The connected emulator does not support serial wire output (SWO)
I am using Eclipse Kelpler SD2 and GNU ARM 4.7 tool chain, plus GNU ARM Eclipse Plugin
and after download code into CM0 I got the warning
"The connected emulator does not support serial wire output (SWO)
My setup environment
  1. Eclipse IDE for C/C++ Developers Version: Kepler Service Release 2
  2. GNU ARM tool chain 4.7
  3. GNU ARM Eclipse plug-in
  4. J-link V4.90d
=============== J-Link GDB Server Log ========================
SEGGER J-Link GDB Server V4.90d GUI Version
JLinkARM.dll V4.90d (DLL compiled Aug 29 2014 14:49:16)
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      localhost only
Generate logfile:              off
Verify download:               off
Init regs on start:            on
Silent mode:                   off
Single run mode:               off
Target connection timeout:     5 sec.
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 nRF51822_xxAA
Target interface:              SWD
Target interface speed:        1000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link OB-SAM3U128 V1 compiled Aug 22 2014 17:25:44
Hardware: V1.00
S/N: 480209778
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 4 bytes @ address 0x00000000 (Data = 0x00000708)
Target interface speed set to 1000 kHz
Resetting target
Halting target CPU...
...Target halted (PC = 0x00000630)
R0 = FFFFFFFF, R1 = FFFFFFFF, R2 = FFFFFFFF, R3 = FFFFFFFF
R4 = FFFFFFFF, R5 = FFFFFFFF, R6 = FFFFFFFF, R7 = FFFFFFFF
R8 = FFFFFFFF, R9 = FFFFFFFF, R10= FFFFFFFF, R11= FFFFFFFF
R12= FFFFFFFF, R13= 00000708, MSP= 00000708, PSP= FFFFFFFC
R14(LR) = FFFFFFFF, R15(PC) = 00000630
XPSR C1000000, APSR C0000000, EPSR 01000000, IPSR 00000000
CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
Select auto target interface speed (2000 kHz)
Flash breakpoints enabled
Semi-hosting enabled (VectorAddr = 0x08)
Semihosting I/O set to TELNET Client
SWO disabled succesfully.
GDB closed TCP/IP connection
If I ignore the warning and dismiss the dialog, program can run but could not stop at any breakpoint
