pca10028 disconnects immediately when trying to connect using ble_app_uart
Can anyone tell me if there is a specific problem on the nFR 51 using the 12.3 DK, where a disconnect is seen when it connects? I'm using Android Lolipop 5.0 on a BLU device. I see the disconnect immediately after selecting the nordic device in the selection dropdown, so it does see the device.
I have read that the 51 had problems, and it wasn't clear if the 52 also has the same problem, or if this is similar with a timeout not being set at the start?
The project I'm working on will use the 52 and I'm thinking of just buying one, but before I do I wanted to find out if this is a common problem with 51 and 52 devices? Isolated to 51? Neither, an error in the ble_app_uart example?
I'm going to get the sniffer setup tonight and see what I see, but I'm using Linux so it requires some jumping through a couple hoops to get the nRF sniffer going...:(
Any help would be appreciated. Eventually I need to get a 52 board, but was trying to use this until the firmware iscomplete, that will be based around your 52 chipset. I'm not doing that portion, I'm on the software side.
The firmware engineer is on vacation, so I'm trying to get going in the meantime. AFAIK, I have the example built and flashed properly to the pca10028 device I'm using.
I'm attempting to use the UART profile with 32 bytes of data.
Compiler:
arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 7-2018-q2-update) 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907]
flash:
[aland@eagle armgcc]$ pwd
/home/aland/src/nRF5_12.3.0/examples/ble_peripheral/ble_app_uart/pca10028/s130/armgcc
[aland@eagle armgcc]$ make flash
Flashing: _build/nrf51422_xxac.hex
nrfjprog --program _build/nrf51422_xxac.hex -f nrf51 --sectorerase
Parsing hex file.
Erasing page at address 0x1B000.
Erasing page at address 0x1B400.
Erasing page at address 0x1B800.
Erasing page at address 0x1BC00.
Erasing page at address 0x1C000.
Erasing page at address 0x1C400.
Erasing page at address 0x1C800.
Erasing page at address 0x1CC00.
Erasing page at address 0x1D000.
Erasing page at address 0x1D400.
Erasing page at address 0x1D800.
Erasing page at address 0x1DC00.
Erasing page at address 0x1E000.
Erasing page at address 0x1E400.
Erasing page at address 0x1E800.
Erasing page at address 0x1EC00.
Erasing page at address 0x1F000.
Erasing page at address 0x1F400.
Erasing page at address 0x1F800.
Erasing page at address 0x1FC00.
Erasing page at address 0x20000.
Erasing page at address 0x20400.
Erasing page at address 0x20800.
Applying system reset.
Checking that the area to write is not protected.
Programming device.
nrfjprog --reset -f nrf51
Run.
OS:
Ubuntu 18.04 (bionic beaver)
Alan
  • Hello Alan,
    Unfortunately, we do not have this type of list. The thumb rule, My understanding is that the earliest android versions that supported BLE was a bit unstable. I believe this was 4."something", so 4.3 might be unstable for some phones. So if you try a phone from the later years, it should be more stable.
    However, I can't guarantee that this is actually the issue. You must check the sniffer log. However, there are no known issues with the common examples in the SDK (the ones not marked as experimental) with relatively new phones (both Android and Apple).
    You can post in this thread when you receive the nRF52DK, or if you have any other questions before that.
    Edvin
  • I'm not sure what happened but I replied a couple days ago and don't see it here now...hmmm...
    Anyway, Edvin, I got the 52 but see the same thing...I suspect I should try with a different version of Android, but wanted to get your thoughts?
    I'm using Lolipop 5.0.
    I'm only using nRF Logger so far, but will get the nRF Sniffer setup.
    nRF Logger Output
    nRF Connect, 2018-08-09
    No name (30:90:3F:2E:2C:67)
    V 15:36:21.248 Connecting to 30:90:3F:2E:2C:67...
    D 15:36:21.249 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE) (hidden)
    V 15:36:39.933 Cancelling connection...
    D 15:36:39.933 gatt.disconnect()
    I 15:36:39.937 Disconnected
    D 15:36:39.951 [Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
    D 15:36:39.958 gatt.refresh() (hidden)
    D 15:36:41.286 [Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
    D 15:36:41.289 gatt.refresh() (hidden)
    D 15:37:33.377 gatt.close()
    D 15:37:33.379 wait(200)
  • What softdevice do you use with the nRF52?
    A sniffer trace would be helpful. Now that you have 2 Developemnt Kits (I assume), you can use the nRF51 as a sniffer device with the nRF Sniffer.
    What SDK and example do you run?
    Can you try to print the disconnect reason?
    It should be in the disconnected event. Depending on what SDK you use, it would look a bit different, but something like this:
    case BLE_GAP_EVT_DISCONNECTED
        NRF_LOG_INFO("Disconnected");
    // change to:
        NRF_LOG_INFO("Disconnected, reason 0x%02x", p_ble_evt->evt.gap_evt.params.disconnected.reason);
    And see if you can see the disconnect reason.
    But please specify what SDK you use with the nRF52. Can you try to run one of the unmodified examples from one of the later examples? E.g. SDK15\examples\ble_peripheral\ble_app_uart
    Edvin
  • Edvin,
    I believe the SD is s132 per the project. I'm using the pca10056 directory and it looks like it has s132 inside of it. Is that correct?
    I do have a 51, but unfortunately the micro-usb connector came loose from the circuit board. I will have access to another 52 when my colleague gets back from vacation. I think he can fix this one also, but I don't want to try to solder it as my equipment is not nearly as good as his stuff. I think he's coming back this week.
    Trying various apps, nRF Connect is one, I think I should see it and be able to connect.
    This might be a dumb question, but how do I determine the ID on my 52 DK? Maybe I'm trying to connect to the wrong device.
    I really only need to get packets across onto the Android device. I think I might be connecting to the wrong device or not seeing it. How can I get all the info from the 52 DK?
    Alan
