I'm using NRF52840 sdk v15 with Softdevice.
I have multiple SPIM instances and I make sure they are never active at the same time.
Can I share the pins (except the CS one) between the instances?
Daniel
Daniel
1. Can I use nrf_spim_csn_configure also with the SPIM driver library to dynamically change the CS?
2. Using the SPIM driver library, I don't need to specify the duration parameter. Can you advise on the best way to determine this parameter?
Daniel
1. Yes, thought not during a transfer.
2. It is given by the Slaves timing specification. I would start with 0 and if that does not work, increase until it does. I suggest you use a digital analyzer during this development.
Thanks again! I did indeed find the min duration for my slaves.
The SPI mode varies among my slaves. Can I also change it (and keep using the driver library)?
Daniel
Yes, with a call to nrf_spim_configure.
This is basically what the spi transaction manager library does. It lets you define different configuration and swap between them, in addition to a basic queuing scheduler.
Thanks!
From the documentation at
Table 3
it seems that our discussion (and especially regarding the CS) applies only to SPIM3 (and not to SPIM0..SPIM2). Am i right?
Thanks again!
Daniel
