Problem with fds: Flash read, write, delete calling that function using android phone.
Hello to all,
I am using nRF52832 DK with sd132, v6.0.0 and sdk 15.0.0, segger embedded studio. We want to achieve change application timer time (APP_TIMER_TICKS(update_time)) using android phone. We have a sensor devices it will wake up as per app timer time defined, we want to change this wake up time using Noridc UART tool box app. For that we are using fds example as referred in given sdk 15.0 and other nRF5-flash-storage-examples .
We are able to flash write read and delete but problem is:
  1.  When i call fds_test_find_and_delete(), fds_test_write(), fds_read() whenever received command from nordic UART app it not able to read and write at this time.
  2. I want to change update_time variable of app timer ticks using android phone and store this time in flash. Whenever want to user need to change this time first delete previous and update latest send time.
  3. Will you please provide me program snippet for How i call flash fds API through android phone and store received time in that app_timer ticks. Confused regarding this.
I am currently using this following functions for FDS read, write, and delete:
static ret_code_t fds_test_write(void)
    //static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
    static uint8_t const m_deadbeef[1] = {0x14};
//    memcpy(m_deadbeef, write_data, sizeof(m_deadbeef));
    fds_record_t        record;
    fds_record_desc_t   record_desc;
    // Set up data.
    // Set up record.
    record.file_id        = FILE_ID_FDS_TEST;
    record.key            = REC_KEY_FDS_TEST;
    record.data.p_data    = &m_deadbeef;
    //record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint32_t);
    record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint8_t);
    ret_code_t ret = fds_record_write(&record_desc, &record);
    if (ret != FDS_SUCCESS)
                    return ret;
     NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
    return NRF_SUCCESS;
static ret_code_t fds_read(void)
    fds_flash_record_t  flash_record;
    fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
    //uint32_t *data;
    uint8_t *data;
    uint32_t err_code;
    NRF_LOG_INFO("Start searching... \r\n");
    // Loop until all records with the given key and file ID have been found.
    while (fds_record_find(FILE_ID_FDS_TEST, REC_KEY_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
                    err_code = fds_record_open(&record_desc, &flash_record);
                    if ( err_code != FDS_SUCCESS)
                            return err_code;
                    NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
                    NRF_LOG_INFO("Data = ");
                    //data = (uint32_t *) flash_record.p_data;
                    data = (uint8_t *) flash_record.p_data;
                    for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
                            NRF_LOG_INFO("0x%8x ",data[i]);
                    NRF_LOG_INFO("\r\n");
                    // Access the record through the flash_record structure.
                    // Close the record when done.
                    err_code = fds_record_close(&record_desc);
                    if (err_code != FDS_SUCCESS)
                            return err_code;
    return NRF_SUCCESS;
static ret_code_t fds_test_find_and_delete (void)
    fds_find_token_t    ftok;
    ftok.page=0;
    ftok.p_addr=NULL;
    // Loop and find records with same ID and rec key and mark them as deleted.
        fds_record_delete(&record_desc);
        NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
    // call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
    ret_code_t ret = fds_gc();
        return ret;
    return NRF_SUCCESS;
  • Thanks for quick response..!!!
    I have made changes as you suggested and error code is 0 means NRF_SUCCESS
    But still same issue.. it continuous in forever loop.
    Any other suggestion please...
  • Do you get the return value NRF_SUCCESS (= 0) from fds_file_delete()? And you are sure that the wait_for_next_delete() function is hit?
    Maybe you get the FDS_EVT_DEL_FILE event with p_fds_evt->result != FDS_SUCCESS? Can you check this?
    Also, can you try to remove the idle_state_handle(); from inside the while loop in the wait_for_next_delete() function?
    Yes I got NRF_SUCESS from fds_file_delete(), and sure bout wait_for_next_delete() function hit.
    I have check by set break point with FDS_EVT_DEL_RECORD and FDS_EVT_DEL_FILE but nothing get.
    this already i have tried.
    This happening only when if used wait_for_next_delete() If I comment this then got all event and also clean flash. Here is my below logs without wait for next delete:
    <debug> app: Received data from BLE NUS. Writing data on UART.
    <debug> app:  38                     |8
    <info> app: 8 cmd received
    <info> app: Deleted record ID: 8
    <info> app: Deleted front & rear value
    <info> app: Deleting File no:1
    <info> app: Deleting File no:2
    <info> app: Deleting File no:3
    <info> app: Deleting File no:4
    <info> app: Deleting File no:5
    <info> app: Deleting File no:6
    <info> app: Deleting File no:7
    <info> app: Deleting File no:8
    <info> app: Deleted record ID: 1
    <info> app: FDS mach-ID delete success
    <info> app: Deleted record ID: 2
    <info> app: FDS Cron-Sch delete success
    <info> app: Deleted record ID: 30
    <info> app: FDS Any Stored ERROR delete success
    <info> app: Garbage Collection completed
    <info> app: Flash data File deleted
    <info> app: Disconnected
    <debug> app: Started Advertisng timeout timer
    <info> app: Flash data record deleted
    I have read some ques and answer from Nordic forum link here someone suggest the intrrupt priority of FDS module is lower than BLE priority is this correct?
    If yes how I can change the priority to get fds event with ble connected to device?
    Thanks.......
  • The priority is lower for FDS than for BLE, yes, but it has to be that way. The BLE will not block you all the time. Only short interrupts.
    What is your connection state when you try to delete? I assume it is connected? If so, what is your connection interval?
  • Yes, the connection state is connected when i call to delete function,
    #define APP_BLE_CONN_CFG_TAG 1                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME "Device_test"                         /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL 64     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION 0   /* Set 0 for contineous advertisng time & handle their timeout by sperate app timer.*/
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS)   //20           /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS)   //75           /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY 0                                      /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(90000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
    Please note I have already tried with connection interval below:
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)   //20           /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)   //75
    Thanks
