After program bootloader software ,application reset
Hi all ,
        I using sdk12.3   experimental_ble_app_buttonless_dfu project to development , below is my bootloader and project  ram setting:
if I don't download the bootloader software, application works ok . But after download the bootloader , in initial the application the software reset on NRF_ERROR_STORAGE_FULL:
ret_code_t pds_init()
ret_code_t ret;
// Check for re-initialization if debugging.
NRF_PM_DEBUG_CHECK(!m_module_initialized);
ret = fds_register(fds_evt_handler);
if (ret != NRF_SUCCESS)
return NRF_ERROR_INTERNAL;
ret = fds_init();
return NRF_ERROR_STORAGE_FULL;
peer_id_init();
peer_ids_load();
m_module_initialized = true;
return NRF_SUCCESS;
Is there any idea why does it reset ? There are 4 service in my software.
  • Sorry for the late reply . Iusing the 51822QFAA chip , the sdk is 12.03 .
    The bootloader setting :0x3AC00  0x5000   /  0x200025E0 0x1A20
    application setting :0x1B000  0x1FC00 / 0x20002138  0xDEC8
    After download the application it works ok . but after download the bootloader it cannot work .(It cannot search by phone).
    Add the Arguments to bootloader software and download by keil , it tell a error messsage:
    Reading flash area to program to guarantee it is erased.
    ERROR: The area to write is not erased.
    Here is my operation step:
    1. Eras the chip by nRFgo studio.
    2. Using the nRFgo studio to download softDevice and application . (It can find by phone)
    3. Using bootloader_secure project to download bootloader.(Tells the error message , if using  nRFgo studio to download it cannot find by phone )
  • I noticed that:
    Usage Memory range nRF51 (S130 v2.0.x) Memory range nRF52 (S132 v3.0.x)
    Bootloader settings 0x0003 FC00 - 0x0004 0000 (1 kB) 0x0007 F000 - 0x0008 0000 (4 kB)
    MBR parameter storage n/a 0x0007 E000 - 0x0007 F000 (4 kB)
    Bootloader 0x0003 AC00 - 0x0003 FC00 (20 kB) 0x0007 8000 - 0x0007 E000 (24 kB)
    Application area (incl. free space) 0x0001 B000 - 0x0003 AC00 (127 kB) 0x0001 F000 - 0x0007 8000 (356 kB)
    SoftDevice 0x0000 1000 - 0x0001 B000 (104 kB) 0x0000 1000 - 0x0001 F000 (120 kB)
    Master Boot Record (MBR) 0x0000 0000 - 0x0000 1000 (4 kB) 0x0000 0000 - 0x0000 1000 (4 kB)
    The chip only has 256K ; so application area is 0x0001 B000 - 0x0003 AC00 (127 kB ), it should begin 0x0001 B000  size is: 0x1FC00 then:
    0x0001 B000 +  0x1FC00 =  0x0003 AC00  .
    but after that it also cannot work , is it the ram I should change ? Any one can give me some tips ?  There are 4 services in my project .
  • Could you debug the bootloader and see if you enter main() of the bootloader?
  • It is the ram setting error . It resolves now . Thanks for your answer.
