In our application we need to receive data from two uart together
Dear Sir,
we are developing an application on the nRF52840 kit with SDK 15.0.0. We are using Keil as compiler. In our application we need to receive data from two uart together. If we use only one uart the application work fine, but if we add the second uart the firmware have a strange behavior: one of the two uart after a certain time stops to work. The time and the uart that stops are not always the same, it seems casual.
What can happen?
Attached you can find the files main.c, the nrf_serial library and the file sdk_config.h.
Please, help us because we are very worry, we need to complete the project soon.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_power.h"
#include "nrf_serial.h"
#include "app_timer.h"
#include "app_error.h"
#include "app_util.h"
#include "boards.h"
/** @file
 * @defgroup nrf_serial_example main.c
 * @ingroup nrf_serial_example
 * @brief Example of @ref nrf_serial usage. Simple loopback.
#define OP_QUEUES_SIZE          3
#define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
static void sleep_handler(void)
    __WFE();
    __SEV();
    __WFE();
NRF_SERIAL_DRV_UART_CONFIG_DEF ( m_uart0_drv_config,
                      RX_PIN_NUMBER, TX_PIN_NUMBER,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_9600,
											UART_DEFAULT_CONFIG_IRQ_PRIORITY);
NRF_SERIAL_DRV_UART_CONFIG_DEF ( m_serial_uart_badge_reading_drv_config ,
                      3 , 4 ,	// Rx pin = P0.03 -- Tx pin = P0.04
                      RTS_PIN_NUMBER , CTS_PIN_NUMBER ,
                      NRF_UART_HWFC_DISABLED , NRF_UART_PARITY_EXCLUDED ,
                      NRF_UART_BAUDRATE_115200 ,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY ) ;
#define SERIAL_FIFO_TX_SIZE 32
#define SERIAL_FIFO_RX_SIZE 32
NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
NRF_SERIAL_QUEUES_DEF ( serial_uart_badge_reading_queues , SERIAL_FIFO_TX_SIZE , SERIAL_FIFO_RX_SIZE ) ;
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
// Configuro i buffer delle seriali
NRF_SERIAL_BUFFERS_DEF ( serial_uart_badge_reading_buffs , SERIAL_BUFF_TX_SIZE , SERIAL_BUFF_RX_SIZE ) ;
NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_IRQ,
                      &serial_queues, &serial_buffs, NULL, sleep_handler);
											// Configuro le seriali
NRF_SERIAL_CONFIG_DEF ( serial_uart_badge_reading_config , NRF_SERIAL_MODE_IRQ ,
                        &serial_uart_badge_reading_queues , &serial_uart_badge_reading_buffs , NULL , sleep_handler ) ;	// sostituito NULL ( il secondo ) a sleep_handlerù
NRF_SERIAL_UART_DEF ( serial_uart , 0 ) ;
NRF_SERIAL_UART_DEF ( serial_uart_badge_reading , 1 ) ;
char	buff_received_uart_badge [ 30 ] = "" ;
char	tmp_buff_debug  [ 50 ] = "" ;
char	UID_badge [ 10 ] = "" ;
    ret_code_t ret ;
		ret_code_t ret_loop ;
    ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    ret = nrf_drv_power_init(NULL);
    ret = app_timer_init();
    // Initialize LEDs and buttons.
    bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
    ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config);
		// Inizializzo la seriale
		ret = nrf_serial_init ( &serial_uart_badge_reading , &m_serial_uart_badge_reading_drv_config , &serial_uart_badge_reading_config ) ;
    static char tx_message[] = "Hello nrf_serial 1!\n\r";
    ret = nrf_serial_write(&serial_uart,
                           tx_message,
                           strlen(tx_message),
                           NULL,
                           NRF_SERIAL_MAX_TIMEOUT);
		while (true)
				char a ;
				/********************* Seriale 1. *********************
				ret_loop = nrf_serial_read ( &serial_uart_badge_reading , &a , sizeof ( a ) , NULL , 5 ) ;
				if ( ret_loop == NRF_SUCCESS )
					( void ) nrf_serial_write ( &serial_uart , &a , sizeof ( a ) , NULL , 0 ) ;
					nrf_serial_flush ( &serial_uart_badge_reading , 5 ) ;
				char c ;
				/********************* Seriale 2. *********************
				ret = nrf_serial_read ( &serial_uart , &c , sizeof ( c ) , NULL , 5 ) ;
				if ( ret == NRF_SUCCESS )
					( void ) nrf_serial_write ( &serial_uart , &c , sizeof ( c ) , NULL , 0 ) ;
					nrf_serial_flush ( &serial_uart , 5 ) ;
/*$$$LICENCE_NORDIC_STANDARD<2016>$$$*/
#include "sdk_common.h"
#if NRF_MODULE_ENABLED(NRF_SERIAL)
#if defined (UART_PRESENT)
static void event_handler(nrf_serial_t const * p_serial,
                          nrf_serial_event_t event)
    if (p_serial->p_ctx->p_config->ev_handler)
        p_serial->p_ctx->p_config->ev_handler(p_serial, event);
static void sleep_handler(nrf_serial_t const * p_serial)
    if (p_serial->p_ctx->p_config->mode == NRF_SERIAL_MODE_POLLING)
        return;
    if (p_serial->p_ctx->p_config->sleep_handler)
        p_serial->p_ctx->p_config->sleep_handler();
static size_t serial_rx(nrf_serial_t const * p_serial,
                        uint8_t * p_buff,
                        size_t length)
        size_t rx_len = MIN(length, UINT8_MAX);
        size_t len = rx_len;
        while (nrfx_uarte_rx_ready(&p_serial->instance) && len)
            ret_code_t ret = nrfx_uarte_rx(&p_serial->instance, p_buff, 1);
            if (ret != NRF_SUCCESS)
            p_buff++;
            len--;
        return rx_len - len;
    nrf_queue_t const * p_rxq = p_serial->p_ctx->p_config->p_queues->p_rxq;
    return nrf_queue_out(p_rxq, p_buff, length);
static size_t serial_tx(nrf_serial_t const * p_serial,
                        uint8_t const * p_buff,
                        size_t length)
    size_t tx_len = 0;
        tx_len = MIN(length, UINT8_MAX);
        ret_code_t ret = nrfx_uarte_tx(&p_serial->instance, p_buff, tx_len);
        ASSERT(ret == NRF_SUCCESS)
        return tx_len;
    nrf_queue_t const * p_txq = p_serial->p_ctx->p_config->p_queues->p_txq;
    nrf_serial_buffers_t const * p_buffs = p_serial->p_ctx->p_config->p_buffers;
    /* Try to enqueue data. */
    size_t queue_in_len = nrf_queue_in(p_txq, p_buff, length);
    if (nrfx_uarte_tx_in_progress(&p_serial->instance))
        return queue_in_len;
    size_t len = nrf_queue_out(p_txq, p_buffs->p_txb, p_buffs->tx_size);
    ASSERT(len > 0);
    ret_code_t ret = nrfx_uarte_tx(&p_serial->instance, p_buffs->p_txb, len);
    ASSERT(ret == NRF_SUCCESS);
static void uart_event_handler(nrfx_uarte_event_t const * p_event, void * p_context)
    uint32_t ret;
    nrf_serial_t const * p_serial = p_context;
    switch (p_event->type)
        case NRFX_UARTE_EVT_RX_DONE:
            size_t len = nrf_queue_in(p_rxq,
                                      p_event->data.rxtx.p_data,
                                      p_event->data.rxtx.bytes);
            if (len < p_event->data.rxtx.bytes)
                event_handler(p_serial, NRF_SERIAL_EVENT_FIFO_ERR);
            event_handler(p_serial, NRF_SERIAL_EVENT_RX_DATA);
                                  p_buffs->p_rxb,
                                  p_buffs->rx_size);
        case NRFX_UARTE_EVT_ERROR:
            event_handler(p_serial, NRF_SERIAL_EVENT_DRV_ERR);
        case NRFX_UARTE_EVT_TX_DONE:
            event_handler(p_serial, NRF_SERIAL_EVENT_TX_DONE);
            if (len == 0)
ret_code_t nrf_serial_init(nrf_serial_t const * p_serial,
                           nrfx_uarte_config_t const * p_drv_uart_config,
                           nrf_serial_config_t const * p_config)
    ret_code_t ret;
    ASSERT(p_serial && p_drv_uart_config && p_config);
    if (p_serial->p_ctx->p_config)
        /*Already initialized.*/
        return NRF_ERROR_MODULE_ALREADY_INITIALIZED;
    if (p_config->mode != NRF_SERIAL_MODE_POLLING)
        ASSERT(p_config->p_queues && p_config->p_buffers);
    nrfx_uarte_config_t drv_config;
    memcpy(&drv_config, p_drv_uart_config, sizeof(nrf_drv_uart_config_t));
    drv_config.p_context = (void *)p_serial;
    #if 0
#if defined(UARTE_PRESENT) && defined(UART_PRESENT)
    drv_config.use_easy_dma = (p_config->mode == NRF_SERIAL_MODE_DMA);
    ret = nrfx_uarte_init(&p_serial->instance,
                            &drv_config,
                            p_config->mode == NRF_SERIAL_MODE_POLLING ?
                            NULL : uart_event_handler);
        return ret;
    p_serial->p_ctx->p_config = p_config;
    if (p_serial->p_ctx->p_config->p_queues)
        nrf_queue_reset(p_serial->p_ctx->p_config->p_queues->p_txq);
        nrf_queue_reset(p_serial->p_ctx->p_config->p_queues->p_rxq);
    nrf_mtx_init(&p_serial->p_ctx->read_lock);
    nrf_mtx_init(&p_serial->p_ctx->write_lock);
    p_serial->p_ctx->flags = NRF_SERIAL_RX_ENABLED_FLAG |
                             NRF_SERIAL_TX_ENABLED_FLAG;
    if (drv_config.pseltxd == NRF_UART_PSEL_DISCONNECTED)
        p_serial->p_ctx->flags &= ~NRF_SERIAL_TX_ENABLED_FLAG;
    if (drv_config.pselrxd == NRF_UART_PSEL_DISCONNECTED)
        p_serial->p_ctx->flags &= ~NRF_SERIAL_RX_ENABLED_FLAG;
        return NRF_SUCCESS;
#if 0
    if (p_serial->p_ctx->p_config->mode != NRF_SERIAL_MODE_DMA)
        nrfx_uart_rx_enable(&p_serial->instance);
            return NRF_SUCCESS;
    return nrfx_uarte_rx(&p_serial->instance,
                           p_serial->p_ctx->p_config->p_buffers->p_rxb,
                           p_serial->p_ctx->p_config->p_buffers->rx_size);
ret_code_t nrf_serial_uninit(nrf_serial_t const * p_serial)
    ASSERT(p_serial);
    if (!p_serial->p_ctx->p_config)
        /*Already uninitialized.*/
        return NRF_ERROR_MODULE_NOT_INITIALIZED;
    if (!nrf_mtx_trylock(&p_serial->p_ctx->write_lock))
        return NRF_ERROR_BUSY;
    if (!nrf_mtx_trylock(&p_serial->p_ctx->read_lock))
        nrf_mtx_unlock(&p_serial->p_ctx->write_lock);
    nrfx_uarte_uninit(&p_serial->instance);
    memset(p_serial->p_ctx, 0, sizeof(nrf_serial_ctx_t));
    return NRF_SUCCESS;
typedef struct {
    volatile bool expired;
} nrf_serial_timeout_ctx_t;
static void serial_timeout_handler(void * p_context)
    nrf_serial_timeout_ctx_t * p_tout_ctx = p_context;
    p_tout_ctx->expired = true;
static ret_code_t timeout_setup(nrf_serial_t const * p_serial,
                                app_timer_id_t const * p_timer_id,
                                uint32_t timeout_ms,
                                nrf_serial_timeout_ctx_t * p_tout_ctx)
    uint32_t ticks = APP_TIMER_TICKS(timeout_ms);
    if (ticks < APP_TIMER_MIN_TIMEOUT_TICKS)
        return NRF_SUCCESS;
    ret_code_t ret = app_timer_create(p_timer_id,
                                      APP_TIMER_MODE_SINGLE_SHOT,
                                      serial_timeout_handler);
        return ret;
    return app_timer_start(*p_timer_id, ticks, p_tout_ctx);
ret_code_t nrf_serial_write(nrf_serial_t const * p_serial,
                            void const * p_data,
                            size_t size,
                            size_t * p_written,
                            uint32_t timeout_ms)
    ret_code_t ret;
    ASSERT(p_serial);
    if (!(p_serial->p_ctx->flags & NRF_SERIAL_TX_ENABLED_FLAG))
    if (size == 0)
        return NRF_SUCCESS;
    if (!nrfx_is_in_ram(p_data) &&
         p_serial->p_ctx->p_config->mode == NRF_SERIAL_MODE_DMA)
        return NRF_ERROR_INVALID_ADDR;
    nrf_serial_timeout_ctx_t tout_ctx = {
            .expired = false,
    if (timeout_ms != NRF_SERIAL_MAX_TIMEOUT)
        ret = timeout_setup(p_serial,
                            p_serial->p_tx_timer,
                            timeout_ms,
                            &tout_ctx);
            return ret;
    size_t left = size;
    uint8_t const * p_buff = p_data;
    do
        size_t wcnt = serial_tx(p_serial, p_buff, left);
        left -= wcnt;
        p_buff += wcnt;
        if (!left)
        sleep_handler(p_serial);
    } while (!tout_ctx.expired);
    if (p_written)
        *p_written = size - left;
    if (!tout_ctx.expired && (timeout_ms != NRF_SERIAL_MAX_TIMEOUT))
        (void)app_timer_stop(*p_serial->p_tx_timer);
    if (left && tout_ctx.expired)
        return NRF_ERROR_TIMEOUT;
    return NRF_SUCCESS;
ret_code_t nrf_serial_read(nrf_serial_t const * p_serial,
                           void * p_data,
                           size_t size,
                           size_t * p_read,
    ret_code_t ret;
    ASSERT(p_serial);
    if (!(p_serial->p_ctx->flags & NRF_SERIAL_RX_ENABLED_FLAG))
    if (size == 0)
        return NRF_SUCCESS;
            .expired = false,
                            p_serial->p_rx_timer,
                            timeout_ms,
                            &tout_ctx);
            nrf_mtx_unlock(&p_serial->p_ctx->read_lock);
            return ret;
    size_t left = size;
    uint8_t * p_buff = p_data;
    do
        size_t rcnt = serial_rx(p_serial, p_buff, left);
        left -= rcnt;
        p_buff += rcnt;
        if (!left)
        if (tout_ctx.expired)
            if (p_serial->p_ctx->p_config->mode != NRF_SERIAL_MODE_POLLING)
                nrfx_uarte_rx_abort(&p_serial->instance);
    } while (1);
    if (p_read)
        *p_read = size - left;
        (void)app_timer_stop(*p_serial->p_rx_timer);
    return NRF_SUCCESS;
ret_code_t nrf_serial_flush(nrf_serial_t const * p_serial, uint32_t timeout_ms)
    ret_code_t ret;
    ASSERT(p_serial);
        return NRF_SUCCESS;
            .expired = false,
                            timeout_ms,
                            &tout_ctx);
            return ret;
    bool empty;
    do
        empty = nrf_queue_is_empty(p_serial->p_ctx->p_config->p_queues->p_txq)
                && !nrfx_uarte_tx_in_progress(&p_serial->instance);
        if (empty)
    if (!empty && tout_ctx.expired)
    return NRF_SUCCESS;
ret_code_t nrf_serial_tx_abort(nrf_serial_t const * p_serial)
    ASSERT(p_serial);
    nrfx_uarte_tx_abort(&p_serial->instance);
    if (p_serial->p_ctx->p_config->p_queues->p_txq)
    return NRF_SUCCESS;
ret_code_t nrf_serial_rx_drain(nrf_serial_t const * p_serial)
    ASSERT(p_serial);
    uint8_t c;
    /*Drain HW FIFO*/
    while (serial_rx(p_serial, &c, sizeof(c)))
    /*Drain SW FIFO*/
    if (p_serial->p_ctx->p_config->p_queues->p_rxq)
    return NRF_SUCCESS;
#else
                           nrf_drv_uart_config_t const * p_drv_uart_config,
    return NRF_ERROR_NOT_SUPPORTED;
                            size_t size,
                            size_t * p_written,
                           void * p_data,
                           size_t size,
                           size_t * p_read,
#endif // UART_PRESENT
#endif //NRF_MODULE_ENABLED(NRF_SERIAL)
nrf_serial.hsdk_config.h
  • Your source basically doesn't work on my PC.
    May you please check our example? Please download SDK15.1 link:
    https://www.nordicsemi.com/eng/nordic/Products/nRF52832/nRF5-SDK-zip/59012
    And run example: examples\peripheral\serial_uartes\
    This example is (I hope) what you need.
  • I have used the example project serial_uartes with SDK15.1. I begin by recieving data from the first uart and it works fine. When i beginning to receive data from second uart both the uart stop to work. Whit this new library the conditions are changed, before (SDK 15.0) after a random time, one of the two uart stops to work but random, now (SDK 15.1) whe the data come to the second uart both stop to work.
    In the example I modified only the receive and trasmision pins and the baude rate of one of the two uart (the first uart is 9600, the second 115200).
    What do you think?
     * Copyright (c) 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdint.h>
    #include <stddef.h>
    #include "nrf.h"
    #include "boards.h"
    /** @file
     * @defgroup nrf_serial_uartes_example main.c
     * @ingroup nrf_serial_uartes_example
     * @brief Example of @ref nrf_serial usage. Loopback example using two UARTE peripherals.
     *        Please short Arduino SCL and SDA GPIOs to start transmission.
        __WFE();
        __SEV();
        __WFE();
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
                          3, 4,
                          NRF_UART_BAUDRATE_115200,
    NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
                          &serial0_queues, &serial0_buffs, NULL, sleep_handler);
    NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
                          &serial1_queues, &serial1_buffs, NULL, sleep_handler);
    NRF_SERIAL_UART_DEF(serial0_uarte, 0);
    NRF_SERIAL_UART_DEF(serial1_uarte, 1);
        ret_code_t ret;
        ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
        ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
    		char	tmp_buff_send [ 10 ] = { 0x50 , 0x00 , 0x05 , 0x23 , 0x04 , 0x64 , 0x03 , 0x01 , 0x00 , 0x14 } ;
    		// Attivo la funzione autolistcard
    		( void ) nrf_serial_write ( &serial1_uarte , &tmp_buff_send , 10 , NULL , 100 ) ;
        static char tx_message[] = "Hello nrf_serial!\n\r";
        ret = nrf_serial_write(&serial0_uarte,
                               tx_message,
                               strlen(tx_message),
                               NULL,
        (void)nrf_serial_flush(&serial1_uarte, 0);
        while (true)
            char c;
            ret = nrf_serial_read(&serial0_uarte, &c, sizeof(c), NULL, 1);
                continue;
            (void)nrf_serial_write(&serial0_uarte, &c, sizeof(c), NULL, 0);
            (void)nrf_serial_flush(&serial0_uarte, 0);
            ret = nrf_serial_read(&serial1_uarte, &c, sizeof(c), NULL, 1);
                continue;
  • Hi Gianmarco,
    Could you try to change:
                continue;
    to
    while(ret != NRF_SUCCESS)
                continue;
    in your main.c instead?
    I have modified the code as you suggested me, but in this way both uarts don't works. There is another test can I do ?
    #include <stdint.h>
    #include <stddef.h>
    #include "nrf.h"
    #include "boards.h"
    /** @file
        __WFE();
        __SEV();
        __WFE();
                          3, 4,
    //NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_POLLING,
    //                      NULL, NULL, NULL, NULL);
    //NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_POLLING,
        ret_code_t ret;
                               tx_message,
                               strlen(tx_message),
                               NULL,
        while (true)
            char c;
            while (ret != NRF_SUCCESS)
                continue;
                continue;
