buttonless_dfu 15.1 not advertising for s112
I have SD and BL secure flashed to the device, and now trying to get the second part of buttonless_dfu + app with settings flashed next.
After flashing the second part, DfuTarg no longer advertises, or any advertising.
The app works fine on its own based on the ble_template, then combined the app with buttonless_dfu as the base, which also seems to be based on the template, and that combination compiles fine.
(I have the buttonless tutorial working start to finish, but tutorial does not have a combined example).
RTT does not seem to display any info after this flash, and now not sure of where to look for clues.
Checking section placements in SES, the standalone app has the same flash & ram settings as the template, but not the buttonless_dfu template which has slightly different values.
15.1_template_custom_app
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x30000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x6000
FLASH_START=0x19000
FLASH_SIZE=0x17000
RAM_START=0x20001b48
RAM_SIZE=0x44b8
15.1_buttonless_custom_app
FLASH_PH_START=0x0
RAM_PH_SIZE=0x6000
FLASH_START=0x19000
FLASH_SIZE=0xf000
RAM_START=0x20001c18
RAM_SIZE=0x43e8
Changed the combined buttonless_custom_app settings to template_custom_app but same results of no advertising. Maybe other section placements settings would work.
Any other way to debug and find the error for buttonless_dfu not advertising?
thank-you,
  • Getting a little farther.
    I'm now able to get the s112 example buttonless_dfu to ADV by simply adding --reset after --sectorerase, without using the backup setting.
    Tried --reset on the custom (with no backup and with backup settings), and didn't get as far too ADV, but at least RTT is now receiving some log and shows these final entries;
    0> <info> app: Erase bonds!
    0> <info> peer_manager_handler: All peers deleted.
    The next line should be,
    0> <info> app: Fast advertising.
    (also tried with RTT and Log turned off)
    I'm not fully understanding the "2 flash pages for the FDS module between the bootloader start address and the last page used by the application". A bit of help needed here to try this.
    thank-you,
  • Hi Simon,
    Ok, so this is with the bootloader, SoftDevice and Application flashed to the custom nRF52810 board?
    The ble_app_buttonless_dfu example uses the Peer Manager module, which in turn uses the Flash Data Storage(FDS) module to store peer data, e.g. peer addresses, encryption keys and dentity resolving keys, in flash.
    Hence, the FDS module needs to free flash pages, one as a swap page and one for storing the data. The FDS module will by default use the two last flash pages, but if a bootloader is present it will use the two pages below the bootloader start address. Usually this works with a hitch with the nRF52832 and nrf52840, but with the nRF52810 there is very limited flash with the S112 SoftDevice, application and bootloader, so some care must be taken.
    So if the bootloader starts at 0x28000, then the last page used by the application must be below 0x26000 in order for FDS to properly initialize.
  • "so this is with the bootloader, SoftDevice and Application flashed to the custom nRF52810 board?"
    -->> yes
    I can without problem get the s112 buttonless example working on the DK to advertise buttonless by flashing SD, secure, settings, backup, & app.
    I have another 810 custom with just an RGB (used to test basic apps like blinky), and tried repeating the buttonless example adjusting for the board and clock. I can get past the first flash of SD & secure to ADV DfuTarg on the custom, then the same no ADV after second flash of app, backup & settings.
    The DK has 512kB and the 810 has 192kB of flash, ...but has the buttonless example been verified on a standalone 810 (just asking)?
    (same results using sdk 15.2)
    0> <info> app: Setting vector table to bootloader: 0x00028000
    0> <info> app: Setting vector table to main app: 0x00019000
    0> <info> app: Buttonless DFU Application started.
    no ADV
    (SES optimize for size, RTT and Log turned off)
    thank-you,
  • HI Simon,
    I have verified that the ble_app_buttonless_dfu_pca10040e_s112 example for pca10040e in SDK v15.0.0 works on a nRF52810 DK that I have here.
    These are the memory settings(Code > Linker > Section Placement Macros) for the ble_app_buttonless_dfu example
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x6000
    FLASH_START=0x19000
    FLASH_SIZE=0xD000
    RAM_SIZE=0x43e8
    These are the secure_bootloader_ble_s112_pca10040e project
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x6000
    FLASH_START=0x28000
    FLASH_SIZE=0x6000
    RAM_START=0x20002390
    RAM_SIZE=0x3c70
    Also note that I have removed the DEVELOP_IN_NRF52832 from the Preprocessor Definitions in both projects (Code > Preprocessor > Preprocessor Definitions). I have also attached the hex file for the application, the bootloader and the settings that works on said nRF52810.
    ble_app_buttonless_dfu_pca10040e_s112.hex
    ble_app_buttonless_settings.hex
     secure_bootloader_ble_s112_pca10040e.hex
  • I can also confirm your findings, ...which I did in my previous reply using the DK.
    The only difference in placements is that the base buttonless example uses flash_size=0xf000 and you are using 0xd000 (secure is the same).
    Either way, no ADV on the 810 chip.
    (DEVELOP_IN_NRF52832 had been removed)
    Rather than using the 832 on the DK, what is the result using the examples on an actual 810 chip?
    for me, ....no ADV.
    thank-you,
