CARRIERs SCAN PROCEDURE With nRF24L01+
Dear Sr.,
Can't detect carrier
They are two PCB one TX Carrier and other mush Detect the carrier
PCB1 TX CARRIER AT Channel 2.410 Ghz (Without data). This module generate only carrier for detecting for PCB2
PCB1 SW:
5 mS
CE=0
wSPI,#00100000b ;WR CONFIG Register SELECT
wSPI,#00001010b ;EN_CRC bit3 Set=1,PWR_UP bit1 Set=1,Set as PTX bit0=0
5 mS
wSPI,#00100101b ;WR RF_CH Register SELECT
wSPI,#10 ;Channel 2.410Ghz
5 mS
wSPI,#00100110b ;WR RF_SETUP Register SELECT
wSPI,#10001110b ;Continous Carrier Tx, 2Mbis/s, 0dBm Tx
CE=1
HALT
This SW run the carrier is OK
PCB2 RX CARRIER AT Channel 2.410 Ghz. This module mush detect carrier from PCB
PCB2 SW:
1 munute after PCB1 power on
5 mS
CE=0
wSPI,#00001011b ;EN_CRC bit3 Set=1,PWR_UP bit1 Set=1,PRX bit0 Set=1
5 mS
5 mS
CE1:
CE=1
5 mS
CE=0
wSPI,#00001001b ;RD RPD Register SELECT
rSPI,RD STATUS ;RD STATUS
rSPI,RPD ;Lee RPD
All Time Bit0=0 ;For Carrier Detec mush be =1
GOTO CE1
This SW don't detect the carrier
What I do wrong ?
Thank
  • Thanks Hakon for your support,
    but need understand as this RPD bit is detected as one easy secuence or flowchart mode.
    I work in assembler and don't understand well C, but I had found one C secuence than is possible can run, if you can explain it terms as I explain at the top of this Nordic Case Info.
    LPO
    The source code I found is:
    #define CE 9
    #define CHANNELS 64 // Define as array to hold channel data
    int channel[CHANNELS];
    #define _NRF24_CONFIG 0x00 // Registers 0x00
    #define _NRF24_EN_AA 0x01 // Registers 0x01
    #define _NRF24_RF_CH 0x05 // Registers 0x05
    #define _NRF24_RF_SETUP 0x06 // Registers 0x06
    #define _NRF24_RPD 0x09 // Registers 0x09
    // Get the value of the NRF25L01 Registers
    byte getRegister(byte r)
    byte c;
    PORTB &=~_BV(2);
    c = SPI.transfer(r&0x1F);
    c = SPI.transfer(0);
    PORTB |= _BV(2);
    return(c);
    // set the value of a nRF24L01p register
    void setRegister(byte r, byte v)
    PORTB &=~_BV(2);
    SPI.transfer((r&0x1F)|0x20);
    SPI.transfer(v);
    PORTB |= _BV(2);
    void powerUp(void) // power up the nRF24L01p chip
    setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)|0x02);
    delayMicroseconds(130);
    // switch nRF24L01p off
    void powerDown(void)
    setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)&~0x02);
    void enable(void) //Activate RX
    PORTB |= _BV(1);
    void disable(void) //Deactivate RX
    PORTB &=~_BV(1);
    // setup RX-Mode of nRF24L01p
    void setRX(void)
    setRegister(_NRF24_CONFIG,getRegister(_NRF24_CONFIG)|0x01);
    enable();
    // this is slightly shorter than
    // the recommended delay of 130 usec
    delayMicroseconds(100);
    //SCANNING ALL CHANNELS IN 2.4GHz Band
    void scanChannels(void)
    disable();
    for( int j=0 ; j<200 ; j++)
    for( int i=0 ; i<CHANNELS ; i++)
    // select a new channel
    setRegister(_NRF24_RF_CH,(128*i)/CHANNELS);
    // switch on RX
    setRX();
    // wait enough for RX-things to settle
    delayMicroseconds(40);
    // this is actually the point where the RPD-flag
    // is set, when CE goes low
    disable();
    // read out RPD flag; set to 1 if
    // received power > -64dBm
    if( getRegister(_NRF24_RPD)>0 ) channel[i]++;
    Thanks for the example code.
    You need to wait atleast 130 us (Ramp-up time) before reading the RPD bit, and I would also recommend reading this prior to disabling the RX. Could you try this and see if you get the expected result?
    Håkon
