Using the UART example of the 52DK with the TX and RX pins set as 8 and 6 the example works. If I try to change the pins to different pins such as 22 and 23, it does not work by giving an UART Comm Error. Problem is reported from the UART ISR.
Thank you.
It worked fine when I tested it using SES. I'll do some tests using Keil and see what I can find out.
Cheers.
Hi, I'm having exactly the same issue. Running the examples/peripheral/uart example it works fine with pins 6 and 8 from port 0 in PCA10056 board. But when I change the pin to a free pin there is no communication. I'm using SES. Should I try another IDE? Am I missing any other change in the code, apart from the definition of RX_PIN_NUMBER and TX_PIN_NUMBER in pca10056.h?
Thanks in advance!
Hi martabc_96,
Maybe you could post a new question about this?
Please explain in detail your setup etc.
Joakim.
I have the same problem.
I am using IAR.
If the problem was solved by changing the IDE, it seems to be solved by the IDE settings. Which setting is it?
Please give me a good advice.
