SDK 14.2.0: Reset on nrf_twi_mngr_perform(), TWI transaction memory messed up.
I'm trying to migrate a working application from SDK 14.0.0 to SDK 14.2.0. I was using app_twi on SDK 14.0.0 and am now using nrf_twi_mngr on SDK 14.2.0. One difference is the ability to pass in the TWI config on each call to nrf_twi_mngr_perform(). I'm not using this feature - I want the same config every time so I'm just passing that config to nrf_twi_mngr_init() and passing NULL for the config parameter on each call to nrf_twi_mngr_perform().
I get an assert on the first call to nrf_twi_mngr_perform(). Stepping through the nrf_twi_mngr.c source, I can see that my transaction is getting messed up in the queue. Before it's pushed into the queue the transaction's required config is null. After it's popped off the queue the transaction's required config is at a weird address in memory (I think the SD's part of flash) and in fact the whole transaction is there.
I've marked up nrf_twi_mngr.c with comments explaining what I'm seeing and attached it below.
Here's how I'm using the TWI from my code:
// From the top of my driver source:
NRF_TWI_MNGR_DEF(m_twi, 40, 0);
void acc_init(void)
    ret_code_t err_code;
    // TWI config. NOT passed in every nrf_twi_mngr_perform() call, since we want the same config every time.
    const nrf_drv_twi_config_t twi_config = {
        .scl = PIN_DEF_ACC_TWIS_SCL,
        .sda = PIN_DEF_ACC_TWIS_SDA,
        .frequency = NRF_TWI_FREQ_100K,
        .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
        .clear_bus_init = false
    err_code = nrf_twi_mngr_init(&m_twi, &twi_config);
void acc_program(acc_state_t state)
    ret_code_t err_code = 0;
    // BGW_SOFTRESET, aka BMA2x2_RST_ADDR
    // Do a soft reset in order to stop any interrupts we may have configured previously. This leaves us in normal mode.
    static uint8_t const reset_tuple[] = { BMA2x2_RST_ADDR, 0xB6 };
    static nrf_twi_mngr_transfer_t const reset_transfers[] = { NRF_TWI_MNGR_WRITE(ACC_SLAVE_ADDRESS, reset_tuple, 2, 0) };
    // This next line will reset, without returning the result code.
    err_code = nrf_twi_mngr_perform(&m_twi, NULL, reset_transfers, 1, NULL); // One transfer, no user function.
 * Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(NRF_TWI_MNGR)
#include "nrf_twi_mngr.h"
#include "nrf_assert.h"
typedef volatile struct
    bool    transaction_in_progress;
    uint8_t transaction_result;
} nrf_twi_mngr_cb_data_t;
static ret_code_t start_transfer(nrf_twi_mngr_t const * p_nrf_twi_mngr)
    ASSERT(p_nrf_twi_mngr != NULL);
    // Pointer for cleaner code.
    nrf_twi_mngr_cb_t * p_cb = p_nrf_twi_mngr->p_nrf_twi_mngr_cb;
    // [use a local variable to avoid using two volatile variables in one
    //  expression]
    uint8_t current_transfer_idx = p_cb->current_transfer_idx;
    nrf_twi_mngr_transfer_t const * p_transfer =
        &p_cb->p_current_transaction->p_transfers[current_transfer_idx];
    uint8_t address = NRF_TWI_MNGR_OP_ADDRESS(p_transfer->operation);
    nrf_drv_twi_xfer_desc_t xfer_desc;
    uint32_t                flags;
    xfer_desc.address        = address;
    xfer_desc.p_primary_buf  = p_transfer->p_data;
    xfer_desc.primary_length = p_transfer->length;
    /* If it is possible try to bind two transfers together. They can be combined if:
     * - there is no stop condition after current transfer.
     * - current transfer is TX.
     * - there is at least one more transfer in the transaction.
     * - address of next transfer is the same as current transfer.
    if ((p_transfer->flags & NRF_TWI_MNGR_NO_STOP) &&
        !NRF_TWI_MNGR_IS_READ_OP(p_transfer->operation) &&
        // Adding 1 to check if next transfer is from the same transaction.
        ((current_transfer_idx + 1) < p_cb->p_current_transaction->number_of_transfers) &&
        (NRF_TWI_MNGR_OP_ADDRESS(p_transfer->operation) ==
        NRF_TWI_MNGR_OP_ADDRESS(p_cb->p_current_transaction->
                            p_transfers[current_transfer_idx + 1].operation)))
        nrf_twi_mngr_transfer_t const * p_second_transfer =
            &p_cb->p_current_transaction->p_transfers[current_transfer_idx + 1];
        xfer_desc.p_secondary_buf  = p_second_transfer->p_data;
        xfer_desc.secondary_length = p_second_transfer->length;
        xfer_desc.type = NRF_TWI_MNGR_IS_READ_OP(p_second_transfer->operation) ?
                NRF_DRV_TWI_XFER_TXRX : NRF_DRV_TWI_XFER_TXTX;
        flags = (p_second_transfer->flags & NRF_TWI_MNGR_NO_STOP) ? NRF_DRV_TWI_FLAG_TX_NO_STOP : 0;
        p_cb->current_transfer_idx++;
        xfer_desc.type = NRF_TWI_MNGR_IS_READ_OP(p_transfer->operation) ? NRF_DRV_TWI_XFER_RX :
                NRF_DRV_TWI_XFER_TX;
        xfer_desc.p_secondary_buf = NULL;
        xfer_desc.secondary_length = 0;
        flags = (p_transfer->flags & NRF_TWI_MNGR_NO_STOP) ? NRF_DRV_TWI_FLAG_TX_NO_STOP : 0;
    return nrf_drv_twi_xfer(&p_nrf_twi_mngr->twi, &xfer_desc, flags);
static void transaction_end_signal(nrf_twi_mngr_t const * p_nrf_twi_mngr,
                                   ret_code_t             result)
    if (p_nrf_twi_mngr->p_nrf_twi_mngr_cb->p_current_transaction->callback)
        //  expression]
        void * p_user_data = p_nrf_twi_mngr->p_nrf_twi_mngr_cb->p_current_transaction->p_user_data;
        p_nrf_twi_mngr->p_nrf_twi_mngr_cb->p_current_transaction->callback(result, p_user_data);
static void twi_event_handler(nrf_drv_twi_evt_t const * p_event,
                              void *                    p_context);
// This function starts pending transaction if there is no current one or
// when 'switch_transaction' parameter is set to true. It is important to
// switch to new transaction without setting 'p_nrf_twi_mngr->p_current_transaction'
// to NULL in between, since this pointer is used to check idle status - see
// 'nrf_twi_mngr_is_idle()'.
static void start_pending_transaction(nrf_twi_mngr_t const * p_nrf_twi_mngr,
                                      bool                   switch_transaction)
    for (;;)
        bool start_transaction = false;
        CRITICAL_REGION_ENTER();
        if (switch_transaction || nrf_twi_mngr_is_idle(p_nrf_twi_mngr))
            if (nrf_queue_pop(p_nrf_twi_mngr->p_queue, (void *)(&p_cb->p_current_transaction))
                == NRF_SUCCESS)
                // Bike Tracker debug: The current transaction is now garbage:
                //   (gdb) print *p_cb->p_current_transaction
                //   $11 = {callback = 0x20000400, p_user_data = 0x8e9, p_transfers = 0x57d, number_of_transfers = 201 '\311', p_required_twi_cfg = 0x587}
                start_transaction = true;
                p_cb->p_current_transaction = NULL;
        CRITICAL_REGION_EXIT();
        if (!start_transaction)
            return;
            ret_code_t result;
            // Bike Tracker debug: The current transaction's required config is now non-null and in flash at 0x587 (in the softdevice?). This is quite wrong.
            //   (gdb) print *p_cb->p_current_transaction->p_required_twi_cfg
            //   $5 = {scl = 155814944, sda = 139987304, frequency = 2317358151, interrupt_priority = 73 'I', clear_bus_init = 9, hold_bus_uninit = 104}
            // The default configuration is correct:
            //   (gdb) print p_cb->default_configuration
            //   $7 = {scl = 15, sda = 16, frequency = NRF_TWI_FREQ_100K, interrupt_priority = 2 '\002', clear_bus_init = false, hold_bus_uninit = false}
            // The current transaction's configuration gets used instead of the default configuration since it's non-null.
            nrf_drv_twi_config_t const * p_instance_cfg =
                p_cb->p_current_transaction->p_required_twi_cfg == NULL ?
                &p_cb->default_configuration :
                p_cb->p_current_transaction->p_required_twi_cfg;
            if (memcmp(p_cb->p_current_configuration, p_instance_cfg, sizeof(*p_instance_cfg)) != 0)
                nrf_drv_twi_uninit(&p_nrf_twi_mngr->twi);
                err_code = nrf_drv_twi_init(&p_nrf_twi_mngr->twi,
                                            p_instance_cfg,
                                            twi_event_handler,
                                            (void *)p_nrf_twi_mngr);
                ASSERT(err_code == NRF_SUCCESS);
                nrf_drv_twi_enable(&p_nrf_twi_mngr->twi);
                UNUSED_VARIABLE(err_code);
                p_cb->p_current_configuration = p_instance_cfg;
            // Try to start first transfer for this new transaction.
            p_cb->current_transfer_idx = 0;
            result = start_transfer(p_nrf_twi_mngr);
            // If transaction started successfully there is nothing more to do here now.
            if (result == NRF_SUCCESS)
                return;
            // Transfer failed to start - notify user that this transaction
            // cannot be started and try with next one (in next iteration of
            // the loop).
            transaction_end_signal(p_nrf_twi_mngr, result);
            switch_transaction = true;
                              void *                    p_context)
    ASSERT(p_event != NULL);
    nrf_twi_mngr_t * p_nrf_twi_mngr = (nrf_twi_mngr_t *)p_context;
    ret_code_t result;
    // This callback should be called only during transaction.
    ASSERT(p_nrf_twi_mngr->p_nrf_twi_mngr_cb->p_current_transaction != NULL);
    if (p_event->type == NRF_DRV_TWI_EVT_DONE)
        result = NRF_SUCCESS;
        // Transfer finished successfully. If there is another one to be
        // performed in the current transaction, start it now.
        //  expression]
        uint8_t current_transfer_idx = p_nrf_twi_mngr->p_nrf_twi_mngr_cb->current_transfer_idx;
        ++current_transfer_idx;
        if (current_transfer_idx <
                p_nrf_twi_mngr->p_nrf_twi_mngr_cb->p_current_transaction->number_of_transfers)
            p_nrf_twi_mngr->p_nrf_twi_mngr_cb->current_transfer_idx = current_transfer_idx;
                // The current transaction goes on and we've successfully
                // started its next transfer -> there is nothing more to do.
                return;
            // [if the next transfer could not be started due to some error
            //  we finish the transaction with this error code as the result]
        result = NRF_ERROR_INTERNAL;
    // The current transaction has been completed or interrupted by some error.
    // Notify the user and start next one (if there is any).
    // [we switch transactions here ('p_nrf_twi_mngr->p_current_transaction' is set
    //  to NULL only if there is nothing more to do) in order to not generate
    //  spurious idle status (even for a moment)]
    start_pending_transaction(p_nrf_twi_mngr, true);
ret_code_t nrf_twi_mngr_init(nrf_twi_mngr_t const *        p_nrf_twi_mngr,
                             nrf_drv_twi_config_t const *  p_default_twi_config)
    ASSERT(p_nrf_twi_mngr->p_queue != NULL);
    ASSERT(p_nrf_twi_mngr->p_queue->size > 0);
    ASSERT(p_default_twi_config != NULL);
                                p_default_twi_config,
                                twi_event_handler,
    VERIFY_SUCCESS(err_code);
    p_nrf_twi_mngr->p_nrf_twi_mngr_cb->p_current_transaction   = NULL;
    p_nrf_twi_mngr->p_nrf_twi_mngr_cb->default_configuration   = *p_default_twi_config;
    p_nrf_twi_mngr->p_nrf_twi_mngr_cb->p_current_configuration =
        &p_nrf_twi_mngr->p_nrf_twi_mngr_cb->default_configuration;
    return NRF_SUCCESS;
void nrf_twi_mngr_uninit(nrf_twi_mngr_t const * p_nrf_twi_mngr)
ret_code_t nrf_twi_mngr_schedule(nrf_twi_mngr_t const *             p_nrf_twi_mngr,
                                 nrf_twi_mngr_transaction_t const * p_transaction)
    ASSERT(p_transaction != NULL);
    ASSERT(p_transaction->p_transfers != NULL);
    ASSERT(p_transaction->number_of_transfers != 0);
    ret_code_t result = NRF_SUCCESS;
    // Bike Tracker debug: At this point the internal transation's required config is null:
    //   (gdb) print p_transaction->p_required_twi_cfg
    //   $4 = (const nrf_drv_twi_config_t *) 0x0
    result = nrf_queue_push(p_nrf_twi_mngr->p_queue, (void *)(&p_transaction));
    // Bike Tracker debug: At this point the internal transation's required config is *still* null:
        // New transaction has been successfully added to queue,
        // so if we are currently idle it's time to start the job.
        start_pending_transaction(p_nrf_twi_mngr, false);
    return result;
static void internal_transaction_cb(ret_code_t result, void * p_user_data)
    nrf_twi_mngr_cb_data_t *p_cb_data = (nrf_twi_mngr_cb_data_t *)p_user_data;
    p_cb_data->transaction_result      = result;
    p_cb_data->transaction_in_progress = false;
ret_code_t nrf_twi_mngr_perform(nrf_twi_mngr_t const *          p_nrf_twi_mngr,
                                nrf_drv_twi_config_t const *    p_config,
                                nrf_twi_mngr_transfer_t const * p_transfers,
                                uint8_t                         number_of_transfers,
                                void                            (* user_function)(void))
    ASSERT(p_transfers != NULL);
    ASSERT(number_of_transfers != 0);
    nrf_twi_mngr_cb_data_t cb_data =
        .transaction_in_progress = true
    nrf_twi_mngr_transaction_t internal_transaction =
        .callback            = internal_transaction_cb,
        .p_user_data         = (void *)&cb_data,
        .p_transfers         = p_transfers,
        .number_of_transfers = number_of_transfers,
        .p_required_twi_cfg  = p_config
    // Bike Tracker debug: At this point the internal transation's required config is still null:
    //   (gdb) print internal_transaction->p_required_twi_cfg
    //   $1 = (const nrf_drv_twi_config_t *) 0x0
    ret_code_t result = nrf_twi_mngr_schedule(p_nrf_twi_mngr, &internal_transaction);
    VERIFY_SUCCESS(result);
    while (cb_data.transaction_in_progress)
        if (user_function)
            user_function();
    return cb_data.transaction_result;
#endif //NRF_MODULE_ENABLED(NRF_TWI_MNGR)
  • Also, you shouldn't need to compile my project because I provided hex files in the case. I'd get this running on a DK, but I don't think there's a TWI device on there.
  • I carried on with the SDK migration and noticed a completely unrelated problem, that my log message prefixes (the module names declared in each source file) were not making it through to the logs. Instead, only one of the module names was appearing for log messages from every module. I had already fixed the SDK 14.2.0 bug about the gcc linker script on log_const_data. Digging a bit deeper I found a devzone post about the same issue with log_dynamic_data, which I hadn't fixed. When I fixed that, suddenly the nrf_twi_mngr_perform() call worked.
    This is horrible "action at a distance" and I'd really like to understand it better. It's only by blind luck that I was able to fix it and I need to know how a more experienced engineer than me would have debugged this.
