A simple message from server to client in mesh 2.0.1.
I am trying to send a simple message from server to client in mesh 2.0.1. I am following this post for the same. I successfully sent a message from client to server and received it in the server side. Now I want to send a message from server to client. I have added all codes provided in the above post and made the specified changes for the server too. But message is not getting sent.
void address_set(uint16_t addr)                 //function for setting address
  uint32_t err_code;
  err_code = dsm_address_publish_add(addr, &m_central_handle); //NRF_ERROR_NO_MEM
  ERROR_CHECK(err_code);
  ERROR_CHECK(access_model_publish_address_set(m_clients[0].model_handle, m_central_handle));
I am getting error:   <t:     663640>, app_error_weak.c,  105, Mesh error 4 at 0x000267E9 at examples\simple_message\server\src\main.c:269 ie. at
The error code is NRF_ERROR_NO_MEM . Can you help me to resolve this? I want to sent a unicast message to the client from server.
  • Hi Edvin,
    1. I changed the group address to 0xC002 in example_network_config.h, in order to send message to all servers instead of group cast.
    #define GROUP_ADDRESS_EVEN (0xC002)
    #define GROUP_ADDRESS_ODD  (0xC002)
    2. I can send message from client to server and LED changes its state in response. I am sending a string from client to server, which is also received there in server.
    3. After changing this parameter ,I can send a message(string) from server to client.
    #define DSM_NONVIRTUAL_ADDR_MAX                         (4)
    4. I am not changing codes in node_setup.c. I am changing in main.c according to this post
    void address_set(uint16_t addr)                   //setting address for sending message
      ERROR_CHECK(dsm_address_publish_add(addr, &m_central_handle));
      ERROR_CHECK(access_model_publish_address_set(m_server.model_handle, m_central_handle));
    void send_message(void)                         //function for sending a simple message
        uint32_t status=0;
        uint8_t buffer[5] = "hello";
        uint8_t length;
        uint16_t address;
        access_message_tx_t msg;
        length = sizeof(buffer); //SEGGER_RTT_Read(0, buffer, sizeof(buffer));
        if(length)
          //no-need:SEGGER_RTT_WriteString(0, "entering message field\n");
          msg.opcode.opcode = simple_message_OPCODE_SEND;
          msg.opcode.company_id = 0x0059; // Nordic's company ID
          msg.p_buffer = (const uint8_t *) &buffer[0];
          msg.length = length;
          address = 0xCAFE;
          address_set(address);
          SEGGER_RTT_printf(0,"Sending to group address 0x%04x\n", address);
          status= access_model_publish(m_clients[3].model_handle, &msg);
          if(status == NRF_ERROR_INVALID_STATE ||
          status == NRF_ERROR_BUSY||
          status == NRF_ERROR_NO_MEM)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot send. Device is busy.\n");
            hal_led_blink_ms(LEDS_MASK, 50, 4);
             ERROR_CHECK(status);
    These two functions and some necessary changes have been made in main.c
    5. I want to send the same above message from a server to another server as a broadcast. Should I begin a new case for that?
    Thank you.
  • Ok. I see.
    You should take a look in node_setup.c as well.
    The fist two servers are set up with individual unix addresses. You must do this for the third server as well.
    On line 123 you'll see:
    static const config_steps_t client_config_steps[] = ...
    which is the provisioning steps that the client will go through.
    line 141 describes the steps that the first two servers will go through:
    static const config_steps_t server1_server2_config_steps[] = ...
    line 154 describes a step that all of the servers will go through:
    static const config_steps_t server_config_steps[] = ...
    Line 321 decides what steps the node that is being provisioned will go through.
    You must alter these lists to set up a unix address to all devices. This decides what addresses the different devices are publishing on, and what addresses the different devices are listening on.
    BR,
    Edvin
