Using BLE NUS SERVICE without UART
Hello
I would like to send my sensor data to a mobile application using BLE SDK 15. Someone suggested me to go through the BLE NUS SERVICE example which was a good one. I understood a lot of things but now my sensor values are coming on analog pins and not on UART pins. How do i send those values? Would i have to create a whole new service for doing this or could i somehow modify the same example to work according to my needs. Thanks!
  • err_code = 0x05 is NRF_ERROR_NOT_FOUND.
    This means that the ble_nus_data_send() receives an invalid conn_handle.
    What conn_handle do you insert?
    in ble_nus_data_send()?
    from the ble_app_uart example:
    Do you get this return value before or after you connect with the phone?
    Edvin
  • Hello Edvin,
    That sounds about right. Actually, i do not understand the concept of connection handle, so i passed the same "m_conn_handle" in my ble_nus_data_send() function. The error comes before connection itself. Can you tell me a little about the connection handle ? or a link where i can learn bout it. Thanks,
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            uint8_t str[4];
          sprintf((char*)str, "%d", (int)adc_sample);
          ret_code_t err_code =  ble_nus_data_send(&m_nus, str, strlen((char*)str), m_conn_handle);
            //idle_state_handle();
    The explanation is using the unmodified ble_app_uart example:
    The connection handle is, during the startup of the ble_app_uart example, set to BLE_CONN_HANDLE_INVALID (= 0xFFFF).
    In the BLE_GAP_EVT_CONNECTED event in ble_evt_handler in main.c, the conn_handle, m_conn_handle is set to the conn_handle of the connection event, and it remains unchanged until the disconnected-event.
    If you look in the same example, in the uart_event_handle() in main.c, which is the only place using the ble_nus_data_send() function, you can see that it ignores returns from ble_nus_data_send if the err_code = NRF_ERROR_INVALID_STATE, NRF_ERROR_BUSY or NRF_ERROR_NOT_FOUND.
    It only means that it will not try to send anything if there is no device to send to.
    So you can ignore this error:
    err_code = ble_nus_data_send(...)
    if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) && (err_code != NRF_ERROR_NOT_FOUND))
    However, you can use these return values to tell your application that the message is not sent, if you need it. The fact that ble_nus_data_send() returns any of these values will not break anything, other than telling you that the message was not sent.
    Alternatively, you can check the conn_handle before you try to send:
    if(m_conn_handle != BLE_CONN_HANDLE_INVALID)
        err_code = ble_nus_data_send(...);
        if (err_code != NRF_ERROR_INVALID_STATE && err_code != NRF_ERROR_BUSY)
    Edvin
  • Hello Edvin,
    I went on to a different project but now i am again back to nrf52832 DK and want to send sensor data to mobile app.
    I am running the ble app uart example. I have enabled the notification of TX characteristic(3 arrows downward) in nrf connect app but still i cannot send any data from Putty to app. I can not even write anything on my COM listener. Why is that so?
  • Make sure that you set up the Putty Terminal correct, as described here:
    http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.2.0%2Flib_cli.html&anchor=lib_cli_terminal_settings
    Remember to follow both "Terminal settings" and "UART and USB settings".
    If you are having problems, check out the Termite Terminal. It is a bit more limited, but easier to set up.
    Edvin
