pstorage_handle_t is lost in BLE NUS data event
why m_storageHandle_DeviceName became to 0xFFFFFFFF, its value was init by pstorage_register when app startup, but here it lost value. Can anybody help me ?
// event on receiving data from ble uart service
static void on_nus_data_evt(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    uint32_t err_code = 0;
    if (p_data != NULL && length > 0)
        err = pstorage_clear( & m_storageHandle_DeviceName,
                                       DEVICE_NAME_LENGTH*4);
	APP_ERROR_CHECK(err);
  • code.txt
    // main.c
    static ble_nus_t m_nus; static ble_nus_init_t m_nus_init; static pstorage_handle_t m_storageHandle_DeviceName;
    static void on_nus_data_evt(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length) { uint32_t err_code = 0;
        pstorage_handle_t blockHandle;
    err_code = pstorage_block_identifier_get(&m_storageHandle_DeviceName, 0, &blockHandle);
    static void bond_manager_init(void) { uint32_t err_code; ble_bondmngr_init_t bond_init_data; bool bonds_delete;
    err_code = pstorage_init();
    err_code = app_button_is_pushed(SIGNAL_ALERT_BUTTON, &bonds_delete);
    bond_init_data.flash_page_num_bond     = FLASH_PAGE_BOND;
    bond_init_data.flash_page_num_sys_attr = FLASH_PAGE_SYS_ATTR;
    bond_init_data.evt_handler             = NULL;
    bond_init_data.error_handler           = bond_manager_error_handler;
    bond_init_data.bonds_delete            = bonds_delete;
    err_code = ble_bondmngr_init(&bond_init_data);
    static void gap_params_init(void) { uint32_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode;
    pstorage_module_param_t param;
    param.block_count = 1;
    param.block_size = 8*4;
    param.cb = on_pstorage_deviceName_evtHandler;
    err_code = pstorage_register(&param, &m_storageHandle_DeviceName);
    static uint8_t devName[DEVICE_NAME_LENGTH]__attribute__((aligned(4))) = {0};
    GET_DEVICE_NAME(devName);
    err_code = sd_ble_gap_device_name_set(&sec_mode, (uint8_t *)devName, DEVICE_NAME_LENGTH);
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
    err_code = sd_ble_gap_tx_power_set(TX_POWER_LEVEL);
    static void nus_init(void) { uint32_t err_code;
    memset(&m_nus_init, 0, sizeof(m_nus_init));
    m_nus_init.data_handler = on_nus_data_evt;
    err_code = ble_nus_init(&m_nus, &m_nus_init);
    int main(void) { ble_stack_init();
    bond_manager_init();
    gap_params_init();
    advertising_init(BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE);
    nus_init();
    conn_params_init();
    sec_params_init();
    advertising_start();
    for (;;)
        uint32_t err_code = sd_app_evt_wait();
  • It's 0xFFFFFFFF before calling pstorage_clear().
  • So after
    It's not 0xFFFFFFFF and in on_nus_data_evt() callback it's 0xFFFFFFFF?
    Then try to follow your code and check m_storageHandle_DeviceName value in your code to identify where does it corrupt:
    if (m_storageHandle_DeviceName == 0xFFFFFFFF) {led_on(); while(1);}
    First place if after:
    then after:
    gap_params_init();
    and etc.
  • thanks, i am trying.
  • I find that the m_storageHandle_DeviceName currupt after pstorage_load().
    static uint8_t devName[DEVICE_NAME_LENGTH]attribute((aligned(4))) = {0}; pstorage_handle_t blockHandle; pstorage_block_identifier_get(&m_storageHandle_DeviceName, 0, &blockHandle); pstorage_load(devName, &blockHandle, DEVICE_NAME_LENGTH*4, 0);
