nRF5 SDK build error with GCC under windows
I am using SDK5 for my code that builds successfully under Linux, but not under windows.
The error occurs in the SDK, not in the application. I am wondering what modifications are needed to migrate from Linux to Windows, apart from editing MakeFile.Windows?
The details are as follow:
build system: Makefile + GNU tools ARM embedded, version 7.3.1
Windows 7 vs UBUNTU
MakeFile.Windows:
GNU_INSTALL_ROOT := C:/Program Files (x86)/GNU Tools ARM Embedded/7 2018-q2-update/bin/
GNU_VERSION := 7.3.1
GNU_PREFIX := arm-none-eabi
The error shown:
Building nrf52832
C:/Aries/Ares-NRF52/nrf52832/makefile.mak:162: *** empty variable name. Stop.
The mentioned line (MakeFile.mak: 162):
$(foreach target, $(TARGETS), $(call define_target, $(target)))
And the macro that is called in the above line:
# $1 target name
define define_target
$(eval OUTPUT_FILE := $(OUTPUT_DIRECTORY)/$(strip $(1))) \
$(eval $(1): $(OUTPUT_FILE).out $(OUTPUT_FILE).hex $(OUTPUT_FILE).bin \
           ; @echo DONE $(strip $(1))) \
$(call prepare_build, $(1), $(OUTPUT_FILE).inc, $(OUTPUT_FILE).out)
endef
this macro and subsequent ones look fine, considering that it builds successfully under Linux with the same makefile and GCC version.
I have read and applied all relevant guides and I don't see what is the issue.
As for the last comment, my windows GCC builds our other projects successfully. So, the problem is not in its installation.
Thank you for any idea
  • Sorry, I should have mentioned that the file had been modified to hide the list of source files. The line in question is at line 111 now.
    Also, in regard to your next question, please go through these new attachments:
    all:
    	@make -f project.mak VARIANT=s3 ROOT_DIR=`pwd`
    clean:
    	@make -f project.mak VARIANT=s3 ROOT_DIR=`pwd` clean
    .PHONY: clean all
    # Diablo top level makefile.
    # Invoke using b.bat
    # In general, hierarchical makefile's are difficult, see:
    # http://aegis.sourceforge.net/auug97.pdf ("Recursive Make Considered Harmful")
    # In this case, the dependancies are linear, i.e.
    # "scale" project depends on "libstdperiphusb" and "libcmisusb".
    # "libstdperiphusb" only depends on "libcmisusb" (and not "scale").
    # "libcmisusb" does not depend on the other projects.
    # So there are no tricky circular project dependancies.
    # Project must be in dependancy order:
    #PROJECTS = bootstrap update scale2 nrf52832
    PROJECTS = scale2 nrf52832
    # pass into make VARIANT=ew5 or VARIANT=ew6.
    ifeq (x,x$(strip $(VARIANT)))
    # by default, build s3
    VARIANT = s3
    endif
    # object files go here...
    OBJ_DIR = obj/$(VARIANT)
    ROOT_DIR = $(CURDIR)
    .PHONY: clean all info $(PROJECTS)
    all: info $(PROJECTS)
    info:
    	# @echo ' ' > build_log.log
    	@echo Running:  project.mak | tee -a build_log.log
    	@echo Building: $(PROJECTS) | tee -a build_log.log
    	@echo Root dir: $(ROOT_DIR) | tee -a build_log.log
    	@echo Shell path: $$PATH | tee -a build_log.log
    	@echo Variant: $(VARIANT) | tee -a build_log.log
    	@echo ' ' | tee -a build_log.log
    $(PROJECTS):
    	@echo Building $@ | tee -a build_log.log
    	@mkdir -p $(ROOT_DIR)/$@/$(OBJ_DIR)
    	@make --no-print-directory -r -C $(ROOT_DIR)/$@/$(OBJ_DIR) \
    	OBJ_DIR=$(OBJ_DIR) \
    	ROOT_DIR=$(ROOT_DIR) \
    	PROJ_DIR=$(ROOT_DIR)/$@ \
    	VARIANT=$(VARIANT) \
    	-f $(ROOT_DIR)/$@/makefile.mak 2>&1 | tee -a build_log.log
    	@echo ' '
    clean: info
    	@echo ' '
    	@echo Cleaning: $(PROJECTS)
    	for proj in $(PROJECTS); do rm -rf $(ROOT_DIR)/$$proj/obj; done;
    	@echo ' '
  • Have you tried replacing $(CURDIR) variable with an absolute path? I get the same error when trying to use this in the Makefiles in Windows.
