I am using nRF52832 IC with softdevice and SDK v15.
I wish to make the MCU in sleep mode and then a couple of milliseconds (let's say 250ms) wakes up the MCU. For this purpose, can I use the timer? Or do you have any idea ?
When I do not use the below code into mine softdevice code, the code crashes at the line "ble_stack_init();"
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
if (int_type == NRF_DRV_RTC_INT_COMPARE0)
nrf_gpio_pin_toggle(COMPARE_EVENT_OUTPUT);
else if (int_type == NRF_DRV_RTC_INT_TICK)
nrf_gpio_pin_toggle(TICK_EVENT_OUTPUT);
/** @brief Function configuring gpio for pin toggling.
static void leds_config(void)
/** @brief Function starting the internal LFCLK XTAL oscillator.
static void lfclk_config(void)
ret_code_t err_code = nrf_drv_clock_init();
/** @brief Function initialization and configuration of RTC driver instance.
static void rtc_config(void)
uint32_t err_code;
//Initialize RTC instance
nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
config.prescaler = 4095;
err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
//Enable tick event & interrupt
nrf_drv_rtc_tick_enable(&rtc,true);
//Set compare channel to trigger interrupt after COMPARE_COUNTERTIME seconds
err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 8,true);
//Power on RTC instance
nrf_drv_rtc_enable(&rtc);
}RTC0 is used by the SoftDevice, RTC1 is used by the app_timer, I suggest you use RTC2 as the RTC instance.
OK, I used the RTC2. However, MCU never wakes up from sleep mode.
What is the state of the RTC2's register after you've configured, enabled, and started it?
actually LED is blinking When the MCU is active. there is no wakeup event occurs When the MCU goes into sleep mode.
