nrf_dfu_flash_callback_t changed in SDK 15
 with SDK15 the definition of the nrf_dfu_flash_callback_t changed from
typedef nrf_fstorage_evt_handler_t dfu_flash_callback_t;
typedef void (*nrf_fstorage_evt_handler_t)(nrf_fstorage_evt_t * p_evt);
typedef struct
    nrf_fstorage_evt_id_t   id;         //!< The event ID.
    ret_code_t              result;     //!< Result of the operation.
    uint32_t                addr;       //!< Address at which the operation was performed.
    uint32_t                len;        //!< Length of the operation.
    void                  * p_param;    //!< User-defined parameter passed to the event handler.
} nrf_fstorage_evt_t;
to
typedef void (*nrf_dfu_flash_callback_t)(void * p_buf);
we used the nrf_fstorage_evt_t->result to determine the success of the operation in the callback, but now with the (void* p_buf) we can't do it, because there is no description what data is in this buffer and in what form.
If someone could provide a solution, I would appreciate it.
Thanks in advance and best regards,
Niclas
  • So previously the dfu_fstorage_evt_handler gave the whole nrf_fstorage_evt_t to the callback, which we used to determine the success of the operation. But how can i determine the success of the operation with only p_src given?
    The dfu_fstorage_evt_handler only has debug output for success or failure. Do i have to compare the given p_src buffer with the data buffer i wanted to write to make sure the operation was successful?
    For me this seems like a big step back.
    If there is a new (easy) way to get the result, i woul appreciate it, if you could point me to it.
    Niclas
  • I see your point. Unfortunately, I have not been able to get hold of any one that can shed light on this change due to most of the R&D being on summer vacation. I will try to get back to you with a better answer as soon as possible, though.
  • Hello Einar,
    has there been any progress regarding this issue?
    Niclas
  • Hello!
    So, as far I as can see there are a couple of functions accepting a nrf_dfu_flash_callback_t. In general, those functions accept a callback that will be invoked upon completion and passed the memory buffer used for the operation, which the caller has the responsibility to free.
    For example, taking the case of nrf_dfu_flash_store(), the application allocates a memory buffer to receive data into; that buffer is passed to the store function, together with a nrf_dfu_flash_callback_t. When that operation has completed and the buffer has been written to flash, the callback is invoked and provided a pointer to that buffer and so the buffer is freed.
    If you want to know the result or progress of the DFU operation you should check for any NRF_DFU_EVT_* events that arrive to the handler you supplied to  nrf_dfu_req_handler_init().
    sorry for the late response, but i wanted to get our code working with the new design before accepting a solution.
    Since we dropped the matter for now, I will accept your answer since it was suggested by a Nordic employee even though i couldn't test it myself.
    Thanks and best regards,
    Niclas
