SPI MISO buffer doesn't fill
I am using an nRF52840PDK (master) to use an SPI peripheral, where my code is based on examples\peripheral\spi. My IDE is Segger Embedded Studio and I am using SDK 15.0.0. I am using an oscilloscope to visualize the SPI bus activity.
I start of by configuring the SPI peripheral hardware on the nRF52840. Afterwards I write my configurations into the external peripheral registers over SPI. All of this works as expected.
Following is my problem:
I am trying to read from one of the registers. To do this I write my command byte and want to read 2 bytes (1 status & 1 data). I can see both MOSI and MISO lines reflect the correct data with the oscilloscope. The data does however not seem to be getting loaded into the receive buffer.
Using the debugger I can see being stuck in an endless loop (peripheral.c, register_read(), thus the spi_event_handler is not called to set spi_transfer_done = true. My first suspicion was my event_handler pointer. This works during writing so should also work during reading. Using a watch on the rx_buffer shows me that it is not being filled.
Below this is are scope images and my relevant code. At the very bottom is the concrete question.
Both of the devices are in SPI mode 0.
Yellow = MOSI - blue = MISO - grey line = SCLK 2 periods (external trigger edited in manually)      ----      The first MISO byte is a status byte and discarded, second byte is data
Image writing register 17:
 MOSI [command,  data] - MISO [status]
Image reading register 17:
 MOSI[command] - MISO[status, data]
main.c:
static const nrf_drv_spi_t peripheral = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);       /**< SPI instance */
const nrf_drv_spi_t *p_spi_instance = &peripheral;
static volatile bool spi_xfer_done;                                             /**< Flag used to indicate that SPI instance completed the transfer */
extern void *p_spi_event_handler;
void spi_config(void)
  nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
  spi_config.sck_pin  = SPI_SCK_PIN;
  spi_config.miso_pin = SPI_MISO_PIN;
  spi_config.mosi_pin = SPI_MOSI_PIN;
  spi_config.ss_pin = SPI_SS_PIN != NRF_DRV_SPI_PIN_NOT_USED ? SPI_SS_PIN : NRF_DRV_SPI_PIN_NOT_USED;
  APP_ERROR_CHECK(nrf_drv_spi_init(p_spi_instance, &spi_config, p_spi_event_handler, NULL));
    //SPI configuration
    spi_config();
    //Peripheral initialization
    peripheral_init(&spi_xfer_done);
    // Enter main loop.
    for (;;)
        idle_state_handle();
peripheral.h:
#ifndef PERIPHERAL_H__
#define PERIPHERAL_H__
#include "nrf_drv_spi.h"
extern const nrf_drv_spi_t *p_spi_instance;                                      /**< Pointer to SPI instance */
#endif  //PERIPHERAL_H__
peripheral.c:
#include "peripheral.h"
#include "nrf_gpio.h"
#include "nrf_log.h"
#include <stdint.h>
static volatile bool *p_spi_xfer_done;                                           /**< Pointer to SPI_xfer_done flag */
static uint8_t m_tx_buf[2] = {};                                                /**< TX buffer */
static uint8_t m_rx_buf[sizeof(m_tx_buf) + 1];                                  /**< RX buffer */
static const int8_t tx_length = sizeof(m_tx_buf);                               /**< Transfer length */
static const int8_t rx_length = sizeof(m_rx_buf);                               /**< Transfer length */
/**@brief Reads data from a register
static void register_read(peripheral_registers_t register_to_access, int rx_length)
  peripheral_result_codes_t result;
  uint8_t command;
  memset(m_tx_buf, 0, tx_length);
  memset(m_rx_buf, 0, rx_length);
  *p_spi_xfer_done = false;
  m_tx_buf[0] = command_byte_set(register_to_access, read);    //Left shift 3 & set 2nd bit 0
  APP_ERROR_CHECK(nrf_drv_spi_transfer(p_spi_instance, m_tx_buf, 1, m_rx_buf, rx_length + 1));      //p_spi_instance = 0x0003be04
  while (!*p_spi_xfer_done)     //I get into an endless loop here
    __WFE();
/**@brief Writes data to a register
static void register_write(peripheral_registers_t register_to_access, uint8_t data, int tx_length)
  uint8_t command;
  m_tx_buf[0] = command_byte_set(register_to_access, write);    //Left shift 3 & set 2nd bit 1
  m_tx_buf[1] = data;         //append data to buffer
  APP_ERROR_CHECK(nrf_drv_spi_transfer(p_spi_instance, m_tx_buf, tx_length + 1, m_rx_buf, 1));
    __WFE();
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    *p_spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
void (*p_spi_event_handler) = &spi_event_handler;       //Function pointer declared in main.c
/**@brief Initialize peripheral at startup
void peripheral_init(volatile bool *spi_xfer_done)
  p_spi_xfer_done = spi_xfer_done;
  register_init(17, 0, 0, 0, 1, 1, 0, 1, 0);        //creates byte with configuration value and calls register_write
static void register_init(peripheral_registers_t register_to_access,
                     uint8_t bit_value7,
                     uint8_t bit_value6,
                     uint8_t bit_value5,
                     uint8_t bit_value4,
                     uint8_t bit_value3,
                     uint8_t bit_value2,
                     uint8_t bit_value1,
                     uint8_t bit_value0)
  uint8_t register_value = 0;
  uint8_t bit_value_array[8] = {bit_value0, bit_value1, bit_value2, bit_value3, bit_value4, bit_value5, bit_value6, bit_value7};   //Array and binary MSB/LSB are reverse in order!
  for(int8_t bit_shift = 7; bit_shift >= 0; bit_shift--)
    //Shift configuration bit into the right place of the register value
    register_value |= shift_bit(register_value, bit_value_array[bit_shift], bit_shift);
  register_write(register_to_access, register_value, 1);
/**@brief Read register 17 on button press
void peripheral_read_17(void)
  uint8_t result;
  register_read(17, 1);
Regarding the SPI mode: the nRF52840 is in mode0 (SCK active high, sample on leading edge of clock) while the documentation of my peripheral reads:
"[...] These signals are represented in the form (CPOL, CPHA). An
interface that expects both positive edge SCKS and the MOSI data to be available before the first
positive clock edge, can operate in modes (0,0) and (1,1) without alteration. […]"
My question is: Why am I getting stuck in this endless loop and how can I fix it?
Thank you in advance (this is quite long),
Kevin
Edit: Corrected image discription
P.s.: I think there is a bug where I can't upload, remove, then reupload a different image with the same name. It will then show the first image again in the editor.
  • I suggest you use GPIOTE driver or app_button library instead of the Board Support Library.
    "Should I only set SPI_DEFAULT_CONFIG_IRQ_PRIORITY or also set NRFX_SPIM_DEFAULT_CONFIG_IRQ to a higher priority value, or something different altogether?"
    - I would set both to the same value.
    "Is it correct that GPIOTE_CONFIG_IRQ_PRIORITY is the relevant IRQ for the BSP handler?
    - Yes, I believe so. The BSP uses the app_button library and it uses the GPIOTE peripheral.
    "Include the name of the source and/or header file in the driver/library documentation in the infocenter. This way it's easier to match/find code files to documentation, or the other way around."
    - I agree on this point, right now the library names do not reflect the naming convention used in the SDK.
