Unable to connect (bond) to nrf52810 using nrfConnect
Hi, I have been developing on the nRF52832. I am now in the process of moving to the nRF52810.
I am using the SDK v15.
I have commented out the DEVELOP_IN_NRF52832 define in the pca10040e Makefile.
It seems to be working OK. I can see the device on the nrf connect app. However, when I click connect, it is unable to connect.
If I comment back in DEVELOP_IN_NRF52832 and switch back to the nRF52832, everything works perfectly.
I have made my own custom service. But I don't think that should matter. Any ideas?
  • I tried using the RC oscillator (using the sdk_config tool). This did not change anything.
    Your hex works perfectly on my hardware, I am able to connect without any issues!
    I re-downloaded the sdk v15 and commented out the DEVELOP_IN_NRF52832 define. Then I flashed the example without any modifications. I had the same issues on my nrf52810.
    Perhaps this is an issue with my LEDs and Buttons or maybe the RSOSC. What is the RSOSC and how do I enable it?
    What did you do to disable the Buttons and LEDs?
  • I just commented out buttons_leds_init(&erase_bonds); in main so that the IOs did not get initialized. Meant to type RCOSC (RC oscillator).
    So it appears that the problem might be related to the pinout, or have you changed the default pins already?
  • Hmm, when I commented out the buttons_led_init(&erase_bonds) the device didn't even advertise. Perhaps I will try that again just in case.
    I might send a copy of my pin out when I get the chance. I haven't changed any default pins from the downloaded sdk.
    I have re-flashed your .hex a number of times and it works perfectly every time. Perhaps the sdk_config is different? I can send copy of my sdk_config if you think that might help?
  • I have done the following steps.
    1. Downloaded sdk v15
    2. Point toolchain to gcc folder
    3. Commented out buttons_leds_init(&erase_bonds);
    -> And removed the -Werror flag to hide the unused function warning
    4. Commented out the two DDEVELOP_IN_NRF52832 flags in the Makefile
    5. Made these changes to the sdk_config
    -> Set CLOCK_CONFIG_LF_SRC to RC
    -> Set NRFX_CLOCK_CONFIG_LF_SRC to RC
    -> Set NRF_SDH_CLOCK_LF_SRC to NRF_CLOCK_LF_SRC_RC
    -> Set NRF_SDH_CLOCK_LF_ACCURACY to NRF_CLOCK_LF_ACCURACY_500_PPM
    Then I did the following
    make clean
    make erase
    make flash_softdevice
    make flash
    I am still having issues. Is there something I am missing. There must be some reason why your hex file works perfectly. Can you think of what other step I should do?
  • Strange, I don't see any relevant differences with your approach compared to what I did. Are you testing with a "clean" SDK copy, or is it possible that there are other changes in your code base? Attached is the code I used here.
    nRF5_SDK_15.0.0_52810_hts.zip
