pm_conn_secure does NOT timeout when Central does not initiate bonding
Hello:
I have been at this problem for days now and not getting anywhere to a solution. My app is using  a static passkey for encryption and does timeout after 30 seconds if no key is received from the central when using the nRFconnect app as it should. Our central app uses BlueGiga dongle and BlueGiga has their own GUI app that can be used for testing. when using Bluegiga app and not enabling bonding, my app still connects and still transmits data and does NOT timeout and therefore bypassing the whole security feature. I know that the passkey is passed through the boding process but how can I force my app to disconnect if the central does not wanna bond? I am using SDK 15 and softdevice 6.00. any help would be greatly appreciated.
Here is my peer manger init function
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
I did try with SEC_PARAM_LESC set to 1 and made no difference.
static void peer_manager_init(void)
//    ble_gap_sec_params_t sec_param;
    ret_code_t           err_code;
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
		static uint8_t passkey[] = "000000";
    static ble_opt_t m_ble_opt;
    m_ble_opt.gap_opt.passkey.p_passkey = &passkey[0];
		err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY,&m_ble_opt);
static uint32_t standard_acquisition_char_add(ble_acq_mode_service_t * p_acq_mode_service, ble_acq_mode_service_init_t const * p_acq_mode_service_init)
    /**@snippet [Adding proprietary characteristic to the SoftDevice] */
		uint32_t            err_code;
    ble_gatts_char_md_t char_md;
    ble_gatts_attr_md_t cccd_md;
    ble_gatts_attr_t    attr_char_value;
    ble_uuid_t          ble_uuid;
    ble_gatts_attr_md_t attr_md;
		memset(&cccd_md, 0, sizeof(cccd_md));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    cccd_md.vloc = BLE_GATTS_VLOC_STACK;
		memset(&char_md, 0, sizeof(char_md));
		char_md.char_props.read 	= 1;
		char_md.char_props.write 	= 1;
    char_md.char_props.notify = 1;
    char_md.p_char_user_desc  = NULL;
    char_md.p_char_pf         = NULL;
    char_md.p_user_desc_md    = NULL;
		char_md.p_cccd_md         = &cccd_md;
    char_md.p_sccd_md         = NULL;
		memset(&attr_md, 0, sizeof(attr_md));
//		attr_md.read_perm  = p_acq_mode_service_init->acq_mode_service_value_char_attr_md.read_perm;
//    attr_md.write_perm = p_acq_mode_service_init->acq_mode_service_value_char_attr_md.write_perm;
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM(&attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM(&attr_md.write_perm);
		attr_md.vloc    = BLE_GATTS_VLOC_STACK;
    attr_md.rd_auth = 0;
    attr_md.wr_auth = 0;
    attr_md.vlen    = 1;
		ble_uuid.type = p_acq_mode_service->uuid_type;
    ble_uuid.uuid = BLE_UUID_STANDARD_FUNCTION_CHARACTERISTIC_UUID;
		memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid    = &ble_uuid;
    attr_char_value.p_attr_md = &attr_md;
    attr_char_value.init_len  = sizeof(uint8_t);
    attr_char_value.init_offs = 0;
    attr_char_value.max_len   = 20;
		err_code =  sd_ble_gatts_characteristic_add(p_acq_mode_service->service_handle,
                                           &char_md,
                                           &attr_char_value,
                                           &p_acq_mode_service->standard_char_handle );
		if (err_code != NRF_SUCCESS)
        return err_code;
    return NRF_SUCCESS;
    uint32_t           							err_code;
    nrf_ble_qwr_init_t 							qwr_init = {0};
		ble_acq_mode_service_init_t     acq_mode_service_init;
		ble_dfu_init_t 									dfus_init = {0};
		ble_dis_init_t     							dis_init;
		memset(&acq_mode_service_init, 0, sizeof(acq_mode_service_init));
		acq_mode_service_init.evt_handler = on_acq_mode_service_evt;
//		BLE_GAP_CONN_SEC_MODE_SET_OPEN(&acq_mode_service_init.acq_mode_service_value_char_attr_md.read_perm);
//		BLE_GAP_CONN_SEC_MODE_SET_OPEN(&acq_mode_service_init.acq_mode_service_value_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM (&acq_mode_service_init.acq_mode_service_value_char_attr_md.read_perm);
		BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM (&acq_mode_service_init.acq_mode_service_value_char_attr_md.write_perm);
		err_code = ble_acq_mode_service_init(&m_acq_mode_service, &acq_mode_service_init);
#ifndef DEBUG
    // Initialize the async SVCI interface to bootloader.
    err_code = ble_dfu_async_svci_init();
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_init(&dfus_init);
		// Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
    ble_srv_ascii_to_utf8(&dis_init.serial_num_str, MODEL_NUMBER);
    ble_dis_sys_id_t system_id;
    system_id.manufacturer_id            = MANUFACTURER_ID;
    system_id.organizationally_unique_id = ORG_UNIQUE_ID;
    dis_init.p_sys_id                    = &system_id;
//    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
//    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM(&dis_init.dis_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_LESC_ENC_WITH_MITM(&dis_init.dis_attr_md.write_perm);
    err_code = ble_dis_init(&dis_init);
