NUS central and DFU using Serialization
I'm using 2 nRF52832s in my project. One of them is connected to a PC serially and has NUS central running on it and the other nRF52 connects to this central. I was able to get the HRM example running with the connectivity firmware on the nRF52 which is connected serially to the PC.
1. Similar to the Serialized HRM example, are there any examples of NUS central which I can use with the HCI BLE connectivity firmware?
2. I would also like to use the nRF52 which will be running the connectivity firmware as an intermediary to perform a DFU on the peripheral nRF52. Is this possible?
Thanks
    Your last answer helped me quite a lot, thanks for that.
    I was able to reach till the characteristic descriptor discovery part, but I'm facing the following issues:
    1) I followed this link's suggestion and incremented the handle by 1 and called the characteristic discover function. But I noticed that the characteristic handles are being allotted in increments of 2.
            NUS RX Characteristic handle = 0x000C
            NUS TX Characteristic handle = 0x000E
    But the above link says to increment by 1 and the graph in the link just states a variable N. So is this value programmer dependent?
    2) When calling the descriptor discovery function, I'm getting the following CCCD details:
           Handle = 0x000E
           UUID = 0x2803
    Is the handle supposed to be same as that of the TX characteristic's handle? Also, from what I understood the CCCD UUID should always be 0x2902. If yes, then any specific reason why I am getting a wrong UUID?
    0x2803 is the characteristic declaration so  seems that the value handle for the NUS TX Characteristic handle should be 0xE + 1. Recommend to have a look at this blog post for a better explanation of the attribute table layouthttps://devzone.nordicsemi.com/tutorials/b/bluetooth-low-energy/posts/ble-characteristics-a-beginners-tutorial
    I have not verified it, but it looks like you can use the existing discovery functions used in heart rate collector example and just change the UUIDs to filter on, or is that what you have done already?
  • I did look at the link you suggested. The table says that the CCCD UUID is 0x2800 while the "Attributes types(UUIDs)" paragraph says that the CCCD UUID is 0x2902. Is that a mistake in the document?
    I did use the existing discovery functions. The only change I made is that I kept calling the characteristic discovery function (after adding 1 to the start handle) the till I received the GATT status BLE_GATT_STATUS_ATTERR_ATTRIBUTE_NOT_FOUND.
    Also, I connected to the peripheral using the nRFConnect app. In the app, it showed the CCCD UUID as 0x2902. But the descriptor discovery using serialization shows that one descriptor is found with UUID as 0x2803, but I haven't added any descriptors to the peripheral other than CCCD. FYI, the peripheral is running a modified version of ble_app_uart example but without any changes to the characteristics or descriptors from the original example.
  • I think that must be a mistake in the documentation, will ask the author to confirm.
    I tried the pc-ble-driver v.2.3.2  with API version 3 and managed to hack together an example works with the standard ble_app_uart example. I.e., complete service discovery and receive notifications. Can you try to see if it works for you?
    Modified hrs_collector example:
    /* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    /**@example examples/heart_rate_collector
     * @brief Heart Rate Collector Sample Application main file.
     * This file contains the source code for a sample application that acts as a BLE Central device.
     * This application scans for a Heart Rate Sensor device and reads it's heart rate data.
     * https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.service.heart_rate.xml
    #include "ble.h"
    #include "sd_rpc.h"
    #include <stdbool.h>
    #include <stdio.h>
    #include <string.h>
    #ifdef _WIN32
    #define UART_PORT_NAME "COM1"
    #define BAUD_RATE 1000000 /**< The baud rate to be used for serial communication with nRF5 device. */
    #ifdef __APPLE__
    #define UART_PORT_NAME "/dev/tty.usbmodem00000"
    #define BAUD_RATE 115200 /**< Baud rate 1M is not supported on MacOS. */
    #ifdef __linux__
    #define UART_PORT_NAME "/dev/ttyACM0"
    enum
        UNIT_0_625_MS = 625,  /**< Number of microseconds in 0.625 milliseconds. */
        UNIT_1_25_MS  = 1250, /**< Number of microseconds in 1.25 milliseconds. */
        UNIT_10_MS    = 10000 /**< Number of microseconds in 10 milliseconds. */
    #define MSEC_TO_UNITS(TIME, RESOLUTION) (((TIME) * 1000) / (RESOLUTION))
    #define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 milliseconds. */
    #define SCAN_WINDOW   0x0050 /**< Determines scan window in units of 0.625 milliseconds. */
    #define SCAN_TIMEOUT  0x0    /**< Scan timeout between 0x01 and 0xFFFF in seconds, 0x0 disables timeout. */
    #define MIN_CONNECTION_INTERVAL         MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
    #define MAX_CONNECTION_INTERVAL         MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
    #define SLAVE_LATENCY                   0                                /**< Slave Latency in number of connection events. */
    #define CONNECTION_SUPERVISION_TIMEOUT  MSEC_TO_UNITS(4000, UNIT_10_MS)  /**< Determines supervision time-out in units of 10 milliseconds. */
    #define TARGET_DEV_NAME "Nordic_UART" /**< Connect to a peripheral using a given advertising name here. */
    #define MAX_PEER_COUNT 1            /**< Maximum number of peer's application intends to manage. */
    #define NUS_BASE_UUID                        {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}}  /**< Used vendor specific UUID. */
    #define BLE_UUID_NUS_SERVICE                 0x0001
    #define BLE_UUID_NUS_RX_CHARACTERISTIC       0x0002
    #define BLE_UUID_NUS_TX_CHARACTERISTIC       0x0003
    #define BLE_UUID_CCCD                        0x2902
    #define BLE_CCCD_NOTIFY                      0x01
    #define STRING_BUFFER_SIZE 50
    typedef struct
        uint8_t *     p_data;   /**< Pointer to data. */
        uint16_t      data_len; /**< Length of data. */
    } data_t;
    static uint8_t     m_connected_devices = 0;
    static uint16_t    m_connection_handle = 0;
    static uint16_t    m_service_start_handle = 0;
    static uint16_t    m_service_end_handle = 0;
    static uint16_t    m_nus_rx_handle = 0;
    static uint16_t    m_nus_tx_handle = 0;
    static uint16_t    m_nus_tx_cccd_handle = 0;
    static bool        m_connection_is_in_progress = false;
    static adapter_t * m_adapter = NULL;
    static const ble_gap_scan_params_t m_scan_param =
         1,                       // Active scanning set.
         0,                       // Selective scanning not set.
    #if NRF_SD_BLE_API == 2
         NULL,                    // White-list not set.
    #if NRF_SD_BLE_API >= 3
         0,                       // adv_dir_report not set.
         (uint16_t)SCAN_INTERVAL,
         (uint16_t)SCAN_WINDOW,
         (uint16_t)SCAN_TIMEOUT
    static const ble_gap_conn_params_t m_connection_param =
        (uint16_t)MIN_CONNECTION_INTERVAL,
        (uint16_t)MAX_CONNECTION_INTERVAL,
        (uint16_t)SLAVE_LATENCY,
        (uint16_t)CONNECTION_SUPERVISION_TIMEOUT
    /* Local function forward declarations */
    static uint32_t ble_stack_init();
    static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata);
    static bool find_adv_name(const ble_gap_evt_adv_report_t *p_adv_report, const char * name_to_find);
    static uint32_t scan_start();
    static uint32_t service_discovery_start();
    static uint32_t char_discovery_start();
    static uint32_t descr_discovery_start();
    static uint32_t hrm_cccd_set(uint8_t value);
    static void ble_address_to_string_convert(ble_gap_addr_t address, uint8_t * string_buffer);
    /**@brief Function for handling error message events from sd_rpc.
     * @param[in] adapter The transport adapter.
     * @param[in] code Error code that the error message is associated with.
     * @param[in] message The error message that the callback is associated with.
    static void status_handler(adapter_t * adapter, sd_rpc_app_status_t code, const char * message)
        printf("Status: %d, message: %s\n", (uint32_t)code, message);
        fflush(stdout);
    /**@brief Function for handling the log message events from sd_rpc.
     * @param[in] severity Level of severity that the log message is associated with.
     * @param[in] message The log message that the callback is associated with.
    static void log_handler(adapter_t * adapter, sd_rpc_log_severity_t severity, const char * message)
        switch (severity)
            case SD_RPC_LOG_ERROR:
                printf("Error: %s\n", message);
                fflush(stdout);
            case SD_RPC_LOG_WARNING:
                printf("Warning: %s\n", message);
                fflush(stdout);
            case SD_RPC_LOG_INFO:
                printf("Info: %s\n", message);
                fflush(stdout);
                printf("Log: %s\n", message);
                fflush(stdout);
    /**@brief Function called on BLE_GAP_EVT_CONNECTED event.
     * @details Update connection state and proceed to discovering the peer's GATT services.
     * @param[in] p_ble_gap_evt GAP event.
    static void on_connected(const ble_gap_evt_t * const p_ble_gap_evt)
        printf("Connection established\n");
        fflush(stdout);
        m_connected_devices++;
        m_connection_handle = p_ble_gap_evt->conn_handle;
    /**@brief Function called on BLE_GAP_EVT_ADV_REPORT event.
     * @details Create a connection if received advertising packet corresponds to desired BLE device.
     * @param[in] p_ble_gap_evt Advertising Report Event.
    static void on_adv_report(const ble_gap_evt_t * const p_ble_gap_evt)
        uint32_t err_code;
        uint8_t  str[STRING_BUFFER_SIZE] = {0};
        // Log the Bluetooth device address of advertisement packet received.
        ble_address_to_string_convert(p_ble_gap_evt->params.adv_report.peer_addr, str);
        printf("Received advertisement report with device address: 0x%s\n", str);
        fflush(stdout);
        if (find_adv_name(&p_ble_gap_evt->params.adv_report, TARGET_DEV_NAME))
            if (m_connected_devices >= MAX_PEER_COUNT || m_connection_is_in_progress)
                return;
            err_code = sd_ble_gap_connect(m_adapter,
                                          &(p_ble_gap_evt->params.adv_report.peer_addr),
                                          &m_scan_param,
                                          &m_connection_param);
            if (err_code != NRF_SUCCESS)
                printf("Connection Request Failed, reason %d\n", err_code);
                fflush(stdout);
                return;
            m_connection_is_in_progress = true;
    /**@brief Function called on BLE_GAP_EVT_TIMEOUT event.
     * @param[in] ble_gap_evt_t Timeout Event.
    static void on_timeout(const ble_gap_evt_t * const p_ble_gap_evt)
        if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
        else if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
            scan_start();
    /**@brief Function called on BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event.
     * @details Update service state and proceed to discovering the service's GATT characteristics.
     * @param[in] p_ble_gattc_evt Primary Service Discovery Response Event.
    static void on_service_discovery_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
        int count;
        int service_index;
        const ble_gattc_service_t * service;
        printf("Received service discovery response\n");
        fflush(stdout);
        if (p_ble_gattc_evt->gatt_status != NRF_SUCCESS)
            printf("Service discovery failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
            fflush(stdout);
            return;
        count = p_ble_gattc_evt->params.prim_srvc_disc_rsp.count;
        if (count == 0)
            printf("Service not found\n");
            fflush(stdout);
            return;
        if (count > 1)
            printf("Warning, discovered multiple primary services. Ignoring all but the first\n");
        service_index = 0; /* We expect to discover only the Heart Rate service as requested. */
        service = &(p_ble_gattc_evt->params.prim_srvc_disc_rsp.services[service_index]);
        if (service->uuid.uuid != BLE_UUID_NUS_SERVICE)
            printf("Unknown service discovered with UUID: 0x%04X\n", service->uuid.uuid);
            fflush(stdout);
            return;
        m_service_start_handle  = service->handle_range.start_handle;
        m_service_end_handle    = service->handle_range.end_handle;
        printf("Discovered heart rate service. UUID: 0x%04X, "
                       "start handle: 0x%04X, end handle: 0x%04X\n",
            service->uuid.uuid, m_service_start_handle, m_service_end_handle);
        fflush(stdout);
    /**@brief Function called on BLE_GATTC_EVT_CHAR_DISC_RSP event.
     * @details Update characteristic state and proceed to discovering the characteristicss descriptors.
     * @param[in] p_ble_gattc_evt Characteristic Discovery Response Event.
    static void on_characteristic_discovery_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
        int count = p_ble_gattc_evt->params.char_disc_rsp.count;
        if (p_ble_gattc_evt->gatt_status == BLE_GATT_STATUS_ATTERR_ATTRIBUTE_NOT_FOUND)
            return;
        else if (p_ble_gattc_evt->gatt_status != NRF_SUCCESS)
            printf("Characteristic discovery failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
            fflush(stdout);
            return;
        printf("Received characteristic discovery response, characteristics count: %d\n", count);
        fflush(stdout);
        for (int i = 0; i < count; i++)
            printf("Characteristic handle: 0x%04X, UUID: 0x%04X\n",
                   p_ble_gattc_evt->params.char_disc_rsp.chars[i].handle_decl,
                   p_ble_gattc_evt->params.char_disc_rsp.chars[i].uuid.uuid);
            fflush(stdout);
            if (p_ble_gattc_evt->params.char_disc_rsp.chars[i].uuid.uuid ==
                BLE_UUID_NUS_RX_CHARACTERISTIC)
                m_nus_rx_handle = p_ble_gattc_evt->params.char_disc_rsp.chars[i].handle_decl;
            else if (p_ble_gattc_evt->params.char_disc_rsp.chars[i].uuid.uuid ==
                     BLE_UUID_NUS_TX_CHARACTERISTIC)
                m_nus_tx_handle = p_ble_gattc_evt->params.char_disc_rsp.chars[i].handle_decl;
        m_service_start_handle += 2;
        //descr_discovery_start();
    /**@brief Function called on BLE_GATTC_EVT_DESC_DISC_RSP event.
     * @details Update CCCD descriptor state and proceed to prompting user to toggle notifications.
     * @param[in] p_ble_gattc_evt Descriptor Discovery Response Event.
    static void on_descriptor_discovery_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
        int count = p_ble_gattc_evt->params.desc_disc_rsp.count;
            printf("Descriptor discovery failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
            fflush(stdout);
            return;
        printf("Received descriptor discovery response, descriptor count: %d\n", count);
        fflush(stdout);
            printf("Descriptor handle: 0x%04X, UUID: 0x%04X\n",
                   p_ble_gattc_evt->params.desc_disc_rsp.descs[i].handle,
                   p_ble_gattc_evt->params.desc_disc_rsp.descs[i].uuid.uuid);
            fflush(stdout);
            if (p_ble_gattc_evt->params.desc_disc_rsp.descs[i].uuid.uuid == BLE_UUID_CCCD)
                m_nus_tx_cccd_handle = p_ble_gattc_evt->params.desc_disc_rsp.descs[i].handle;
                printf("Press enter to toggle notifications on the HRM characteristic\n");
                fflush(stdout);
                m_service_start_handle++;
    /**@brief Function called on BLE_GATTC_EVT_WRITE_RSP event.
     * @param[in] p_ble_gattc_evt Write Response Event.
    static void on_write_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
        printf("Received write response.\n");
        fflush(stdout);
            printf("Error. Write operation failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
            fflush(stdout);
    /**@brief Function called on BLE_GATTC_EVT_HVX event.
     * @details Logs the received heart rate measurement.
     * @param[in] p_ble_gattc_evt Handle Value Notification/Indication Event.
    static void on_hvx(const ble_gattc_evt_t * const p_ble_gattc_evt)
        printf("Received notification\n");
    #if 0
        if (p_ble_gattc_evt->params.hvx.handle >= m_nus_tx_handle ||
                p_ble_gattc_evt->params.hvx.handle <= m_nus_tx_cccd_handle) // Heart rate measurement.
            // We know the heart rate reading is encoded as 2 bytes [flag, value].
            printf("Received heart rate measurement: %d\n", p_ble_gattc_evt->params.hvx.data[1]);
        else // Unknown data.
            printf("Un-parsed data received on handle: %04X\n", p_ble_gattc_evt->params.hvx.handle);
        fflush(stdout);
    /**@brief Function called on BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST event.
     * @details Update GAP connection parameters.
     * @param[in] p_ble_gap_evt Connection Parameter Update Event.
    static void on_conn_params_update_request(const ble_gap_evt_t * const p_ble_gap_evt)
        uint32_t err_code = sd_ble_gap_conn_param_update(m_adapter, m_connection_handle,
                                                &(p_ble_gap_evt->
                                                        params.conn_param_update_request.conn_params));
            printf("Conn params update failed, err_code %d\n", err_code);
            fflush(stdout);
    /**@brief Function called on BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event.
     * @details Replies to an ATT_MTU exchange request by sending an Exchange MTU Response to the client.
     * @param[in] p_ble_gatts_evt Exchange MTU Request Event.
    static void on_exchange_mtu_request(const ble_gatts_evt_t * const p_ble_gatts_evt)
        uint32_t err_code = sd_ble_gatts_exchange_mtu_reply(m_adapter, m_connection_handle,
                                                            GATT_MTU_SIZE_DEFAULT);
            printf("MTU exchange request reply failed, err_code %d\n", err_code);
            fflush(stdout);
    /**@brief Function called on BLE_GATTC_EVT_EXCHANGE_MTU_RSP event.
     * @details Logs the new BLE server RX MTU size.
     * @param[in] p_ble_gattc_evt Exchange MTU Response Event.
    static void on_exchange_mtu_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
        uint16_t server_rx_mtu = p_ble_gattc_evt->params.exchange_mtu_rsp.server_rx_mtu;
        printf("MTU response received. New ATT_MTU is %d\n", server_rx_mtu);
        fflush(stdout);
    /**@brief Function for initializing serial communication with the target nRF5 Bluetooth slave.
     * @param[in] serial_port The serial port the target nRF5 device is connected to.
     * @return The new transport adapter.
    static adapter_t * adapter_init(char * serial_port)
        physical_layer_t  * phy;
        data_link_layer_t * data_link_layer;
        transport_layer_t * transport_layer;
        phy = sd_rpc_physical_layer_create_uart(serial_port, BAUD_RATE, SD_RPC_FLOW_CONTROL_NONE,
                                                SD_RPC_PARITY_NONE);
        data_link_layer = sd_rpc_data_link_layer_create_bt_three_wire(phy, 100);
        transport_layer = sd_rpc_transport_layer_create(data_link_layer, 100);
        return sd_rpc_adapter_create(transport_layer);
    /**@brief Function for converting a BLE address to a string.
     * @param[in] address       Bluetooth Low Energy address.
     * @param[out] string_buffer The serial port the target nRF5 device is connected to.
        const int address_length = 6;
        char      temp_str[3];
        for (int i = address_length - 1; i >= 0; --i)
            sprintf(temp_str, "%02X", address.addr[i]);
            strcat((char *)string_buffer, temp_str);
     * @brief Parses advertisement data, providing length and location of the field in case
     *        matching data is found.
     * @param[in]  Type of data to be looked for in advertisement data.
     * @param[in]  Advertisement report length and pointer to report.
     * @param[out] If data type requested is found in the data report, type data length and
     *             pointer to data will be populated here.
     * @retval NRF_SUCCESS if the data type is found in the report.
     * @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
        uint32_t  index = 0;
        uint8_t * p_data;
        p_data = p_advdata->p_data;
        while (index < p_advdata->data_len)
            uint8_t field_length = p_data[index];
            uint8_t field_type   = p_data[index + 1];
            if (field_type == type)
                p_typedata->p_data   = &p_data[index + 2];
                p_typedata->data_len = field_length - 1;
                return NRF_SUCCESS;
            index += field_length + 1;
        return NRF_ERROR_NOT_FOUND;
    /**@brief Function for searching a given name in the advertisement packets.
     * @details Use this function to parse received advertising data and to find a given
     * name in them either as 'complete_local_name' or as 'short_local_name'.
     * @param[in]   p_adv_report   advertising data to parse.
     * @param[in]   name_to_find   name to search.
     * @return   true if the given name was found, false otherwise.
        uint32_t err_code;
        data_t   adv_data;
        data_t   dev_name;
        // Initialize advertisement report for parsing
        adv_data.p_data     = (uint8_t *)p_adv_report->data;
        adv_data.data_len   = p_adv_report->dlen;
        //search for advertising names
        err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME,
                                    &adv_data,
                                    &dev_name);
        if (err_code == NRF_SUCCESS)
            if (memcmp(name_to_find, dev_name.p_data, dev_name.data_len )== 0)
                return true;
            // Look for the short local name if it was not found as complete
            err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME,
                                        &adv_data,
                                        &dev_name);
                return false;
                return true;
        return false;
     * @return NRF_SUCCESS on success, otherwise an error code.
        uint32_t            err_code;
        ble_enable_params_t ble_enable_params;
        uint32_t *          app_ram_base = NULL;
        memset(&ble_enable_params, 0, sizeof(ble_enable_params));
        ble_enable_params.gatt_enable_params.att_mtu = GATT_MTU_SIZE_DEFAULT;
        ble_enable_params.gatts_enable_params.attr_tab_size     = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
        ble_enable_params.gatts_enable_params.service_changed   = false;
        ble_enable_params.gap_enable_params.periph_conn_count   = 1;
        ble_enable_params.gap_enable_params.central_conn_count  = 1;
        ble_enable_params.gap_enable_params.central_sec_count   = 1;
        ble_enable_params.common_enable_params.p_conn_bw_counts = NULL;
        ble_enable_params.common_enable_params.vs_uuid_count    = 1;
        err_code = sd_ble_enable(m_adapter, &ble_enable_params, app_ram_base);
        switch (err_code) {
            case NRF_SUCCESS:
            case NRF_ERROR_INVALID_STATE:
                printf("BLE stack already enabled\n");
                fflush(stdout);
                printf("Failed to enable BLE stack. Error code: %d\n", err_code);
                fflush(stdout);
        return err_code;
    /**@brief Set BLE option for the BLE role and connection bandwidth.
     * @return NRF_SUCCESS on option set successfully, otherwise an error code.
    static uint32_t ble_options_set()
        ble_opt_t        opt;
        ble_common_opt_t common_opt;
        common_opt.conn_bw.role = BLE_GAP_ROLE_CENTRAL;
        common_opt.conn_bw.conn_bw.conn_bw_rx = BLE_CONN_BW_HIGH;
        common_opt.conn_bw.conn_bw.conn_bw_tx = BLE_CONN_BW_HIGH;
        opt.common_opt = common_opt;
        return sd_ble_opt_set(m_adapter, BLE_COMMON_OPT_CONN_BW, &opt);
    /**@brief Start scanning (GAP Discovery procedure, Observer Procedure).
     * @return NRF_SUCCESS on successfully initiating scanning procedure, otherwise an error code.
        uint32_t      error_code;
        ble_uuid128_t nus_base_uuid = NUS_BASE_UUID;
        uint8_t       uuid_type;
        error_code = sd_ble_uuid_vs_add(m_adapter, &nus_base_uuid, &uuid_type);
        if (error_code != NRF_SUCCESS)
            printf("failed to add uuid base\n");
        error_code = sd_ble_gap_scan_start(m_adapter, &m_scan_param);
            printf("Scan start failed\n");
            fflush(stdout);
        } else
            printf("Scan started\n");
            fflush(stdout);
        return error_code;
    /**@brief Function called upon connecting to BLE peripheral.
     * @details Initiates primary service discovery.
        uint32_t   err_code;
        uint16_t   start_handle = 0x01;
        ble_uuid_t srvc_uuid;
        printf("Discovering primary services\n");
        fflush(stdout);
        srvc_uuid.type = BLE_UUID_TYPE_VENDOR_BEGIN;
        srvc_uuid.uuid = BLE_UUID_NUS_SERVICE;
        // Initiate procedure to find the primary BLE_UUID_NUS_SERVICE.
        err_code = sd_ble_gattc_primary_services_discover(m_adapter,
                                                          m_connection_handle, start_handle,
                                                          &srvc_uuid);
            printf("Failed to initiate or continue a GATT Primary Service Discovery procedure\n");
            fflush(stdout);
        return err_code;
    /**@brief Function called upon discovering a BLE peripheral's primary service(s).
     * @details Initiates service's (m_service) characteristic discovery.
        ble_gattc_handle_range_t handle_range;
        printf("Discovering characteristics\n");
        fflush(stdout);
        handle_range.start_handle = m_service_start_handle;
        handle_range.end_handle = m_service_end_handle;
        printf("m_service_start_handle: %d\n",m_service_start_handle);
        printf("m_service_end_handle: %d\n",m_service_end_handle);
        fflush(stdout);
        return sd_ble_gattc_characteristics_discover(m_adapter, m_connection_handle, &handle_range);
    /**@brief Function called upon discovering service's characteristics.
     * @details Initiates heart rate monitor (m_nus_rx_handle) characteristic's descriptor discovery.
        printf("Discovering characteristic's descriptors\n");
        fflush(stdout);
        if (m_nus_rx_handle == 0)
            printf("No heart rate measurement characteristic handle found\n");
            fflush(stdout);
        return sd_ble_gattc_descriptors_discover(m_adapter, m_connection_handle, &handle_range);
    /**@brief Function that write's the HRM characteristic's CCCD.
        ble_gattc_write_params_t write_params;
        uint8_t                  cccd_value[2] = {value, 0};
        printf("Setting HRM CCCD\n");
        fflush(stdout);
        if (m_nus_tx_cccd_handle == 0)
            printf("Error. No CCCD handle has been found\n");
            fflush(stdout);
        write_params.handle = m_nus_tx_cccd_handle;
        write_params.len = 2;
        write_params.p_value = cccd_value;
        write_params.write_op = BLE_GATT_OP_WRITE_REQ;
        write_params.offset = 0;
        return sd_ble_gattc_write(m_adapter, m_connection_handle, &write_params);
    /**@brief Function for handling the Application's BLE Stack events.
     * @param[in] p_ble_evt Bluetooth stack event.
    static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
        if (p_ble_evt == NULL)
            printf("Received an empty BLE event\n");
            fflush(stdout);
            return;
            case BLE_GAP_EVT_CONNECTED:
                on_connected(&(p_ble_evt->evt.gap_evt));
                printf("Disconnected, reason: 0x%02X\n",
                       p_ble_evt->evt.gap_evt.params.disconnected.reason);
                fflush(stdout);
                m_connected_devices--;
            case BLE_GAP_EVT_ADV_REPORT:
                on_adv_report(&(p_ble_evt->evt.gap_evt));
            case BLE_GAP_EVT_TIMEOUT:
                on_timeout(&(p_ble_evt->evt.gap_evt));
            case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
                on_service_discovery_response(&(p_ble_evt->evt.gattc_evt));
            case BLE_GATTC_EVT_CHAR_DISC_RSP:
                on_characteristic_discovery_response(&(p_ble_evt->evt.gattc_evt));
            case BLE_GATTC_EVT_DESC_DISC_RSP:
                on_descriptor_discovery_response(&(p_ble_evt->evt.gattc_evt));
            case BLE_GATTC_EVT_WRITE_RSP:
                on_write_response(&(p_ble_evt->evt.gattc_evt));
            case BLE_GATTC_EVT_HVX:
                on_hvx(&(p_ble_evt->evt.gattc_evt));
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                on_conn_params_update_request(&(p_ble_evt->evt.gap_evt));
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                on_exchange_mtu_request(&(p_ble_evt->evt.gatts_evt));
            case BLE_GATTC_EVT_EXCHANGE_MTU_RSP:
                on_exchange_mtu_response(&(p_ble_evt->evt.gattc_evt));
                printf("Received an un-handled event with ID: %d\n", p_ble_evt->header.evt_id);
                fflush(stdout);
    /**@brief Function for application main entry.
     * @param[in] argc Number of arguments (program expects 0 or 1 arguments).
     * @param[in] argv The serial port of the target nRF5 device (Optional).
    int main(int argc, char * argv[])
        char *   serial_port;
        uint8_t  cccd_value = 0;
        if (argc > 1)
            serial_port = argv[1];
            serial_port = UART_PORT_NAME;
        printf("Serial port used: %s\n", serial_port);
        fflush(stdout);
        m_adapter =  adapter_init(serial_port);
        sd_rpc_log_handler_severity_filter_set(m_adapter, SD_RPC_LOG_INFO);
        error_code = sd_rpc_open(m_adapter, status_handler, ble_evt_dispatch, log_handler);
            printf("Failed to open nRF BLE Driver. Error code: 0x%02X\n", error_code);
            fflush(stdout);
            return error_code;
        error_code = ble_stack_init();
            return error_code;
        error_code = ble_options_set();
            return error_code;
        error_code = scan_start();
            return error_code;
        // Endlessly loop.
        for (; ;)
            char c = (char)getchar();
            if (c == 'q' || c == 'Q')
                error_code = sd_ble_gap_scan_stop(m_adapter);
                    printf("Failed to stop scanning. Error code: 0x%02X\n", error_code);
                    fflush(stdout);
                error_code = sd_rpc_close(m_adapter);
                    printf("Failed to close nRF BLE Driver. Error code: 0x%02X\n", error_code);
                    fflush(stdout);
                    return error_code;
                printf("Closed\n");
                fflush(stdout);
                return NRF_SUCCESS;
            // Toggle notifications on the HRM characteristic every time user input is received.
            cccd_value ^= BLE_CCCD_NOTIFY;
            hrm_cccd_set(cccd_value);
  • Thank you, your code helped me fix my problem. I had initially assumed that calling the characteristic discovery function once would be enough. I also noticed that your code and pc_ble_driver_py both use the API version 3. Which branch of the pc_ble_driver should I use to get the API version 3?? Even the branch v3 contains sd_ap_v2 and sd_api_v5 in the hex folder. My end aim is to get NUS central and DFU working, so which API version should I use and which branch should I get it from?
    FYI, I am currently using sd_api_v5 from the master branch of pc_ble_driver
