Very high response times of reliable unicast messages.
I adapted the light switch demo of the nRF5 SDK for Mesh for sending a series of reliable on/off messages sequentially from an nRF52840 Preview DK to 20 Thingy:52 servers via send_reliable_message(). In this scenario I measure in most cases response times between 20 to 50 milliseconds, which is quite acceptable. However in about one of 20 cases there is a significant higher response time of many seconds. It seems that the delay in this cases is always a multiply of 5 seconds, so I get 5, 10, 15 and so on seconds response time in these cases. Is this a normal behavior of the stack, and do I therefore have to accept these sporadic long response times? Or is there maybe a parameter which can be tweaked in order to get a better performance with reliable messages?
  • Hi Armin,
    Very sorry for the delayed response. Hung has been on vacation for the past two weeks & it seems we forgot to follow up on this case. I am very sorry about that. Hung will be back on Monday, but I will try my best to help you out & hopefully we can figure out the issue before he is back. Are you using mesh sdk v2.0.1?
    Kind Regards,
    Bjørn
  • Yes, according to the RELEASE_NOTES.md we use
    BLE Mesh v2.0.1
    We are very sorry for the delays over the past days. I have been looking at this issue today.
    I think that your reported 10 ms advertising interval is way too short for letting the Mesh stack run properly. Did you test increasing it?
    It would be great if we could build and reproduce this issue locally, but it seems many of the files that are needed to build the project are still missing... Usually we ask for a minimal example showing the erroneous behavior. It may be an option to strip some of the unneeded functionality away from the project instead. Or, we would need all the included c and h files for building the projects.
    If I have understood things correctly, the projects are:
    For nRF52840 DK: examples\light_switch\proxy_client\light_switch_proxy_client_nrf52840_xxAA_s140_6_0_0.emProject
    For the Thingy:52s: examples\light_switch\thingy_provisioning_demo_generic_OnOff_BLINK\light_switch_proxy_server_nrf52832_xxAA_s132_6_0_0.emProject
    Can you confirm or correct that?
    Terje
    Regarding the delays that you see, you mentioned they all are a multiple of 5 seconds. Can you confirm that you see all of the multiples of 5, and that it is not a series where each number is the double amount of the previous number, as in 5, 10, 20, etc?
    One hypothesis is that while the message is sent and received, the acknowledgement is lost, which means the message is resent until an acknowledgement is correctly received (or a timeout). But the behavior for resending messages is that the time between retries is doubled every time, and that does not correspond to delays increasing linearly.
    Terje
  • Regarding advertising interval I did not change that parameter against what is preset in your examples. I even don't know where this is defined, so if I shall increase it as you recommended please let me know in which file it is exactly defined so that I can find it.
    Yes, the projects are those which are mentioned by you before. Look:
    For reproduction you should take the original Nordic examples and override the sources in:
    • \nRF5_SDK_for_Mesh\examples\light_switch\proxy_client\include
    • \nRF5_SDK_for_Mesh\examples\light_switch\proxy_client\src
    • \nRF5_SDK_for_Mesh\models\generic_on_off\include
    • \nRF5_SDK_for_Mesh\models\generic_on_off\src
    • \nRF5_SDK_for_Mesh\examples\light_switch\include
    • \nRF5_SDK_for_Mesh\examples\light_switch\thingy_provisioning_demo_generic_OnOff_BLINK\include
    • \nRF5_SDK_for_Mesh\examples\light_switch\thingy_provisioning_demo_generic_OnOff_BLINK\src
    Regarding the delays I made a mistake in my description: it is actually always a double amount of the previous number starting with 5 as you mentioned above, i.e. 5, 10, 20, etc. and not just a multiply of 5. Sorry for that. In fact, if I understood it right, this confirms your hypothesis of lost acknowledges.
    However, the question remains why there are messages lost. Maybe the behavior improves when the advertising interval time is increased. So either you test it on your own or you help me finding the code where the parameter is defined so I can test it. But this may take some days as I'm currently quite busy with other work.
