Bug in how bootloader treats GPREGRET
I suspect this is related to https://devzone.nordicsemi.com/f/nordic-q-a/36601/gpregret-and-nrf_bootloader-c-evolution-proposal (Case ID: 211047)
In nrf_bootloader_info.h you find this:
#define BOOTLOADER_DFU_GPREGRET_MASK            (0xB0)      /**< Magic pattern written to GPREGRET register to signal between main app and DFU. The 3 lower bits are assumed to be used for signalling purposes.*/
#define BOOTLOADER_DFU_START_BIT_MASK (0x01) /**< Bit mask to signal from main application to enter DFU mode using a buttonless service. */
As I understand the comment, B0 is used as a kind of signature to say "yes, the register content is related to bootloader", and reading the 3 lower bits are used to "signal", bit 0 (lowest bit) is used to signal DFU should start.
I wanted to create my own signal, for which I use bit 1. So at some point, I set it, which gives the register a value of B2.
Now let's have a look at code in dfu_enter_flags_clears:
if (NRF_BL_DFU_ENTER_METHOD_GPREGRET &&
(nrf_power_gpregret_get() & BOOTLOADER_DFU_START))
// Clear DFU mark in GPREGRET register.
nrf_power_gpregret_set(nrf_power_gpregret_get() & ~BOOTLOADER_DFU_START);
This code will be executed as B2 & B1 != 0... Shouldn't it be replaced with:
((nrf_power_gpregret_get() & 0xF8 == BOOTLOADER_DFU_GPREGRET_MASK) && (nrf_power_gpregret_get() & BOOTLOADER_DFU_START_BIT_MASK)))
Now let's have a look at this code from dfu_enter_check:
NRF_LOG_DEBUG("DFU mode requested via GPREGRET.");
return true;
When GPRGRET == 0xB2, this code will get executed, which, as far as I understand, contradicts the documentation and the way it was intended to work (as BOOTLOADER_DFU_START_BIT_MASK is here unimportant, replacing BOOTLOADER_DFU_START with BOOTLOADER_DFU_GPREGRET_MASK would do the same job, while clearly ignoring the "signal flags", and then what's the point of having signal flags?)
So I guess I'm expecting 2 things:
- Confirmation that I understood properly the way "signal bits" were intended to be used.
- That case ID 211047 would not be regarded as a possible evolution, but rather as a bugfix, as the bootloader does not behave according to the way "described" by the documentation.
2.5.0.0
  • We are using SDKv15.3.0 and I found this error accidentally.
    We wanted to put a value in GPREGRET that the bootloader would ignore so the application would run and read the GPREGRET register and restore an operating mode that was active before reset.
    We found that almost any combination of bits GPREGRET caused the device to enter boot-mode after reset, but could only exit after a power off/on. I found the fault due to the bitmask operation, and corrected it as described above.
    If we had deployed this code on on devices in the field it would have been impossible to cause them to exit boot-loader mode once the value in GPREGET doesn't have the bits set according to the bitmask.  We deploy hundreds of devices in remote sites.  This would have been a major problem for us.
    This is a typical case where it works correctly when tested in the way it's supposed to work.  Clearly this was never tested with combinations of bits other that what is specified to get into and out of boot-loader mode.
    This is such an amateurish error.
    If the boot-loader source code wasn't available, we would not have been able to fix it
  • The bug still exists in SDK 17.0.
    nrf_bootloader.c, line #377
    You are entirely correct. In this location, the same approach to testing magic word + signal should be used as is correctly done in crc_on_valid_app_required() and in dfu_enter_flags_clear() in the same file. I have notified the SDK team.
    Thank you for the reports.
    Terje
  • Just a '+1' on this: I'm a bit annoyed that I spent half an afternoon debugging what I thought was an error in my code, to find that my bootloader was incorrectly entering DFU mode due to this bug.
    I do understand that bugs happen - just a bit concerned that this was first reported more than 2 years ago, and still persists in SDK17, even though it's really easy to fix.
    I'll need to make my own custom copy of nrfbootloader.c to fix this.  Oh well...
    +1 noted.
    Can be fixed by changing nrf_bootloader.c lines 377-382:
            return true;
    To this:
           (nrf_power_gpregret_get() & BOOTLOADER_DFU_GPREGRET_MASK) == BOOTLOADER_DFU_GPREGRET)
            return true;
    Terje
