I am working with Thread on the nRF52840 and have setup a few nodes and a Border Router 1.0.0 as described in the documentation using Raspberry Pi 3B+.
My sdk is nRF5_SDK_for_Thread_and_Zigbee_v1.0.0
Is it possible to run nrfutil on the Raspberry Pi?
I tried the following on Rasp Pi:
sudo apt-get update sudo apt-get install python-pip sudo pip install nrf util
It seemed to successfully install, but I'm thinking it's intended for a PC, not ARM.
I followed the Thread Secure DFU example using my PC successfully, and then prepared another package (appdfu_package_3.zip) with a minor change to the client code.
I ran nrfutil as before, only this time on the Raspberry Pi within the Border Router. I left off the -f option, since the Border Router is already connected to a DK board running NCP.
nrfutil dfu thread -pkg appdfu_package_3.zip --channel 11 --panid 43981 -r 8 -rs 5000 -a FF03::1
File "/usr/local/bin/nrfutil", line 11, in <module>
sys.exit(cli())
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 722, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 697, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 1066, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 895, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 535, in invoke
return callback(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/nordicsemi/__main__.py", line 901, in thread
ble_driver_init('NRF52')
File "/usr/local/lib/python2.7/dist-packages/nordicsemi/__main__.py", line 65, in ble_driver_init
from pc_ble_driver_py.ble_driver import BLEDriver, Flasher
File "/usr/local/lib/python2.7/dist-packages/pc_ble_driver_py/ble_driver.py", line 105, in <module>
raise RuntimeError("Could not load shared library {} : '{}'.".format(shlib_path, error))
RuntimeError: Could not load shared library /usr/local/lib/python2.7/dist-packages/pc_ble_driver_py/lib/linux/x86_32/libpc_ble_driver_shared_sd_api_v3.so : '/usr/local/lib/python2.7/dist-packages/pc_ble_driver_py/lib/linux/x86_32/libpc_ble_driver_shared_sd_api_v3.so: cannot open shared object file: No such file or directory'.
The libraries is said it couldn't find are in fact there. But I suspect they are compiled for x86 and not ARM, given the path name.
I saw an older post https://devzone.nordicsemi.com/f/nordic-q-a/15509/trying-to-use-a-nrfutil-command-on-raspbian-os describing how to compile nrfutil from source, but it's a bit old and doesn't mention these libraries.
Is this possible? Any plans to provide nrfutil for ARM?
Mary
