Radio Transmitter Example
1. How should I connect with UART to my board?
2. How to put the device into RX mode as required by RED EN300328?
Test the Radio Test Example application by performing the following steps:
  1. Compile and program the application.
  2. Start a terminal emulator like PuTTY and connect to the used COM port with the following UART settings:
    • Baud rate: 115.200
    • 8 data bits
    • 1 stop bit
    • No parity
    • HW flow control: None
  3. The text "RF Test" should appear at the top of the terminal.
  4. Type any of the letters described above. An output text should be displayed in the PUTTY window, or a sweep or signal should be started.
  5. Use a spectrum analyzer to confirm the behavior of the radio module.
  • Do you have an example for it?
    how can I change the pins setup?
    No, we do not have an example for how to change UART pins.
    1. Download SDK v.15.0
    2. Open project of DTM example for whatever IDE you have available. SES can be downloaded for free through Segger.
    3. Browse and open 'PCA10056.h', (through 'boards.h' if needed) and change code lines 87-90 to whatever GPIO number you want to use
    #define RX_PIN_NUMBER  8
    #define TX_PIN_NUMBER  6
    #define CTS_PIN_NUMBER 7
    #define RTS_PIN_NUMBER 5
    Build, flash and you are good to go.
    Andreas
  • On this system, I should have
    1. EVB- NRF52- should act like mater to send data
    2. My PCB- which should receive the commands
    Should I burn the same FW on both?
    Is there a simple document which describes the block diagram and the FW for each part??
    The information is not clear nor setup...
    this test should be done by any customer ..
    In order to use the python PER script linked below, both boards should be loaded with the DTM application. If you load the DK with the exact same hex file as yo udo with your DUT, remember that the UART pins will also change. The nRF52 on the DK will then not have its UART connected to the pins(lines) that go to the interface MCU, which it needs to get commands to/from the PC.
    We do not have any documents or similar on basic UART, but this is freely available at a number of sources, e.g. this by Sparkfun. There has not been a demand for anything this elaborate from us directly, and there is a lot of assistance to be found through previously answered DevZone queries.
    An attempt to break it down
    Tester (nRF52 on DK), no change needed. just flash it with the pre-compiled DTM application:
    DK-side nRF52 side
    TXD (P0.08) RXD (P0.08)
    RXD (P0.06) TXD(P0.06)
    CTS (not needed)
    RTS (not needed)
    DUT (Custom device):
    DK-Side nRF52 side
    TXD (P0.08) RXD (whatever you set it to)
    RXD (P0.06) TXD (whatever you set it to)
    CTS (not needed) Not needed
    RTS (not needed) Not needed
    Andreas
