SPI MISO buffer doesn't fill
I am using an nRF52840PDK (master) to use an SPI peripheral, where my code is based on examples\peripheral\spi. My IDE is Segger Embedded Studio and I am using SDK 15.0.0. I am using an oscilloscope to visualize the SPI bus activity.
I start of by configuring the SPI peripheral hardware on the nRF52840. Afterwards I write my configurations into the external peripheral registers over SPI. All of this works as expected.
Following is my problem:
I am trying to read from one of the registers. To do this I write my command byte and want to read 2 bytes (1 status & 1 data). I can see both MOSI and MISO lines reflect the correct data with the oscilloscope. The data does however not seem to be getting loaded into the receive buffer.
Using the debugger I can see being stuck in an endless loop (peripheral.c, register_read(), thus the spi_event_handler is not called to set spi_transfer_done = true. My first suspicion was my event_handler pointer. This works during writing so should also work during reading. Using a watch on the rx_buffer shows me that it is not being filled.
Below this is are scope images and my relevant code. At the very bottom is the concrete question.
Both of the devices are in SPI mode 0.
Yellow = MOSI - blue = MISO - grey line = SCLK 2 periods (external trigger edited in manually)      ----      The first MISO byte is a status byte and discarded, second byte is data
Image writing register 17:
 MOSI [command,  data] - MISO [status]
Image reading register 17:
 MOSI[command] - MISO[status, data]
main.c:
static const nrf_drv_spi_t peripheral = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);       /**< SPI instance */
const nrf_drv_spi_t *p_spi_instance = &peripheral;
static volatile bool spi_xfer_done;                                             /**< Flag used to indicate that SPI instance completed the transfer */
extern void *p_spi_event_handler;
void spi_config(void)
  nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
  spi_config.sck_pin  = SPI_SCK_PIN;
  spi_config.miso_pin = SPI_MISO_PIN;
  spi_config.mosi_pin = SPI_MOSI_PIN;
  spi_config.ss_pin = SPI_SS_PIN != NRF_DRV_SPI_PIN_NOT_USED ? SPI_SS_PIN : NRF_DRV_SPI_PIN_NOT_USED;
  APP_ERROR_CHECK(nrf_drv_spi_init(p_spi_instance, &spi_config, p_spi_event_handler, NULL));
    //SPI configuration
    spi_config();
    //Peripheral initialization
    peripheral_init(&spi_xfer_done);
    // Enter main loop.
    for (;;)
        idle_state_handle();
peripheral.h:
#ifndef PERIPHERAL_H__
#define PERIPHERAL_H__
#include "nrf_drv_spi.h"
extern const nrf_drv_spi_t *p_spi_instance;                                      /**< Pointer to SPI instance */
#endif  //PERIPHERAL_H__
peripheral.c:
#include "peripheral.h"
#include "nrf_gpio.h"
#include "nrf_log.h"
#include <stdint.h>
static volatile bool *p_spi_xfer_done;                                           /**< Pointer to SPI_xfer_done flag */
static uint8_t m_tx_buf[2] = {};                                                /**< TX buffer */
static uint8_t m_rx_buf[sizeof(m_tx_buf) + 1];                                  /**< RX buffer */
static const int8_t tx_length = sizeof(m_tx_buf);                               /**< Transfer length */
static const int8_t rx_length = sizeof(m_rx_buf);                               /**< Transfer length */
/**@brief Reads data from a register
static void register_read(peripheral_registers_t register_to_access, int rx_length)
  peripheral_result_codes_t result;
  uint8_t command;
  memset(m_tx_buf, 0, tx_length);
  memset(m_rx_buf, 0, rx_length);
  *p_spi_xfer_done = false;
  m_tx_buf[0] = command_byte_set(register_to_access, read);    //Left shift 3 & set 2nd bit 0
  APP_ERROR_CHECK(nrf_drv_spi_transfer(p_spi_instance, m_tx_buf, 1, m_rx_buf, rx_length + 1));      //p_spi_instance = 0x0003be04
  while (!*p_spi_xfer_done)     //I get into an endless loop here
    __WFE();
/**@brief Writes data to a register
static void register_write(peripheral_registers_t register_to_access, uint8_t data, int tx_length)
  uint8_t command;
  m_tx_buf[0] = command_byte_set(register_to_access, write);    //Left shift 3 & set 2nd bit 1
  m_tx_buf[1] = data;         //append data to buffer
  APP_ERROR_CHECK(nrf_drv_spi_transfer(p_spi_instance, m_tx_buf, tx_length + 1, m_rx_buf, 1));
    __WFE();
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    *p_spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
void (*p_spi_event_handler) = &spi_event_handler;       //Function pointer declared in main.c
/**@brief Initialize peripheral at startup
void peripheral_init(volatile bool *spi_xfer_done)
  p_spi_xfer_done = spi_xfer_done;
  register_init(17, 0, 0, 0, 1, 1, 0, 1, 0);        //creates byte with configuration value and calls register_write
static void register_init(peripheral_registers_t register_to_access,
                     uint8_t bit_value7,
                     uint8_t bit_value6,
                     uint8_t bit_value5,
                     uint8_t bit_value4,
                     uint8_t bit_value3,
                     uint8_t bit_value2,
                     uint8_t bit_value1,
                     uint8_t bit_value0)
  uint8_t register_value = 0;
  uint8_t bit_value_array[8] = {bit_value0, bit_value1, bit_value2, bit_value3, bit_value4, bit_value5, bit_value6, bit_value7};   //Array and binary MSB/LSB are reverse in order!
  for(int8_t bit_shift = 7; bit_shift >= 0; bit_shift--)
    //Shift configuration bit into the right place of the register value
    register_value |= shift_bit(register_value, bit_value_array[bit_shift], bit_shift);
  register_write(register_to_access, register_value, 1);
/**@brief Read register 17 on button press
void peripheral_read_17(void)
  uint8_t result;
  register_read(17, 1);
Regarding the SPI mode: the nRF52840 is in mode0 (SCK active high, sample on leading edge of clock) while the documentation of my peripheral reads:
"[...] These signals are represented in the form (CPOL, CPHA). An
interface that expects both positive edge SCKS and the MOSI data to be available before the first
positive clock edge, can operate in modes (0,0) and (1,1) without alteration. […]"
My question is: Why am I getting stuck in this endless loop and how can I fix it?
Thank you in advance (this is quite long),
Kevin
Edit: Corrected image discription
P.s.: I think there is a bug where I can't upload, remove, then reupload a different image with the same name. It will then show the first image again in the editor.
  • I have a question considering the SPIM peripheral. There are 2 examples, namely \examples\peripheral\spi and \examples\peripheral\nrfx_spim. According to the SDK documentation both (can) use SPIM, they are considerably different in their setup however. Can it be as easy as changing sdk_config.h to use NRFX_SPIM3_ENABLED instead of SPI0_ENABLED?
    Which should I be using, assuming I only want to transmit data without special interactions?
  • I suggest you use the SPI Master Example or SPI Transaction Manager Example, and use SPIM0-2 as the instance. SPIM3 is the Quad SPI peripheral.
  • Hello again, sorry for the delay as I've had a week off.
    I have looked into using the SPIM peripheral and the examples. Specifically the SPI Master example as I have been using this from the start. It seems to me as if this uses the SPI peripheral making use of the older nrf driver. Is this correct?
    It seems to me as to use SPIM I should also make sure I use the nrfx driver. To ensure this I have been commenting the legacy layer SPI  configurations in sdk_config.h out. Is this the right way to go?
    Lastly, should I create the SPI instance as in the SPI master example (NRF_DRV_SPI_INSTANCE() macro) or the nrfx version? I guess this ties into my other questions.
    Is there anything I should specifically watch for to transition to SPIM?
    Edit: I think the best question would be: Can you link the api reference from the infocenter of the SPIM master driver I should be using (e.g. this)?
  • Use nrfx_spim_init and nrfx_spim_xfer
    "To ensure this I have been commenting the legacy layer SPI  configurations in sdk_config.h out. Is this the right way to go?"
    -No, not really. You should leave it as is, and enable the SPI instance in the legacy layer SPI of sdk_config.h, I believe the nrfx driver has an #ifdef or two that requires it.
    "Lastly, should I create the SPI instance as in the SPI master example (NRF_DRV_SPI_INSTANCE() macro) or the nrfx version?"
    - Yes.
    I suggest you try this out and verify the implementation by reading the SPIM registers before and after you've called nrfx_spim_xfer (debug session). That way you can see if the SPIM peripheral is set up correctly, and what might be missing, like enabled interrupts, clk frequency, CPOL/CPHA config, RXD/TXD pointers, etc.
  • Thank you for your clear response, but I have not managed to solve it completely yet. The received data now properly reflect in the receive buffer. Despite this I'm still stuck in the infinite loop in register_read().
    I have changed everything SPI related to use the SPIM driver. With this I have had nrf_drv_spi enabled and also disabled (and commented out). I do not see any difference in behaviour between these two. I have also used regular SPI, which yields the same result.
    This infinite loop only occurs when I trigger a transfer by pressing a button. Any transfer started in main(), whether for configuration or repeatedly reading a register, works perfectly normal. I don't have any timers running anymore to eliminate possibly disruptive sources, so the only difference I can think of is having the button or not. Note that the softdevice is running in every scenario.
    Is there anything else I could try, or is it not possible to have an SPI transaction being triggered by a button?
