How to configure FREERTOS Tasks for the following description
Hi Everyone
My requirements are as follows
1. I am running 4 tasks using free rtos in which one measures the ADC , 2nd sends the adc data over BLE and 3rd check if the button is pressed or not and 4th sends the ADC data to LORA.
2. All my 4 tasks are running perfectly so far.
But i would like to have this feature in my code.
Whenever i press the button , the controller should come out of sleep mode and run the other 2 tasks of measuring adc and sending data over BLE.
As long as button is in low state(NOT PRESSED) ,the controller should remain in sleep mode and should not do anything.
My questions are
1. How to put the nrf52840 to Sleep mode ?
2. How to achieve the above described theory using FREERTOS Tasks.
3. Can i use mutexes and sempahores for the above theory?
4. What are the available Sleep modes on nrf52840.?
5. What are the functions to call to put nrf52840 to sleep modes?
  • App_timer would have made things easier for you , its super siimple to use and low current consuming.
    FreeRTOS is a bit difficult
  • I know that but before that, I need to show the working with freertos tasks. I have attached the code snippet.
    void Battery_Level_Take_Reading(void)
      vTaskSuspend(ble_task_handle);
      uint32_t iteration = 0;
      while (1)
            uint32_t i;
            for(iteration = 0;iteration <500; iteration++)
              nrf_saadc_value_t result;
              uint32_t calc;
              if (nrfx_saadc_sample_convert(0, &result) != NRFX_SUCCESS)
                NRF_LOG_INFO("ADC failure\r\n");
            //    calc = result;
            //    calc *= NANOVOLTS_PER_BIT;
            //    calc /= MV_PER_NV; // Calc now contains the voltage in mV
                printf("ADC: %d\r\n", result);
          //      NRF_LOG_INFO("ADC: %d\r\n", result);
               vTaskDelay(TASK_DELAY);
            vTaskResume(ble_task_handle);
     void advertising_start(void)
        vTaskSuspend(adc1_task_handle);
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        while(1)
        printf(" ble task 1 \n");
    //    if(xSemaphoreTake(task_signal, portMAX_DELAY))
          vTaskDelay(15000);
          vTaskResume(adc1_task_handle);
  • void Battery_Level_Take_Reading(void)
      while (1)
            uint32_t i;
              uint32_t calc;
            //    calc = result;
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        while(1)
          vTaskDelay(15000);
    Try with this one
  • No. Now its continuously performing the battery that is adc task.
    while (1)
    uint32_t i;
    uint32_t calc;
    // calc = result;
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    while(1)
    vTaskDelay(15000);
    Try with this one , but i guess this is also possible using semaphores
    Sorry , its been a while since i worked with freertos so couldn't offer much help Disappointed
