pstorage: stuck in erase operation
This is my code snippet
	uint32_t err_code;
	// Scheduler
	scheduler_init();
	// Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, true); // Use scheduler
    ..... register system event dispatch here .......
	// Initialize persistent storage module.
	err_code = pstorage_init();
	storage_param.block_size = DATA_BLOCK_SIZE;
	storage_param.block_count = DATA_BLOCK_COUNT;
	storage_param.cb = pstorage_callback;
	err_code = pstorage_register(&storage_param, &storage_handle);
	err_code = pstorage_block_identifier_get(&m_base_handle, 0, &storage_handle);
	err_code = pstorage_clear(&m_base_handle, DATA_BLOCK_COUNT * DATA_BLOCK_SIZE);
	// Wait until FLASH all cleared
	uint32_t count;
	do {
		err_code = pstorage_access_status_get(&count);
	} while(count); /* Stuck here??? */
The program stuck in the while segment, and count is always 0x1. Why?
  • No, you must use softdevice_sys_evt_handler_set(), because it's where softdevice will handle end of flash operations ans start new operations:
    Registering for system events and passing them on to pstorage module using the pstorage_sys_event_handler is mandatory for the module to function as expected. Code snippet below demonstrates what application needs to do for this.
    /**@brief Function for dispatching a system event to interested modules.
       @details This function is called from the System event interrupt handler after a system
                event has been received.
       @param[in]   sys_evt   System stack event.
    static void sys_evt_dispatch(uint32_t sys_evt)
        pstorage_sys_event_handler(sys_evt);
    /**@brief BLE stack initialization.
       @details Initializes the SoftDevice and the stack event interrupt.
    static void ble_ant_stack_init(void)
        // Initialize SoftDevice
        SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, false);
        // Subscribe for BLE events.
        uint32_t err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
        // Register with the SoftDevice handler module for System events.
        err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    You will block CPU until Flash erase is done with your code:
    uint32_t count;
    do {
  • Ok, the problem was that when you use scheduler all pstorage execution will be transfered from interrupts to the main context so you need to call scheduler events execution:
    uint32_t count;
    do {
        app_sched_execute();
    } while(count);
    UPD:
    I messed up and forgot to add app_sched_execute();
  • Hi all,
    I repost my question here. I found the problem chain is
    1. pstorage_init() called sd_flash_page_erase(), and set m_cmd_queue.flash_access = true;
    2. sd_flash_page_erase() will not trigger system event handler which calls pstorage_sys_event_handler, and thus m_cmd_queue.flash_access kept true;
    3. because m_cmd_queue.flash_access is true, then later the pstorage_clear() is not executed immediately but enqueued.
    4. Enqueued command will not be executed, and thus m_cmd_queue.count is always 1.
  • Thank for for answering your own question, and separating the questions.
