Getting analog values from different channels using SAADC example
Hello ,
I want to read around 6 analog pins, not necessarily simultaneously. I could afford some delay in between them. i am using nrf52832 dev kit with sdk 15. How do i modify the SAADC example to achieve the same because the example only reads 1 channel. i did found this thread https://devzone.nordicsemi.com/f/nordic-q-a/5561/adc-from-various-pins/19481#19481 which looks similar but i was unable to open the GitHub link provided in the thread. Can you please direct me to the relevant examples.
Thank you!
  • Don't see any result, or do you see some results, but not the ones you are looking for? (Does the application stop, or does it print blank values?)
    Please see this post.
    As described, you must use NRF_LOG_FLOAT_MARKER instead of %f when using NRF_LOG to print float values.
    Edvin
  • Hello Edvin,
    Thanks for the answer. It certainly worked for NRF LOG but how can i see the result in the debug terminal window? In the attached image you can see that i am getting float result in putty terminal but the output of printf() function displays nothing in the debug terminal window.
  • Also, when i am connecting the analog pin to VDD, its giving me 2.87V. should not I be getting 3.3V by connecting to VDD ?
  • I see that printf isn't defined by default in the saadc example, so I haven't tested, but have you tested the exact same approach in printf? Just swap NRF_LOG_INFO with printf.
    printf("My float number " NRF_LOG_FLOAT_MARKER "\r\n", NRF_LOG_FLOAT(R));
    BR,
    Edvin
  • Hi Edvin, Hope you are doing good. We just received our prototype boards with nrf52840 processor . Very excited. I have started testing modules of my firmware.
    I am still running into issues while collecting data from analog channels. please look at the attached code snippet and suggest what am i doing wrong. My goal is to store all the values from 5 analog channels into an array adc_value[] and then use these values to do some calculations. But I am facing some weird behavior where I am getting values one by one, sometimes only on channel 1 , sometimes on channel 2 etc.
    i am simply trying to store
    AIN0 VALUE -> adc_value[0]
    AIN1 VALUE -> adc_value[1]
    AIN2 VALUE -> adc_value[2]
    AIN3 VALUE -> adc_value[3]
    AIN4 VALUE -> adc_value[4]
    Can you please suggest a better way to do so.
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_timer.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_delay.h"
    #include "nrf_gpio.h "
    #include "boards.h"
    #include "nrf_drv_spi.h"
    #include "app_error.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "math.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "PULSE_1.0.0"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAADC_SAMPLES_IN_BUFFER         5
    float C1 = 0.00100924;
    float C2 = 0.0002378;
    float C3 = 0.000000201920;
    float R,C,R1,R2;
    static uint8_t value[10];
    float Res1 = 10000;
    float Res2 = 5100;
    static int     m_buffer_pool1[SAADC_SAMPLES_IN_BUFFER ];
    #define SAMPLES_IN_BUFFER 3
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
    static nrf_saadc_value_t     m_buffer_pool[4][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                nrf_gpio_cfg_output(9);
                nrf_gpio_pin_write(9, 1);
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
                             (err_code != NRF_ERROR_NOT_FOUND) )
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
            static int adc_value[SAADC_SAMPLES_IN_BUFFER];
            uint16_t T,T1, T2, P1, P2;
            uint8_t nus_to_send_array[2];
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            int i;
            NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
            for (i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
                   adc_value[i] = p_event->data.done.p_buffer[i];
                 R = 10000*((825.5/adc_value[0])-1);
                float logR = log(R);
                 C = C1 + C2*logR + C3*logR*logR*logR;
                T = 1/C;
                T = T - 273.15;
                T = (T*9)/5 + 32;
                T = T/1.009;
                 R1 = 10000*((825.5/adc_value[1])-1);
                float logR1 = log(R1);
                 C = C1 + C2*logR1 + C3*logR1*logR1*logR1;
                T1 = 1/C;
                T1 = T1 - 273.15;
                T1 = (T1*9)/5 + 32;
                T1 = T1/1.009;
                R2 = 10000*((825.5/adc_value[2])-1);
                float logR2 = log(R2);
                 C = C1 + C2*logR2 + C3*logR2*logR2*logR2;
                T2 = 1/C;
                T2 = T2 - 273.15;
                T2 = (T2*9)/5 + 32;
                T2 = T2/1.009;
                P1 = ((adc_value[3] * 3.6)/1024);
                P1 = P1*(Res2/Res2+Res1);
                P1 = (P1 - 0.5)/4;
                P1 = P1*2;
                P1 = P1*145.038;
                P2 = ((adc_value[4] * 3.6)/1024);
                P2 = P2*(Res2/Res2+Res1);
                P2 = (P2 - 0.5)/4;
                P2 = P2*4;
                P2 = P2*145.038;
            value[0] = (adc_value[0] & 0xFF00) >> 8;
            value[1] = (adc_value[0] & 0x00FF);
            value[2] = (T1 & 0xFF00) >> 8;
            value[3] = (T1 & 0x00FF);
            value[4] = (T2 & 0xFF00) >> 8;
            value[5] = (T2 & 0x00FF);
            value[6] = (P1 & 0xFF00) >> 8;
            value[7] = (P1 & 0x00FF);
            value[8] = (P2 & 0xFF00) >> 8;
            value[9] = (P2 & 0x00FF);
            m_adc_evt_counter++;
    void saadc_init(void)
             //TEMP 1
             nrf_saadc_channel_config_t channel_0_config =
             NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
             //TEMP2
               nrf_saadc_channel_config_t channel_1_config =
             NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
             //TEMP3
               nrf_saadc_channel_config_t channel_2_config =
             NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
               nrf_saadc_channel_config_t channel_3_config =
             NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
               nrf_saadc_channel_config_t channel_4_config =
             NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
        err_code = nrf_drv_saadc_init(NULL, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
         err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
         err_code = nrf_drv_saadc_channel_init(4, &channel_4_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_init();
        advertising_start();
          uint16_t bytes_to_send = 10;
        for (;;)
            nrf_drv_saadc_sample();
            nrf_delay_ms(2000);
            ble_nus_data_send(&m_nus, value, &bytes_to_send , m_conn_handle);
             idle_state_handle();
