Updating Advertising Service Data
Good afternoon,
I'm running advertising with a uint16_t service data associated with a 16-bit service UUID.
I would like to update the service data regularly without the need to update the whole advertising package.
Is there a way to do this similarly to the flags_set() function in the BLE Advertising Module? When I try to accomplish it by recurring to "uint8_t * p_service_data = ble_advdata_parse(p_advertising->adv_data.adv_data.p_data, p_advertising->adv_data.adv_data.len, BLE_GAP_AD_TYPE_SERVICE_DATA)" I can never return the correct offset in the advertising data related to the Service Data field - it always returns 0 offset - and therefore can't access the actual Service Data to update it. Any suggestions to accomplish this?
Thank you,
João
  • Here is the code I used for testing btw:
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_delay.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "ART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    //static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    //    {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
                             (err_code != NRF_ERROR_NOT_FOUND) )
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    static ret_code_t service_data_set(ble_advertising_t * const p_advertising,
    				    uint8_t * service_data)
                                              BLE_GAP_AD_TYPE_SERVICE_DATA);
        if (p_service_data != NULL)
            memcpy(p_service_data, service_data, p_advertising->adv_data.adv_data.len);
        return sd_ble_gap_adv_set_configure(&p_advertising->adv_handle, &p_advertising->adv_data, &p_advertising->adv_params);
    static ble_advertising_init_t 		   m_init_adv_data_and_params;
    static ble_advdata_service_data_t      m_service_data;
    uint16_t 							   m_sdata;
    static ble_uuid_t 					   m_adv_uuids[] = {{0xBEEF, BLE_UUID_TYPE_BLE}};
    static ble_gap_phys_t 				   m_phys;
    void advertising_init(void)
        uint32_t err_code;
        //Build and Set Service Data
        m_service_data.service_uuid       = 0xBAAD;
        m_service_data.data.size          = 2;
    //    m_sdata                           = get_new_advertising_data();
        m_service_data.data.p_data        = "Mart";//(uint8_t*)&m_sdata;
        memset(&m_init_adv_data_and_params, 0, sizeof(m_init_adv_data_and_params));
        //Build and Set Advertising Data.
        m_init_adv_data_and_params.advdata.flags                        = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        m_init_adv_data_and_params.advdata.name_type                    = BLE_ADVDATA_FULL_NAME;
        m_init_adv_data_and_params.advdata.include_appearance           = false;
        m_init_adv_data_and_params.advdata.uuids_complete.uuid_cnt       = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        m_init_adv_data_and_params.advdata.uuids_complete.p_uuids        = m_adv_uuids;
        m_init_adv_data_and_params.advdata.p_service_data_array          = &m_service_data;
        m_init_adv_data_and_params.advdata.service_data_count            = 1;
        //Build and Set Advertising Params.
        m_init_adv_data_and_params.config.ble_adv_whitelist_enabled      = true;
        m_init_adv_data_and_params.config.ble_adv_fast_enabled           = true;
        m_init_adv_data_and_params.config.ble_adv_fast_interval          = APP_ADV_INTERVAL;
        m_init_adv_data_and_params.config.ble_adv_fast_timeout           = APP_ADV_DURATION;
        m_init_adv_data_and_params.config.ble_adv_slow_enabled           = true;
        m_init_adv_data_and_params.config.ble_adv_slow_interval          = APP_ADV_INTERVAL;
        m_init_adv_data_and_params.config.ble_adv_slow_timeout           = APP_ADV_DURATION;
        m_init_adv_data_and_params.config.ble_adv_primary_phy            = BLE_GAP_PHY_1MBPS;
        m_init_adv_data_and_params.config.ble_adv_secondary_phy          = BLE_GAP_PHY_1MBPS;
        err_code = ble_advertising_init(&m_advertising, &m_init_adv_data_and_params);
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    ret_code_t sdata_set(ble_advertising_t * const p_advertising, uint16_t sdata)
        uint8_t * p_sdata = ble_advdata_parse(p_advertising->adv_data.adv_data.p_data,
        if (p_sdata != NULL)
    	*p_sdata = sdata;
    	NRF_LOG_ERROR("SData at address 0x%X", p_sdata);
    	uint16_t offset = 0;
    	ble_advdata_search(p_advertising->adv_data.adv_data.p_data, BLE_GAP_ADV_SET_DATA_SIZE_MAX, &offset, BLE_GAP_AD_TYPE_SERVICE_DATA);
    	NRF_LOG_INFO("OFFSET: %d", offset);
        else //Debug
    	NRF_LOG_ERROR("No SData!");
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
    //        idle_state_handle();
    	nrf_delay_ms(1000);
    	sdata_set(&m_advertising, 0xC0FE);
    	NRF_LOG_FLUSH();
  • Hi Martin,
    I tried to import your sdata_set function and it results the same => offset is always zero and thus p_sdata is never different than NULL.
    I checked p_advertising->adv_data.adv_data.len and it is always 31.
    Do you have any idea what might be the problem?
    João
  • That is strange.
    1. What SDK version are you using?
    2. Can you share your entire project? We can make the case private if you prefer confidentiality.
  • Hi Martin,
    It seems that I had an issue with p_advertising->adv_data.adv_data.len indeed, which was getting unintentionally altered and reading the ServiceData "out of range".
    It is now working but I'm struggling with the NRF_ERROR_INVALID_STATE with sd_ble_gap_adv_set_configure. According to the documentation, "It is invalid to provide the same data buffers while advertising. To update advertising data, provide new advertising buffers."
    I try to contour the issue with the code in attachment but still retrieve the same error. Any ideas to solve it?
    I'm using SDK15 and Softdevice6.0.0
    Thank you,
    João
        uint32_t ret;
    			*p_sdata = sdata;
            	offset+=2; //To get the data itself
    			p_advertising->adv_data.adv_data.p_data[offset++] = MSB_16(sdata);
            	p_advertising->adv_data.adv_data.p_data[offset++] = LSB_16(sdata);
        else //Debug
        if(m_advdata_idx % 2 == 0)
                memcpy(m_new_enc_advdata1, p_advertising->adv_data.adv_data.p_data, p_advertising->adv_data.adv_data.len);
                m_new_adv_data.adv_data.p_data      = m_new_enc_advdata1;
                m_new_adv_data.adv_data.len         = p_advertising->adv_data.adv_data.len;
                m_new_adv_data.scan_rsp_data.p_data = p_advertising->enc_scan_rsp_data;
                m_new_adv_data.scan_rsp_data.len    = p_advertising->adv_data.scan_rsp_data.len;
                memcpy(m_new_enc_advdata2, p_advertising->adv_data.adv_data.p_data, p_advertising->adv_data.adv_data.len);
                m_new_adv_data.adv_data.p_data      = m_new_enc_advdata2;
        m_advdata_idx++;
        memcpy(&p_advertising->adv_data, &m_new_adv_data, sizeof(p_advertising->adv_data));
        p_advertising->p_adv_data = &p_advertising->adv_data;
        ret = sd_ble_gap_adv_set_configure(&p_advertising->adv_handle, &p_advertising->adv_data, &p_advertising->adv_params);
        return ret;
    Unfortunately there is no elegant way of updating the data in the advertising packet while advertising. You need to stop advertising, reconfigure the packet, and restart advertising again.
