Using:
- nRF51822
- GCC 4.8.4
- Nordic Sdk 5.2.0
- pure-gcc setup (Ole Morten)
- newlib-nano and -flto
See also this question.
I'd defined some stack size within startup_nrf51.s and want to be informed if the stackpointer passes __StackLimit.
Might there be a way to generate something like a hardfault or something else? The stack overflow condition should be detected regardless if the device is in debugging environment or not.
Edit 2014-08-28
BTW: For the heap / malloc issue, I see a different approach using a custom _sbrk() implementation. I'll post it as soon as I got a solution.
Trying out the RLENR0 based approach as suggested by RK.
My ram memory layout is currently like this:
__data_start__ = 20002000
__data_end__ = 20002088
__bss_start__ = 20002090
__bss_end__ = 20002DC4
__HeapBase = 20002DC8
__HeapLimit = 200031C8
__StackLimit = 20003400
__StackTop = 20004000
__stack = 20004000
Dump of current RLENR0 and CLENR0 values:
NRF_MPU->RLENR0 = 00002000
NRF_UICR->CLENR0 = 00014000
NRF_FICR->CLENR0 = FFFFFFFF
I'm using the Sdk 5.2 bootloader which performs a check to NRF_UICR->CLENR0
// This check ensures that the defined fields in the bootloader corresponds with actual setting in the nRF51 chip.
APP_ERROR_CHECK_BOOL(NRF_UICR->CLENR0 == CODE_REGION_1_START);
so I'm a bit afraid from changing CLENR0 register.
Now I stuck for finding the correct RLENR0 value and write that into NRF_MPU->RLENR0.
I'd try it from within code (tried both startup asm and very start of main).
By trying out some random values:
- Info: At the time when changing
NRF_MPU->RLENR0within main, my stackpointer is at0x20003EF0(determined by calling__get_MSP()). - For values like
0x20003400, my application stops immediately. Don't know if my hardfault handler was called - if so, then he was unable to write something via uart. - For values above
0x2140, I earn a immediate hardfault however. - All values from
0x0000up to0x2140, my application runs like before.
For the last case, I see my changed value in NRF_MPU->RLENR0, but when calling softdevice_handler_init() the value will be restored to 0x2000.
When I now try to change NRF_MPU->RLENR0 again, a hardfault is raised - regardless which value I try to set.
Could you help me to find the right value for NRF_MPU->RLENR0 and how to write it into?
