DFU Scanner Failed on Android O with SR3 v1.1
We are working on Android O with SR3  v1.1.
There is an issue that our Android STB can't find any BLE device using your library.
(https://github.com/NordicSemiconductor/Android-Scanner-Compat-Library)
Here is our code and error log
ScanSettings scanSettings = new ScanSettings.Builder()
               .setCallbackType(ScanSettings.CALLBACK_TYPE_ALL_MATCHES)
               .setScanMode(ScanSettings.SCAN_MODE_LOW_LATENCY)
               .setUseHardwareBatchingIfSupported(true)
               .build();
bleScanner.startScan(null, scanSettings, mScanCallback);
 I/zygote: Late-enabling -Xcheck:jni
 W/GraphicsEnvironment: driver package 'gfxdriver-bcmstb' not installed
 E/VC5: DRM: Trying to find: /dev/dri/card0
 D/libEGL: loaded /vendor/lib/egl/libGLES_nexus.so
           [ 08-22 11:13:47.206  9298: 9318 E/         ]
           init_expose_fences v3d EGL_ANDROID_native_fence_sync extension enabled
 D/OpenGLRenderer: HWUI GL Pipeline
 E/VC5: DRM: Trying to open: /dev/dri/card0
 E/VC5: DRM: brcmv3d Version 2.0.0 20180313, Broadcom V3D GEM provider
 E/VC5: DRM: No Nexus secure graphics heap available
 I/OpenGLRenderer: Initialized EGL, version 1.4
 D/OpenGLRenderer: Swap behavior 1
 W/OpenGLRenderer: Failed to choose config with EGL_SWAP_BEHAVIOR_PRESERVED, retrying without...
 D/OpenGLRenderer: Swap behavior 0
 V/VC5: ==========================================================================
 V/VC5: NATIVE_WINDOW_MIN_UNDEQUEUED_BUFFERS = 1
 D/BluetoothGatt: connect() - device: E9:74:F1:2A:15:D5, auto: false
 D/BluetoothGatt: registerApp()
 D/BluetoothGatt: registerApp() - UUID=2cf0ce0e-fce1-41ec-9b00-e6e32acab188
 D/BluetoothGatt: onClientRegistered() - status=0 clientIf=6
 D/BluetoothGatt: onClientConnectionState() - status=0 clientIf=6 device=E9:74:F1:2A:15:D5
 V/BluetoothLeService: onConnectionStateChange 2
 D/BluetoothGatt: discoverServices() - device: E9:74:F1:2A:15:D5
 D/BluetoothGatt: onSearchComplete() = Device=E9:74:F1:2A:15:D5 Status=0
 I/zygote: Do partial code cache collection, code=26KB, data=30KB
 I/zygote: After code cache collection, code=26KB, data=30KB
 I/zygote: Increasing code cache capacity to 128KB
 D/BluetoothGatt: onClientConnectionState() - status=8 clientIf=6 device=E9:74:F1:2A:15:D5
 V/BluetoothLeService: onConnectionStateChange 0
 D/BluetoothGatt: close()
 D/BluetoothGatt: unregisterApp() - mClientIf=6
 D/BluetoothGatt: registerApp() - UUID=438ca611-8a23-4350-a40e-1dc9394ab84f
 I/zygote: Do partial code cache collection, code=43KB, data=58KB
 I/zygote: After code cache collection, code=43KB, data=58KB
 I/zygote: Increasing code cache capacity to 256KB
 I/zygote: Compiler allocated 4MB to compile void android.widget.TextView.<init>(android.content.Context, android.util.AttributeSet, int, int)
 I/zygote: Do full code cache collection, code=126KB, data=88KB
 I/zygote: After code cache collection, code=84KB, data=41KB
 V/UploadingFragment: scanLeDevice
 D/BluetoothAdapter: isLeEnabled(): ON
 D/BluetoothLeScanner: onScannerRegistered() - status=0 scannerId=6 mScannerId=0
 I/zygote: Do partial code cache collection, code=99KB, data=57KB
 I/zygote: After code cache collection, code=99KB, data=56KB
 I/zygote: Increasing code cache capacity to 512KB
 I/zygote: Method exceeds compiler instruction limit: 25337 in void org.ccil.cowan.tagsoup.HTMLSchema.<init>()
 W/UploadingFragment: force stop scan
 D/BluetoothGatt: registerApp() - UUID=5c4971d7-1118-40cc-9e45-62b4861ffa01
 * Using https://github.com/NordicSemiconductor/Android-Scanner-Compat-Library/releases
 * ScanSettings scanSettings = new ScanSettings.Builder()
 *				.setCallbackType(ScanSettings.CALLBACK_TYPE_ALL_MATCHES)
 *				.setScanMode(ScanSettings.SCAN_MODE_LOW_LATENCY)
 *				.setUseHardwareCallbackTypesIfSupported(true)
 *				.build();
 * bleScanner.startScan(null, scanSettings, mScanCallback);
However We worked fine on Android N with SR3 v1.1.
Ralph
