NRF_ERROR_SVC_HANDLER_MISSING whith uart
When I use the uart to transparently transmit, there is no problem at around 4k/s. When I increase the transparent transmission rate, there will be NRF_ERROR_SVC_HANDLER_MISSING this error in the APP_UART_COMMUNICATION_ERROR event.
What is the reason, I have been unable to find the reason, if you want a higher transmission rate, what should I do, I do not want to use flow control, dma is not a better choice?
  • I didn't turn on UART_EASY_DMA_SUPPORT =1 because I have tried to turn it on, but turning it on will cause the power consumption to be upgraded to about 2mA. Compared with the 52810 power consumption is too high. As mentioned here, the 52810 does not appear in the case of not turning on UART_EASY_DMA_SUPPORT. Error, I set the uar priority to 6 buffers to 512. The effect is improved, but this problem still occurs. I am now trying a higher uart priority.https://devzone.nordicsemi.com/f/nordic-q-a/36342/uart0_config_use_easy_dma-1-lead-hight-consumption
  • UART_EASY_DMA_SUPPORT =1 Isn't really turning on DMA, but what is this used? I tried to turn on UART_EASY_DMA_SUPPORT =1 to avoid this error, but why it leads to such high power consumption, we are going to produce the product, with the same series. The 52810 is not normal compared to this
  • I gradually increased the rx buffer 1024 tx buffer512 uart UART_DEFAULT_CONFIG_IRQ_PRIORITY to 2 The result did not improve,
  • My original code is on NRF52810. This problem does not occur, but I have this problem when I ported to 52832.
    How does your makefile look like ?
    Did you remove DNRF52810_XXAA, and added DNRF52832_XXAA ?
    Did you remove DDEVELOP_IN_NRF52832?
    Was the nRF52810 a QFN48, QFN32 or WLCSP varaint? The pin assignments might be different here compared to a nRF52832 QFN48.
    Have you checked that TX and RX are connected to the correct pins?
  • PROJECT_NAME     := ble_app_uart_pca10040_s132
    TARGETS          := BLE_UART_NRF52832_xxaa
    OUTPUT_DIRECTORY := _build
    SDK_ROOT := ../../../../../..
    PROJ_DIR := ../../..
    $(OUTPUT_DIRECTORY)/BLE_UART_NRF52832_xxaa.out: \
      LINKER_SCRIPT  := ble_app_uart_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_rtt.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_backend_serial.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_default_backends.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_frontend.c \
      $(SDK_ROOT)/components/libraries/experimental_log/src/nrf_log_str_formatter.c \
      $(SDK_ROOT)/components/libraries/button/app_button.c \
      $(SDK_ROOT)/components/libraries/util/app_error.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/fifo/app_fifo.c \
      $(SDK_ROOT)/components/libraries/scheduler/app_scheduler.c \
      $(SDK_ROOT)/components/libraries/timer/app_timer.c \
      $(SDK_ROOT)/components/libraries/uart/app_uart_fifo.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/hardfault/hardfault_implementation.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/atomic_fifo/nrf_atfifo.c \
      $(SDK_ROOT)/components/libraries/balloc/nrf_balloc.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf.c \
      $(SDK_ROOT)/external/fprintf/nrf_fprintf_format.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage.c \
      $(SDK_ROOT)/components/libraries/fstorage/nrf_fstorage_sd.c \
      $(SDK_ROOT)/components/libraries/experimental_memobj/nrf_memobj.c \
      $(SDK_ROOT)/components/libraries/pwr_mgmt/nrf_pwr_mgmt.c \
      $(SDK_ROOT)/components/libraries/experimental_section_vars/nrf_section_iter.c \
      $(SDK_ROOT)/components/libraries/strerror/nrf_strerror.c \
      $(SDK_ROOT)/components/libraries/uart/retarget.c \
      $(SDK_ROOT)/components/libraries/util/sdk_mapped_flags.c \
      $(SDK_ROOT)/components/drivers_nrf/clock/nrf_drv_clock.c \
      $(SDK_ROOT)/components/drivers_nrf/common/nrf_drv_common.c \
      $(SDK_ROOT)/components/drivers_nrf/gpiote/nrf_drv_gpiote.c \
      $(SDK_ROOT)/components/drivers_nrf/uart/nrf_drv_uart.c \
      $(PROJ_DIR)/main.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_Syscalls_GCC.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
      $(SDK_ROOT)/components/ble/common/ble_advdata.c \
      $(SDK_ROOT)/components/ble/ble_advertising/ble_advertising.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_params.c \
      $(SDK_ROOT)/components/ble/common/ble_conn_state.c \
      $(SDK_ROOT)/components/ble/common/ble_srv_common.c \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt/nrf_ble_gatt.c \
      $(SDK_ROOT)/components/toolchain/gcc/gcc_startup_nrf52.S \
      $(SDK_ROOT)/components/toolchain/system_nrf52.c \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus/ble_nus.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_ble.c \
      $(SDK_ROOT)/components/softdevice/common/nrf_sdh_soc.c \
      $(SDK_ROOT)/components/libraries/simple_timer/app_simple_timer.c\
      $(SDK_ROOT)/components/libraries/fds/fds.c \
      $(SDK_ROOT)/components/libraries/gpiote/app_gpiote.c \
      $(SDK_ROOT)/components/drivers_nrf/wdt/nrf_drv_wdt.c \
      $(SDK_ROOT)/components/drivers_nrf/timer/nrf_drv_timer.c \
      $(SDK_ROOT)/components/drivers_nrf/power/nrf_drv_power.c\
    # Include folders common to all targets
    INC_FOLDERS += \
      $(SDK_ROOT)/components/libraries/gpiote\
      $(SDK_ROOT)/components/drivers_nrf/comp \
      $(SDK_ROOT)/components/drivers_nrf/twi_master \
      $(SDK_ROOT)/components/ble/ble_services/ble_ancs_c \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias_c \
      $(SDK_ROOT)/components/libraries/pwm \
      $(SDK_ROOT)/components/softdevice/s132/headers/nrf52 \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc/acm \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/generic \
      $(SDK_ROOT)/components/libraries/usbd/class/msc \
      $(SDK_ROOT)/components/libraries/usbd/class/hid \
      $(SDK_ROOT)/components/libraries/experimental_log \
      $(SDK_ROOT)/components/ble/ble_services/ble_gls \
      $(SDK_ROOT)/components/libraries/fstorage \
      $(SDK_ROOT)/components/drivers_nrf/i2s \
      $(SDK_ROOT)/components/libraries/mutex \
      $(SDK_ROOT)/components/libraries/experimental_log/src \
      $(SDK_ROOT)/components/drivers_nrf/gpiote \
      $(SDK_ROOT)/components/libraries/fifo \
      $(SDK_ROOT)/components/libraries/experimental_memobj \
      $(SDK_ROOT)/components/drivers_nrf/common \
      $(SDK_ROOT)/components/libraries/fds \
      $(SDK_ROOT)/components/ble/ble_advertising \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas_c \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs_c \
      $(SDK_ROOT)/components/libraries/queue \
      $(SDK_ROOT)/components/libraries/pwr_mgmt \
      $(SDK_ROOT)/components/ble/ble_dtm \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs_c \
      $(SDK_ROOT)/components/drivers_nrf/uart \
      $(SDK_ROOT)/components/ble/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_lls \
      $(SDK_ROOT)/components/drivers_nrf/wdt \
      $(SDK_ROOT)/components/ble/ble_services/ble_bas \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/components/softdevice/s132/headers \
      $(SDK_ROOT)/components/ble/ble_services/ble_ans_c \
      $(SDK_ROOT)/components/libraries/slip \
      $(SDK_ROOT)/components/libraries/mem_manager \
      $(SDK_ROOT)/external/segger_rtt \
      $(SDK_ROOT)/components/libraries/usbd/class/cdc \
      $(SDK_ROOT)/components/drivers_nrf/hal \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus_c \
      $(SDK_ROOT)/components/drivers_nrf/rtc \
      $(SDK_ROOT)/components/softdevice/common \
      $(SDK_ROOT)/components/ble/ble_services/ble_ias \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/mouse \
      $(SDK_ROOT)/components/libraries/ecc \
      $(SDK_ROOT)/components/drivers_nrf/ppi \
      $(SDK_ROOT)/components/ble/ble_services/ble_dfu \
      $(SDK_ROOT)/external/fprintf \
      $(SDK_ROOT)/components/drivers_nrf/twis_slave \
      $(SDK_ROOT)/components/libraries/atomic \
      $(SDK_ROOT)/components \
      $(SDK_ROOT)/components/libraries/scheduler \
      $(SDK_ROOT)/components/libraries/cli \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs \
      $(SDK_ROOT)/components/ble/ble_services/ble_hts \
      $(SDK_ROOT)/components/drivers_nrf/delay \
      $(SDK_ROOT)/components/libraries/crc16 \
      $(SDK_ROOT)/components/drivers_nrf/timer \
      $(SDK_ROOT)/components/libraries/util \
      $(SDK_ROOT)/components/drivers_nrf/pwm \
      ../config \
      $(SDK_ROOT)/components/libraries/csense_drv \
      $(SDK_ROOT)/components/libraries/csense \
      $(SDK_ROOT)/components/libraries/balloc \
      $(SDK_ROOT)/components/libraries/low_power_pwm \
      $(SDK_ROOT)/components/libraries/hardfault \
      $(SDK_ROOT)/components/ble/ble_services/ble_cscs \
      $(SDK_ROOT)/components/libraries/uart \
      $(SDK_ROOT)/components/libraries/hci \
      $(SDK_ROOT)/components/libraries/usbd/class/hid/kbd \
      $(SDK_ROOT)/components/drivers_nrf/spi_slave \
      $(SDK_ROOT)/components/drivers_nrf/lpcomp \
      $(SDK_ROOT)/components/libraries/timer \
      $(SDK_ROOT)/components/drivers_nrf/rng \
      $(SDK_ROOT)/components/drivers_nrf/power \
      $(SDK_ROOT)/components/libraries/usbd/config \
      $(SDK_ROOT)/components/toolchain \
      $(SDK_ROOT)/components/libraries/led_softblink \
      $(SDK_ROOT)/components/drivers_nrf/qdec \
      $(SDK_ROOT)/components/ble/ble_services/ble_cts_c \
      $(SDK_ROOT)/components/drivers_nrf/spi_master \
      $(SDK_ROOT)/components/ble/ble_services/ble_nus \
      $(SDK_ROOT)/components/libraries/twi_mngr \
      $(SDK_ROOT)/components/ble/ble_services/ble_hids \
      $(SDK_ROOT)/components/libraries/strerror \
      $(SDK_ROOT)/components/drivers_nrf/pdm \
      $(SDK_ROOT)/components/libraries/crc32 \
      $(SDK_ROOT)/components/libraries/usbd/class/audio \
      $(SDK_ROOT)/components/ble/peer_manager \
      $(SDK_ROOT)/components/drivers_nrf/swi \
      $(SDK_ROOT)/components/ble/ble_services/ble_tps \
      $(SDK_ROOT)/components/ble/ble_services/ble_dis \
      $(SDK_ROOT)/components/device \
      $(SDK_ROOT)/components/ble/nrf_ble_gatt \
      $(SDK_ROOT)/components/ble/nrf_ble_qwr \
      $(SDK_ROOT)/components/libraries/button \
      $(SDK_ROOT)/components/libraries/usbd \
      $(SDK_ROOT)/components/drivers_nrf/saadc \
      $(SDK_ROOT)/components/libraries/atomic_fifo \
      $(SDK_ROOT)/components/ble/ble_services/ble_lbs_c \
      $(SDK_ROOT)/components/ble/ble_racp \
      $(SDK_ROOT)/components/toolchain/gcc \
      $(SDK_ROOT)/components/libraries/twi \
      $(SDK_ROOT)/components/drivers_nrf/clock \
      $(SDK_ROOT)/components/ble/ble_services/ble_rscs \
      $(SDK_ROOT)/components/drivers_nrf/usbd \
      $(SDK_ROOT)/components/ble/ble_services/ble_hrs \
      $(SDK_ROOT)/examples/ble_peripheral/ble_app_uart\
      $(SDK_ROOT)/examples/ble_peripheral/ble_app_uart/board\
      $(SDK_ROOT)/components/libraries/simple_timer\
      $(SDK_ROOT)/components/drivers_nrf/power\
    # Libraries common to all targets
    LIB_FILES += \
    # Optimization flags
    OPT = -O1 -g3
    # Uncomment the line below to enable link time optimization
    #OPT += -flto
    # C flags common to all targets
    CFLAGS += $(OPT)
    CFLAGS += -DBOARD_MS50SF1AC
    CFLAGS += -DCONFIG_NFCT_PINS_AS_GPIOS
    CFLAGS += -DBLE_STACK_SUPPORT_REQD
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DFLOAT_ABI_HARD
    CFLAGS += -DNRF52
    CFLAGS += -DDEBUG
    CFLAGS += -DBLE_UART_NRF52832_XXAA
    CFLAGS += -DNRF52_PAN_74
    CFLAGS += -DNRF_SD_BLE_API_VERSION=5
    CFLAGS += -DS132
    CFLAGS += -DSOFTDEVICE_PRESENT
    CFLAGS += -DSWI_DISABLE0
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS += -Wall -w -O2 -g3
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in a separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin -fshort-enums
    # C++ flags common to all targets
    CXXFLAGS += $(OPT)
    # Assembler flags common to all targets
    ASMFLAGS += -g3
    ASMFLAGS += -mcpu=cortex-m4
    ASMFLAGS += -mthumb -mabi=aapcs
    ASMFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    ASMFLAGS += -DBOARD_MS50SF1AC
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DCONFIG_NFCT_PINS_AS_GPIOS
    ASMFLAGS += -DFLOAT_ABI_HARD
    ASMFLAGS += -DNRF52
    ASMFLAGS += -DBLE_UART_NRF52832_XXAA
    ASMFLAGS += -DNRF52_PAN_74
    ASMFLAGS += -DNRF_SD_BLE_API_VERSION=5
    ASMFLAGS += -DS132
    ASMFLAGS += -DSOFTDEVICE_PRESENT
    ASMFLAGS += -DSWI_DISABLE0
    # Linker flags
    LDFLAGS += $(OPT)
    LDFLAGS += -mthumb -mabi=aapcs -L $(TEMPLATE_PATH) -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs
    # Add standard libraries at the very end of the linker input, after all objects
    # that may need symbols provided by these libraries.
    LIB_FILES += -lc -lnosys -lm
    .PHONY: default help
    # Default target - first one defined
    default: BLE_UART_NRF52832_xxaa
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo		BLE_UART_NRF52832_xxaa
    	@echo		flash_softdevice
    	@echo		sdk_config - starting external tool for editing sdk_config.h
    	@echo		flash      - flashing binary
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    .PHONY: flash flash_softdevice erase
    # Flash the program
    flash: $(OUTPUT_DIRECTORY)/BLE_UART_NRF52832_xxaa.hex
    	@echo Flashing: $<
    	nrfjprog -f nrf52 --program $< --sectorerase
    	nrfjprog -f nrf52 --reset
    # Flash softdevice
    flash_softdevice:
    	@echo Flashing: s132_nrf52_5.0.0_softdevice.hex
    	nrfjprog -f nrf52 --program $(SDK_ROOT)/components/softdevice/s132/hex/s132_nrf52_5.0.0_softdevice.hex --sectorerase
    erase:
    	nrfjprog -f nrf52 --eraseall
    SDK_CONFIG_FILE := ../config/sdk_config.h
    CMSIS_CONFIG_TOOL := $(SDK_ROOT)/external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar
    sdk_config:
    	java -jar $(CMSIS_CONFIG_TOOL) $(SDK_CONFIG_FILE)
    I used the logic code of sdk13 52810, then modified the logic code on the ble_uart_peripheral routine of sdk14.2, and then I encountered this problem. I don't think this has anything to do with the makefile.
