nrf_twi_mngr handling of transfers larger than 255 Bytes
I am trying to send more than 255 Bytes of data over I2C so I break it up into 255 byte transfers within a transaction.
I notice a stop/start condition is sent between I2C transfers even if I use the NRF_TWI_MNGR_NO_STOP flag for each transfer.
This seems to contrary to the comment at line 74 in nrf_twi_mngr.c:
/* If it is possible try to bind two transfers together. They can be combined if:
     * - there is no stop condition after current transfer.
     * - current transfer is TX.
     * - there is at least one more transfer in the transaction.
     * - address of next transfer is the same as current transfer.
Is there a way to accomplish this?
  • It looks like the NRF_TWI_MNGR_NO_STOP flag just enables a repeated start instead of a stop followed by a start. From nrf_twi_mngr.h:
     * Use this flag when a stop condition is undesirable between two transfers,
     * for example, when the first transfer is a write that sets an address in the slave
     * device and the second one is a read that fetches certain data using this
     * address. In this case, the second transfer should follow directly after the
     * first transfer, with a repeated start condition instead of a stop and then
     * a new start condition.
    However, I spent a few minutes looking at nrfx_twi.c and it looks like twi_send_byte executes the NRF_TWI_TASK_SUSPEND task when it gets to the end of the first data buffer and NRF_TWI_MNGR_NO_STOP is set (instead of executing NRF_TWI_TASK_STOP). Then twi_tx_start_transfer is called to send the second buffer and it's in here that the NRF_TWI_TASK_RESUME and NRF_TWI_TASK_STARTTX tasks are executed. I think the NRF_TWI_TASK_STARTTX is the task that actually puts the repeated start condition and address on the bus again. To test this I used a static variable to remember if the TWI bus was previously suspended instead of stopped -- if so I allow twi_tx_start_transfer to execute the NRF_TWI_TASK_RESUME task but skip NRF_TWI_TASK_STARTTX . The result on my logic analyzer is start, address with write bit, 255 bytes, 255 more bytes, and then stop.
    I didn't have time to test if this breaks something else in the driver but if I understand your question correctly this should at least prove that it's possible to do what you're looking for.
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <nrfx.h>
    #if NRFX_CHECK(NRFX_TWI_ENABLED)
    #if !(NRFX_CHECK(NRFX_TWI0_ENABLED) || NRFX_CHECK(NRFX_TWI1_ENABLED))
    #error "No enabled TWI instances. Check <nrfx_config.h>."
    #include <nrfx_twi.h>
    #include <hal/nrf_gpio.h>
    #include "prs/nrfx_prs.h"
    #define NRFX_LOG_MODULE TWI
    #include <nrfx_log.h>
    #define EVT_TO_STR(event)                                      \
        (event == NRFX_TWI_EVT_DONE         ? "EVT_DONE"         : \
        (event == NRFX_TWI_EVT_ADDRESS_NACK ? "EVT_ADDRESS_NACK" : \
        (event == NRFX_TWI_EVT_DATA_NACK    ? "EVT_DATA_NACK"    : \
                                              "UNKNOWN ERROR")))
    #define EVT_TO_STR_TWI(event)                                       \
        (event == NRF_TWI_EVENT_STOPPED   ? "NRF_TWI_EVENT_STOPPED"   : \
        (event == NRF_TWI_EVENT_RXDREADY  ? "NRF_TWI_EVENT_RXDREADY"  : \
        (event == NRF_TWI_EVENT_TXDSENT   ? "NRF_TWI_EVENT_TXDSENT"   : \
        (event == NRF_TWI_EVENT_ERROR     ? "NRF_TWI_EVENT_ERROR"     : \
        (event == NRF_TWI_EVENT_BB        ? "NRF_TWI_EVENT_BB"        : \
        (event == NRF_TWI_EVENT_SUSPENDED ? "NRF_TWI_EVENT_SUSPENDED" : \
                                            "UNKNOWN ERROR"))))))
    #define TRANSFER_TO_STR(type)                   \
        (type == NRFX_TWI_XFER_TX   ? "XFER_TX"   : \
        (type == NRFX_TWI_XFER_RX   ? "XFER_RX"   : \
        (type == NRFX_TWI_XFER_TXRX ? "XFER_TXRX" : \
        (type == NRFX_TWI_XFER_TXTX ? "XFER_TXTX" : \
                                      "UNKNOWN TRANSFER TYPE"))))
    #define TWI_PIN_INIT(_pin) nrf_gpio_cfg((_pin),                     \
                                            NRF_GPIO_PIN_DIR_INPUT,     \
                                            NRF_GPIO_PIN_INPUT_CONNECT, \
                                            NRF_GPIO_PIN_PULLUP,        \
                                            NRF_GPIO_PIN_S0D1,          \
                                            NRF_GPIO_PIN_NOSENSE)
    #define HW_TIMEOUT      10000
    static bool m_suspended = false;
    // Control block - driver instance local data.
    typedef struct
        nrfx_twi_evt_handler_t  handler;
        void *                  p_context;
        volatile uint32_t       int_mask;
        nrfx_twi_xfer_desc_t    xfer_desc;
        uint32_t                flags;
        uint8_t *               p_curr_buf;
        uint8_t                 curr_length;
        bool                    curr_no_stop;
        nrfx_drv_state_t        state;
        bool                    error;
        volatile bool           busy;
        bool                    repeated;
        uint8_t                 bytes_transferred;
        bool                    hold_bus_uninit;
    } twi_control_block_t;
    static twi_control_block_t m_cb[NRFX_TWI_ENABLED_COUNT];
    static nrfx_err_t twi_process_error(uint32_t errorsrc)
        nrfx_err_t ret = NRFX_ERROR_INTERNAL;
        if (errorsrc & NRF_TWI_ERROR_OVERRUN)
            ret = NRFX_ERROR_DRV_TWI_ERR_OVERRUN;
        if (errorsrc & NRF_TWI_ERROR_ADDRESS_NACK)
            ret = NRFX_ERROR_DRV_TWI_ERR_ANACK;
        if (errorsrc & NRF_TWI_ERROR_DATA_NACK)
            ret = NRFX_ERROR_DRV_TWI_ERR_DNACK;
        return ret;
    nrfx_err_t nrfx_twi_init(nrfx_twi_t const *        p_instance,
                             nrfx_twi_config_t const * p_config,
                             nrfx_twi_evt_handler_t    event_handler,
                             void *                    p_context)
        NRFX_ASSERT(p_config);
        NRFX_ASSERT(p_config->scl != p_config->sda);
        twi_control_block_t * p_cb  = &m_cb[p_instance->drv_inst_idx];
        nrfx_err_t err_code;
        if (p_cb->state != NRFX_DRV_STATE_UNINITIALIZED)
            err_code = NRFX_ERROR_INVALID_STATE;
            NRFX_LOG_WARNING("Function: %s, error code: %s.",
                             __func__,
                             NRFX_LOG_ERROR_STRING_GET(err_code));
            return err_code;
    #if NRFX_CHECK(NRFX_PRS_ENABLED)
        static nrfx_irq_handler_t const irq_handlers[NRFX_TWI_ENABLED_COUNT] = {
            #if NRFX_CHECK(NRFX_TWI0_ENABLED)
            nrfx_twi_0_irq_handler,
            #if NRFX_CHECK(NRFX_TWI1_ENABLED)
            nrfx_twi_1_irq_handler,
        if (nrfx_prs_acquire(p_instance->p_twi,
                irq_handlers[p_instance->drv_inst_idx]) != NRFX_SUCCESS)
            err_code = NRFX_ERROR_BUSY;
                             __func__,
            return err_code;
    #endif // NRFX_CHECK(NRFX_PRS_ENABLED)
        p_cb->handler         = event_handler;
        p_cb->p_context       = p_context;
        p_cb->int_mask        = 0;
        p_cb->repeated        = false;
        p_cb->busy            = false;
        p_cb->hold_bus_uninit = p_config->hold_bus_uninit;
        /* To secure correct signal levels on the pins used by the TWI
           master when the system is in OFF mode, and when the TWI master is
           disabled, these pins must be configured in the GPIO peripheral.
        TWI_PIN_INIT(p_config->scl);
        TWI_PIN_INIT(p_config->sda);
        NRF_TWI_Type * p_twi = p_instance->p_twi;
        nrf_twi_pins_set(p_twi, p_config->scl, p_config->sda);
        nrf_twi_frequency_set(p_twi,
            (nrf_twi_frequency_t)p_config->frequency);
        if (p_cb->handler)
            NRFX_IRQ_PRIORITY_SET(nrfx_get_irq_number(p_instance->p_twi),
                p_config->interrupt_priority);
            NRFX_IRQ_ENABLE(nrfx_get_irq_number(p_instance->p_twi));
        p_cb->state = NRFX_DRV_STATE_INITIALIZED;
        err_code = NRFX_SUCCESS;
        NRFX_LOG_INFO("Function: %s, error code: %s.", __func__, NRFX_LOG_ERROR_STRING_GET(err_code));
        return err_code;
    void nrfx_twi_uninit(nrfx_twi_t const * p_instance)
        NRFX_ASSERT(p_cb->state != NRFX_DRV_STATE_UNINITIALIZED);
        if (p_cb->handler)
            NRFX_IRQ_DISABLE(nrfx_get_irq_number(p_instance->p_twi));
        nrfx_twi_disable(p_instance);
        nrfx_prs_release(p_instance->p_twi);
        if (!p_cb->hold_bus_uninit)
            nrf_gpio_cfg_default(p_instance->p_twi->PSELSCL);
            nrf_gpio_cfg_default(p_instance->p_twi->PSELSDA);
        p_cb->state = NRFX_DRV_STATE_UNINITIALIZED;
        NRFX_LOG_INFO("Instance uninitialized: %d.", p_instance->drv_inst_idx);
    void nrfx_twi_enable(nrfx_twi_t const * p_instance)
        NRFX_ASSERT(p_cb->state == NRFX_DRV_STATE_INITIALIZED);
        nrf_twi_enable(p_twi);
        p_cb->state = NRFX_DRV_STATE_POWERED_ON;
        NRFX_LOG_INFO("Instance enabled: %d.", p_instance->drv_inst_idx);
    void nrfx_twi_disable(nrfx_twi_t const * p_instance)
        nrf_twi_int_disable(p_twi, NRF_TWI_ALL_INTS_MASK);
        nrf_twi_shorts_disable(p_twi, NRF_TWI_ALL_SHORTS_MASK);
        nrf_twi_disable(p_twi);
        NRFX_LOG_INFO("Instance disabled: %d.", p_instance->drv_inst_idx);
    static bool twi_send_byte(NRF_TWI_Type  * p_twi,
                              uint8_t const * p_data,
                              uint8_t         length,
                              uint8_t       * p_bytes_transferred,
                              bool            no_stop)
        if (*p_bytes_transferred < length)
            nrf_twi_txd_set(p_twi, p_data[*p_bytes_transferred]);
            ++(*p_bytes_transferred);
            if (no_stop)
                m_suspended = true;
                nrf_twi_task_trigger(p_twi, NRF_TWI_TASK_SUSPEND);
                return false;
                nrf_twi_task_trigger(p_twi, NRF_TWI_TASK_STOP);
        return true;
    static void twi_receive_byte(NRF_TWI_Type * p_twi,
                                 uint8_t      * p_data,
                                 uint8_t        length,
                                 uint8_t      * p_bytes_transferred)
            p_data[*p_bytes_transferred] = nrf_twi_rxd_get(p_twi);
            if (*p_bytes_transferred == length - 1)
                nrf_twi_shorts_set(p_twi, NRF_TWI_SHORT_BB_STOP_MASK);
            else if (*p_bytes_transferred == length)
                return;
            nrf_twi_task_trigger(p_twi, NRF_TWI_TASK_RESUME);
    static bool twi_transfer(NRF_TWI_Type  * p_twi,
                             bool          * p_error,
                             uint8_t       * p_data,
                             uint8_t         length,
                             bool            no_stop)
        bool do_stop_check = ((*p_error) || ((*p_bytes_transferred) == length));
        if (*p_error)
            nrf_twi_event_clear(p_twi, NRF_TWI_EVENT_ERROR);
            nrf_twi_event_clear(p_twi, NRF_TWI_EVENT_TXDSENT);
            nrf_twi_event_clear(p_twi, NRF_TWI_EVENT_RXDREADY);
        else if (nrf_twi_event_check(p_twi, NRF_TWI_EVENT_ERROR))
            NRFX_LOG_DEBUG("TWI: Event: %s.", EVT_TO_STR_TWI(NRF_TWI_EVENT_ERROR));
            *p_error = true;
            if (nrf_twi_event_check(p_twi, NRF_TWI_EVENT_TXDSENT))
                NRFX_LOG_DEBUG("TWI: Event: %s.", EVT_TO_STR_TWI(NRF_TWI_EVENT_TXDSENT));
                    *p_error = true;
                    if (!twi_send_byte(p_twi, p_data, length, p_bytes_transferred, no_stop))
                        return false;
            else if (nrf_twi_event_check(p_twi, NRF_TWI_EVENT_RXDREADY))
                NRFX_LOG_DEBUG("TWI: Event: %s.", EVT_TO_STR_TWI(NRF_TWI_EVENT_RXDREADY));
                    *p_error = true;
                    twi_receive_byte(p_twi, p_data, length, p_bytes_transferred);
        if (do_stop_check && nrf_twi_event_check(p_twi, NRF_TWI_EVENT_STOPPED))
            nrf_twi_event_clear(p_twi, NRF_TWI_EVENT_STOPPED);
            NRFX_LOG_DEBUG("TWI: Event: %s.", EVT_TO_STR_TWI(NRF_TWI_EVENT_STOPPED));
            return false;
        return true;
    static nrfx_err_t twi_tx_start_transfer(twi_control_block_t * p_cb,
                                            uint8_t               length,
                                            bool                  no_stop)
        nrfx_err_t ret_code = NRFX_SUCCESS;
        volatile int32_t hw_timeout;
        hw_timeout = HW_TIMEOUT;
        nrf_twi_shorts_set(p_twi, 0);
        p_cb->bytes_transferred = 0;
        p_cb->error             = false;
        // In case TWI is suspended resume its operation.
        if (!m_suspended)
            nrf_twi_task_trigger(p_twi, NRF_TWI_TASK_STARTTX);
        (void)twi_send_byte(p_twi, p_data, length, &p_cb->bytes_transferred, no_stop);
        if (p_cb->handler)
            p_cb->int_mask = NRF_TWI_INT_STOPPED_MASK   |
                             NRF_TWI_INT_ERROR_MASK     |
                             NRF_TWI_INT_TXDSENT_MASK   |
                             NRF_TWI_INT_RXDREADY_MASK;
            nrf_twi_int_enable(p_twi, p_cb->int_mask);
            while ((hw_timeout > 0) &&
                   twi_transfer(p_twi,
                                &p_cb->error,
                                (uint8_t *)p_data,
                                length,
                                no_stop))
                hw_timeout--;
            if (p_cb->error)
                uint32_t errorsrc =  nrf_twi_errorsrc_get_and_clear(p_twi);
                if (errorsrc)
                    ret_code = twi_process_error(errorsrc);
            if (hw_timeout <= 0)
                ret_code = NRFX_ERROR_INTERNAL;
        return ret_code;
    static nrfx_err_t twi_rx_start_transfer(twi_control_block_t * p_cb,
                                            uint8_t               length)
        if (length == 1)
            nrf_twi_shorts_set(p_twi, NRF_TWI_SHORT_BB_SUSPEND_MASK);
        nrf_twi_task_trigger(p_twi, NRF_TWI_TASK_STARTRX);
        if (p_cb->handler)
                   twi_transfer(p_twi,
                                &p_cb->error,
                                (uint8_t*)p_data,
                                length,
                                false))
                   hw_timeout--;
            if (p_cb->error)
                if (errorsrc)
        return ret_code;
    __STATIC_INLINE nrfx_err_t twi_xfer(twi_control_block_t        * p_cb,
                                        nrfx_twi_xfer_desc_t const * p_xfer_desc,
                                        uint32_t                     flags)
        nrfx_err_t err_code = NRFX_SUCCESS;
        /* Block TWI interrupts to ensure that function is not interrupted by TWI interrupt. */
        if (p_cb->busy)
                             __func__,
            return err_code;
            p_cb->busy = (NRFX_TWI_FLAG_NO_XFER_EVT_HANDLER & flags) ? false : true;
        p_cb->flags       = flags;
        p_cb->xfer_desc   = *p_xfer_desc;
        p_cb->curr_length = p_xfer_desc->primary_length;
        p_cb->p_curr_buf  = p_xfer_desc->p_primary_buf;
        nrf_twi_address_set(p_twi, p_xfer_desc->address);
        if (p_xfer_desc->type != NRFX_TWI_XFER_RX)
            p_cb->curr_no_stop = ((p_xfer_desc->type == NRFX_TWI_XFER_TX) &&
                                 !(flags & NRFX_TWI_FLAG_TX_NO_STOP)) ? false : true;
            err_code = twi_tx_start_transfer(p_cb,
                                             p_twi,
                                             p_xfer_desc->p_primary_buf,
                                             p_xfer_desc->primary_length,
                                             p_cb->curr_no_stop);
            p_cb->curr_no_stop = false;
            err_code = twi_rx_start_transfer(p_cb,
                                             p_twi,
                                             p_xfer_desc->primary_length);
        if (p_cb->handler == NULL)
            p_cb->busy = false;
        return err_code;
    bool nrfx_twi_is_busy(nrfx_twi_t const * p_instance)
        return p_cb->busy;
    nrfx_err_t nrfx_twi_xfer(nrfx_twi_t           const * p_instance,
                             uint32_t                     flags)
        // TXRX and TXTX transfers are supported only in non-blocking mode.
        NRFX_ASSERT( !((p_cb->handler == NULL) && (p_xfer_desc->type == NRFX_TWI_XFER_TXRX)));
        NRFX_ASSERT( !((p_cb->handler == NULL) && (p_xfer_desc->type == NRFX_TWI_XFER_TXTX)));
        NRFX_LOG_INFO("Transfer type: %s.", TRANSFER_TO_STR(p_xfer_desc->type));
        NRFX_LOG_INFO("Transfer buffers length: primary: %d, secondary: %d.",
                      p_xfer_desc->secondary_length);
        NRFX_LOG_DEBUG("Primary buffer data:");
        NRFX_LOG_HEXDUMP_DEBUG(p_xfer_desc->p_primary_buf,
                               p_xfer_desc->primary_length * sizeof(p_xfer_desc->p_primary_buf[0]));
        NRFX_LOG_DEBUG("Secondary buffer data:");
        NRFX_LOG_HEXDUMP_DEBUG(p_xfer_desc->p_secondary_buf,
                               p_xfer_desc->secondary_length * sizeof(p_xfer_desc->p_secondary_buf[0]));
        err_code = twi_xfer(p_cb, (NRF_TWI_Type  *)p_instance->p_twi, p_xfer_desc, flags);
                         __func__,
        return err_code;
    nrfx_err_t nrfx_twi_tx(nrfx_twi_t const * p_instance,
                           uint8_t            address,
                           size_t             length,
                           bool               no_stop)
        nrfx_twi_xfer_desc_t xfer = NRFX_TWI_XFER_DESC_TX(address, (uint8_t*)p_data, length);
        return nrfx_twi_xfer(p_instance, &xfer, no_stop ? NRFX_TWI_FLAG_TX_NO_STOP : 0);
    nrfx_err_t nrfx_twi_rx(nrfx_twi_t const * p_instance,
                           uint8_t            address,
                           uint8_t *          p_data,
                           size_t             length)
        nrfx_twi_xfer_desc_t xfer = NRFX_TWI_XFER_DESC_RX(address, p_data, length);
        return nrfx_twi_xfer(p_instance, &xfer, 0);
    size_t nrfx_twi_data_count_get(nrfx_twi_t const * const p_instance)
        return m_cb[p_instance->drv_inst_idx].bytes_transferred;
    uint32_t nrfx_twi_stopped_event_get(nrfx_twi_t const * p_instance)
        return (uint32_t)nrf_twi_event_address_get(p_instance->p_twi, NRF_TWI_EVENT_STOPPED);
    static void twi_irq_handler(NRF_TWI_Type * p_twi, twi_control_block_t * p_cb)
        NRFX_ASSERT(p_cb->handler);
        if (twi_transfer(p_twi,
                         &p_cb->error,
                         p_cb->p_curr_buf,
                         p_cb->curr_length,
                         p_cb->curr_no_stop ))
            return;
        if (!p_cb->error &&
            ((p_cb->xfer_desc.type == NRFX_TWI_XFER_TXRX) ||
             (p_cb->xfer_desc.type == NRFX_TWI_XFER_TXTX)) &&
            p_cb->p_curr_buf == p_cb->xfer_desc.p_primary_buf)
            p_cb->p_curr_buf   = p_cb->xfer_desc.p_secondary_buf;
            p_cb->curr_length  = p_cb->xfer_desc.secondary_length;
            p_cb->curr_no_stop = (p_cb->flags & NRFX_TWI_FLAG_TX_NO_STOP);
            if (p_cb->xfer_desc.type == NRFX_TWI_XFER_TXTX)
                (void)twi_tx_start_transfer(p_cb,
                                            p_twi,
                                            p_cb->p_curr_buf,
                                            p_cb->curr_length,
                (void)twi_rx_start_transfer(p_cb, p_twi, p_cb->p_curr_buf, p_cb->curr_length);
            nrfx_twi_evt_t event;
            event.xfer_desc = p_cb->xfer_desc;
            if (p_cb->error)
                    event.type = NRFX_TWI_EVT_ADDRESS_NACK;
                    NRFX_LOG_DEBUG("Event: %s.", EVT_TO_STR(NRFX_TWI_EVT_ADDRESS_NACK));
                else if (errorsrc & NRF_TWI_ERROR_DATA_NACK)
                    event.type = NRFX_TWI_EVT_DATA_NACK;
                    NRFX_LOG_DEBUG("Event: %s.", EVT_TO_STR(NRFX_TWI_EVT_DATA_NACK));
                event.type = NRFX_TWI_EVT_DONE;
                NRFX_LOG_DEBUG("Event: %s.", EVT_TO_STR(NRFX_TWI_EVT_DONE));
            p_cb->busy = false;
            if (!(NRFX_TWI_FLAG_NO_XFER_EVT_HANDLER & p_cb->flags))
                p_cb->handler(&event, p_cb->p_context);
    void nrfx_twi_0_irq_handler(void)
        twi_irq_handler(NRF_TWI0, &m_cb[NRFX_TWI0_INST_IDX]);
    void nrfx_twi_1_irq_handler(void)
        twi_irq_handler(NRF_TWI1, &m_cb[NRFX_TWI1_INST_IDX]);
    #endif // NRFX_CHECK(NRFX_TWI_ENABLED)
