c,  112, Initializing SoftDevice...
<t:          0>, mesh_softdevice_init.c,   77, Enabling BLE...
<t:          2>, mesh_softdevice_init.c,   88, Ram base: 0x200032C8
<t:        628>, main.c,  488, Initializing and adding models
<t:        639>, main.c,  531, Setup defaults: Adding keys, addresses, and bindings
<t:        820>, provisioner_helper.c,  329, netkey_handle: 0
<t:        833>, main.c,  578, <start>
<t:      27308>, main.c,  117, Flash write complete
<t:      27310>, main.c,  565, Starting application ...
<t:      27313>, main.c,  567, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100
<t:      27317>, main.c,  568, Dev key : 89DCF36FB3CF39528D04DF753A9CC4C6
<t:      27319>, main.c,  569, Net key : F4DDEECF26C9582860275E9C1606C1A8
<t:      27322>, main.c,  570, App key : 15E01D1155AAAE1CBF88D79D085C4D68
<t:      27325>, main.c,  571, <t:    2180003>, main.c,  448, Button 1 pressed
<t:    2180005>, main.c,  361, Waiting for Client node to be provisioned ...
<t:    2184752>, provisioner_helper.c,  282, Scanning For Unprovisioned Devices
<t:    6409939>, provisioner_helper.c,  144, UUID seen: 0059ABCDEFABCDEFACCDEFABCDEFABCD
<t:    6409942>, provisioner_helper.c,   95, UUID filter matched
<t:    6410660>, provisioner_helper.c,  259, Provisioning link established
<t:    6423376>, provisioner_helper.c,  254, Static authentication data provided
<t:    6435506>, provisioner_helper.c,  192, Provisioning completed received
<t:    6435509>, provisioner_helper.c,  197, Adding device address, and device keys
<t:    6435514>, provisioner_helper.c,  214, Addr: 0x0100 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
<t:    6438727>, provisioner_helper.c,  155, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:    6438732>, main.c,  282, Provisioning successful
<t:    6438734>, provisioner_helper.c,  181, Provisioning complete. Node addr: 0x0100 elements: 5
<t:    6438738>, node_setup.c,  672, Configuring Node: 0x0100
<t:    6438741>, node_setup.c,  586, Config client setup: devkey_handle:2 addr_handle:0
<t:    6438744>, node_setup.c,  361, Getting composition data
<t:    6438785>, main.c,  117, Flash write complete
<t:    6492270>, main.c,  332, Config client event
<t:    6492273>, node_setup.c,  371, Adding appkey
<t:    6496039>, main.c,  332, Config client event
<t:    6496041>, node_setup.c,  234, Unexpected opcode: exp 0x8003  rx 0x0002
<t:    6497872>, main.c,  332, Config client event
<t:    6497874>, node_setup.c,  272, opcode status field: 0
<t:    6497877>, node_setup.c,  382, App key bind: Health server
<t:    6498766>, main.c,  332, Config client event
<t:    6498769>, node_setup.c,  272, opcode status field: 0
<t:    6498771>, node_setup.c,  450, Setting publication address for the health server to 0x0001
<t:    6501836>, main.c,  332, Config client event
<t:    6501839>, node_setup.c,  272, opcode status field: 0
<t:    6501841>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0101
<t:    6503784>, main.c,  332, Config client event
<t:    6503786>, node_setup.c,  272, opcode status field: 0
<t:    6503789>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0102
<t:    6504504>, main.c,  332, Config client event
<t:    6504507>, node_setup.c,  272, opcode status field: 0
<t:    6504509>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0103
<t:    6505434>, main.c,  332, Config client event
<t:    6505437>, node_setup.c,  272, opcode status field: 0
<t:    6505439>, node_setup.c,  416, App key bind: Simple On/Off client on element 0x0104
<t:    6506112>, main.c,  332, Config client event
<t:    6506115>, node_setup.c,  272, opcode status field: 0
<t:    6506118>, node_setup.c,  301, Set: on/off client: 0x0101  pub addr: 0x0105
<t:    6509698>, main.c,  332, Config client event
<t:    6509701>, node_setup.c,  272, opcode status field: 0
<t:    6509703>, node_setup.c,  301, Set: on/off client: 0x0102  pub addr: 0x0106
<t:    6513756>, main.c,  332, Config client event
<t:    6513758>, node_setup.c,  272, opcode status field: 0
<t:    6513761>, node_setup.c,  301, Set: on/off client: 0x0103  pub addr: 0xC003
<t:    6518222>, main.c,  332, Config client event
<t:    6518224>, node_setup.c,  272, opcode status field: 0
<t:    6518227>, node_setup.c,  301, Set: on/off client: 0x0104  pub addr: 0xC002
<t:    6522657>, main.c,  332, Config client event
<t:    6522659>, node_setup.c,  272, opcode status field: 0
<t:    6522662>, main.c,  248, Configuration of device 0 successful
<t:    6522665>, provisioner_helper.c,  282, Scanning For Unprovisioned Devices
<t:    6522699>, main.c,  117, Flash write complete
<t:    6828343>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    7155986>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    7483557>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:    7811314>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    8139228>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    8466735>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:    8794325>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    9122427>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    9450152>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:    9777808>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -59
<t:    9983367>, provisioner_helper.c,  144, UUID seen: 0059FFFF000000000C63B607528DC9A6
<t:    9983370>, provisioner_helper.c,   95, UUID filter matched
<t:    9984289>, provisioner_helper.c,  259, Provisioning link established
<t:    9997027>, provisioner_helper.c,  254, Static authentication data provided
<t:   10009390>, provisioner_helper.c,  192, Provisioning completed received
<t:   10009393>, provisioner_helper.c,  197, Adding device address, and device keys
<t:   10009398>, provisioner_helper.c,  214, Addr: 0x0105 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
<t:   10012912>, provisioner_helper.c,  155, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:   10012917>, main.c,  282, Provisioning successful
<t:   10012920>, provisioner_helper.c,  181, Provisioning complete. Node addr: 0x0105 elements: 1
<t:   10012923>, node_setup.c,  672, Configuring Node: 0x0105
<t:   10012927>, node_setup.c,  586, Config client setup: devkey_handle:3 addr_handle:1
<t:   10012930>, node_setup.c,  361, Getting composition data
<t:   10013016>, main.c,  117, Flash write complete
<t:   10064540>, main.c,  332, Config client event
<t:   10064542>, node_setup.c,  371, Adding appkey
<t:   10067965>, main.c,  332, Config client event
<t:   10067967>, node_setup.c,  272, opcode status field: 0
<t:   10067970>, node_setup.c,  382, App key bind: Health server
<t:   10068933>, main.c,  332, Config client event
<t:   10068936>, node_setup.c,  272, opcode status field: 0
<t:   10068938>, node_setup.c,  397, App key bind: Simple On/Off server
<t:   10069640>, main.c,  332, Config client event
<t:   10069643>, node_setup.c,  272, opcode status field: 0
<t:   10069645>, node_setup.c,  450, Setting publication address for the health server to 0x0001
<t:   10073271>, main.c,  332, Config client event
<t:   10073273>, node_setup.c,  272, opcode status field: 0
<t:   10073276>, node_setup.c,  476, Set: on/off server pub addr: 0x0101
<t:   10077532>, main.c,  332, Config client event
<t:   10077534>, node_setup.c,  272, opcode status field: 0
<t:   10077537>, node_setup.c,  487, Adding subscription
<t:   10104632>, main.c,  332, Config client event
<t:   10104634>, node_setup.c,  272, opcode status field: 0
<t:   10104637>, main.c,  248, Configuration of device 1 successful
<t:   10104640>, provisioner_helper.c,  282, Scanning For Unprovisioned Devices
<t:   10104674>, main.c,  117, Flash write complete
<t:   10105059>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:   10399429>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -75
<t:   10433359>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:   10617702>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   10683548>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   10726920>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -87
<t:   10749291>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   10760767>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -75
<t:   10815030>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   10880729>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   10946552>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11012374>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11055052>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -80
<t:   11077966>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11088126>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:   11143555>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11209350>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11275186>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11340885>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11382447>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -75
<t:   11406514>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11415767>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:   11472298>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11538002>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11603798>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11669514>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11709795>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -88
<t:   11735225>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11744096>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -59
<t:   11801081>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11866817>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11932558>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   11998232>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12038136>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -78
<t:   12063872>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12071456>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:   12129389>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12195108>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12260721>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12326478>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12365283>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -75
<t:   12392299>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12399476>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:   12457863>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12523490>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12589117>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12654855>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12693021>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -89
<t:   12720530>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12726550>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -59
<t:   12786168>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12852027>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12917789>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   12983346>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13021207>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -79
<t:   13048990>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13054377>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:   13114507>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13180361>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13246025>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13311583>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13348280>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -75
<t:   13377146>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13382259>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:   13442908>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13508555>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13574422>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13640029>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13675883>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -90
<t:   13705585>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13709506>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -59
<t:   13771173>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13836807>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13902628>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   13968439>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14003777>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -79
<t:   14034044>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14037807>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:   14099642>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14165316>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14230909>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14296420>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14331247>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -75
<t:   14362249>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14365308>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:   14428028>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14493755>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14559568>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14625239>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14659118>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -89
<t:   14690867>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14692550>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:   14756688>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14822356>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14887887>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14953686>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   14986844>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -78
<t:   15019384>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15020285>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:   15085025>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15150700>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15216428>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15281992>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15314692>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -75
<t:   15347638>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15348642>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:   15413470>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15479022>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15544720>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15610373>, provisioner_helper.c,  144, UUID seen: 9A5308BE2A18B7372DD296262244F37D
<t:   15642249>, main.c,  311, Node 0x0105 alive with 0 active fault(s), RSSI: -90
<t:   15675974>, main.c,  311, Node 0x0100 alive with 0 active fault(s), RSSI: -59
- Client:
<t:         50>, main.c,  247, ----- BLE Mesh Light Switch Client Demo -----
<t:         53>, mesh_softdevice_init.c,  112, Initializing SoftDevice...
<t:        602>, main.c,  220, Initializing and adding models
<t:       5477>, main.c,  275, Device UUID : 0059ABCDEFABCDEFACCDEFABCDEFABCD
<t:      74374>, main.c,   98, Successfully provisioned
<t:      74376>, main.c,  102, Node Address: 0x0100
- Server:
<t:         49>, main.c,  177, ----- BLE Mesh Light Switch Server Demo -----
<t:         52>, mesh_softdevice_init.c,  112, Initializing SoftDevice...
<t:        627>, main.c,  150, Initializing and adding models
<t:       5513>, main.c,  205, Device UUID : 0059FFFF000000000C63B607528DC9A6
<t:      84000>, main.c,   70, Successfully provisioned
<t:      84002>, main.c,   74, Node Address: 0x0105
- DFU:
<t:         61>, main.c,  204, ----- Bluetooth Mesh DFU Example -----
<t:         64>, mesh_softdevice_init.c,  112, Initializing SoftDevice...
<t:          1>, mesh_softdevice_init.c,   88, Ram base: 0x200032C8
<t:        635>, serial_handler_prov.c,  212, Generating encryption keypair...
<t:       5538>, main.c,  222, Initialization complete!
<t:      10321>, main.c,  240, Enabling serial interface...
<t:      10329>, main.c,  244, DFU example started!
<t:    4770770>, nrf_mesh_dfu.c,  901, ERROR: No CMD handler!
<t:    4787476>, nrf_mesh_dfu.c,  901, ERROR: No CMD handler!
<t:    4804224>, nrf_mesh_dfu.c,  901, ERROR: No CMD handler!
<t:    4820641>, nrf_mesh_dfu.c,  901, ERROR: No CMD handler!
<t:    4837378>, nrf_mesh_dfu.c,  901, ERROR: No CMD handler!
- Terminal:
C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src
λ nrfutil --verbose dfu serial -pkg bin\lss-3_2.zip -p com4 -b 115200 -fc --mesh
Upgrading target on com4 with DFU package C:\Nordic\nrf5_SDK_for_Mesh_v2.0.1_src\bin\lss-3_2.zip. Flow control is enabled.
  [------------------------------------]    0%Flushing com-port...
Opened com-port
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 91180
Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
PC -> target: 0502aabbccdd
target -> PC: 0582aabbccdd
Got echo response
Sending DFU init packet
PC -> target: 1378fdff040f85ba41a359000000030002000000
target -> PC: 0384788e
Failed to upgrade target. Error is: Device returned an unknown status code (142) on a DFU state beacon packet.
Possible causes:
- bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
- baud rate or flow control is not the same as in the target bootloader.
- target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. Closing serial port...
I hope you can help me, thank you for your time.
Carlos
  • Hi Martin,
    In 6) ,what does 'On line 32 change RAM_PH_SIZE to RAM_SIZE' mean? What is RAM_SIZE equal to? When I  do this, and rebuild my project, I meet some error:
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio 3.30/gcc/arm-none-eabi/bin/ld: error: .reserved_ram is too large to fit in RAM memory segment
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio 3.30/gcc/arm-none-eabi/bin/ld: error: .data_run is too large to fit in RAM memory segment
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio 3.30/gcc/arm-none-eabi/bin/ld: error: .bss is too large to fit in RAM memory segment
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio 3.30/gcc/arm-none-eabi/bin/ld: error: .heap is too large to fit in RAM memory segment
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio 3.30/gcc/arm-none-eabi/bin/ld: error: section .heap overlaps absolute placed section .stack
    Build failed
    BR
    Helen
  • Hi Helen,
    The difference between RAM_PH_SIZE and RAM_SIZE is that one is your physical ram, whilst the other is ram allocated for your application.
    It seems like you maybe got these mixed up somewhere, as it looks like you do not have enough RAM.Your flash_placement.xml line 32 should look like this:
     <MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_SIZE)">
    If this does not solve your issue, you should look into how much ram you have currently allocated. In that case, this post should point you in the right direction.
    BR
    Martin
  • dfu_test.ziplight_server_110501.zip
    HI Martin,
    Tnanks! I have add RAM_SIZE in the dfu example in the mesh sdk 2.2.
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x78000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0xf000
    FLASH_START=0x26000
    RAM_START=0x200032c8
    RAM_SIZE=0xbd38
    And modify the RAM_PH_SIZE to RAM_SIZE in flash_placement.xml.
    But when I try to dfu with the light_server_110501.zip(134KB),it always report like this and stop output the log.
    <t:      10298>, main.c,  244, Enabling serial interface...
    <t:      10310>, main.c,  248, DFU example started!
    <t:     215611>, nrf_mesh_dfu.c,  390, New firmware!
    <t:     215614>, nrf_mesh_dfu.c,  528, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
    <t:     215618>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 1).
    <t:     215622>, nrf_mesh_dfu.c,  561, SERIAL TX!
    <t:     281806>, nrf_mesh_dfu.c,  528, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
    <t:     281810>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 0).
    <t:     281814>, nrf_mesh_dfu.c,  561, SERIAL TX!
    <t:     347660>, nrf_mesh_dfu.c,  383, Abort event. Reason: 0xD
    <t:     347664>, nrf_mesh_dfu.c,  528, RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFE
    <t:     347668>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 20).
    <t:     347672>, nrf_mesh_dfu.c,  561, SERIAL TX!
    When I dfu with the dfu_test.zip(4KB), it always succeed. I have no idea about that. Could you give me some advice? Thanks!
    BR
    Helen
    The error you get 0xD is NRF_MESH_DFU_END_ERROR__LAST, which states: /**< The given bank address results in bootloader invalidation. */. This usually suggests your file is to large to fit on the free designated area for DFU. I suggest you look into where the Bootloader, SoftDevice and Mesh puts files in the flash. You can use the nRF Connect Programmer found HERE to help you adjust flash placements.
