pstorage reading other values than writing
Hi!
Maybe I'm doing something wrong (very possible), but for example, when I want to store array of 3 uint8_t values I use:
uint8_t dataToStore[3];
dataToStore[0] = 11;
dataToStore[1] = 22;
dataToStore[2] = 33;
retval = pstorage_store(&block_handle, dataToStore, 3 , 0);
	if (retval == NRF_SUCCESS)
			// Store successfully requested. Wait for operation result.
			// Failed to request store, take corrective action.
and when I want to read it from the memory to variable I use:
   retval = pstorage_block_identifier_get(&persistant_memory_handle, 0, &block_handle);
		uint8_t           dest_data[3];
		 //Request to read 3 bytes from block at an offset of 0 bytes.
		retval = pstorage_load(dest_data, &block_handle, 3, 0);
                         // here dest_data should be: 11, 22, 33 but it gets different values.
				// Failed to load, take corrective action.
Received value is always different than stored. What can be the reason?
  • I think that it's just the description of capability of Persistent Storage Module interface, but for now SDK implementation is not supporting this functionality.
  • Hi!
    After trying to use that same solution which worked before in another project, I discovered a problem with getting NRF_ERROR_INVALID_LENGTH error code as a result of:
    retval = pstorage_update(&block_handle, shutter_state, 4 , 0);
    shutter_state is declared as:
    static uint8_t shutter_state[4] __attribute__((aligned(4)));
    and initialized as:
    		shutter_state[FULL_MOVE_UP_COUNT_EE_POS] 	= s->fullMoveUpCount;
    	shutter_state[FULL_MOVE_DOWN_COUNT_EE_POS] = s->fullMoveDownCount;
    	shutter_state[CURRENT_POSITION_EE_POS] 		= s->currentPosition;
    	shutter_state[DESIRED_POSITION_EE_POS] 		= 0;
    What can cause that error?
    Thanks!:)
  • What if you try to call pstorage_update() at the beginning in the main at initialization? NRF_ERROR_INVALID_LENGTH error can only be returned from sd_flash_write() and I don't know what can be the problem.
  • Hi!
    That's wired, but it works when I use it on before load_stored_data. When I moved it (exactly that same function) to another part of program it stopped working.
    What can cause it?
    Thanks, Patriko
  • Now I recognized that the problem occurs only when the function pstorage_update is called from function declared in another file, so probably there is something wrong with data structure declaration.
    I've all variables associated with pstorage declared in "data_structure.h" included in both files.
    data_strtucture.h contains:
    #include "pstorage.h"
    static pstorage_handle_t persistant_memory_handle;
    static uint32_t retval;
    static pstorage_handle_t block_handle;
    #define FULL_MOVE_UP_COUNT_EE_POS			0
    #define FULL_MOVE_DOWN_COUNT_EE_POS		1
    #define CURRENT_POSITION_EE_POS				2
    #define DESIRED_POSITION_EE_POS				3
    So it should work from both files, shouldn't it?
