Error 22 (0x16) GATT_CONN TERMINATE LOCAL HOST ISSUE
Platform NRF52832 SoftDevice S132 V6.1 SDK 15.0 FreeRTOS implemented
In our application, once the mobile app is connected to the peripheral, it makes continuous writes to a characteristic every 1 second and then forwards the message to a different chip over UART. We expect this behavior to work for at least 2 hours.
Here are the connection parameters we are using
 MIN_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS)
MAX_CONN_INTERVAL MSEC_TO_UNITS(2000, UNIT_1_25_MS)
SLAVE_LATENCY 0
CONN_SUP_TIMEOUT MSEC_TO_UNITS(10000, UNIT_10_MS)
However after some time (ranging from 3 minutes to 25 minutes at random), we see an error on nrf_connect app stating Error 22 (0x16) GATT_CONN_TERMINATE_LOCAL_HOST and the phone is disconnected. But on the dev board, we do not see any disconnect event and the board becomes unresponsive to any BLE command and remains stuck. The only way to recover is pressing the reset switch. This issue is quite problematic since the production version will not have any I/O for reset.
Could RTOS be causing any issue. I have increased the priority of the BLE task to 4 (Total of 4 tasks running)  from the default of 2 in nrf_sdh_freertos.c
  • Quick update on the issue
    I changed the connection intervals to Min: 100ms Max 300ms Supervisory timeout: 5000ms
    On Oneplus 3, the connection was stable for around 8 hours overnight. It was still active when I woke up and manually closing the app caused a clean disconnect (Reason 0x13).
    I will run some more tests with Samsung phones and upload sniffer logs if there are any issues.
  • That is interesting news. Please let me know how it goes.
    -Martin
  • Hello, I experienced a similar issue, my bluetooth connection kept getting disconnected with error 22 after a somewhat random time intervals (mostly 30-90 seconds).
    First time this happened I tried forgetting the device in android settings, removing the bonding information.. That didnt help, then I played around with the connection parameters and thought that solved the issue.
    The problem reappeared some days later, even through I didnt change any of the settings. This time nothing seemed to help, until I erased bluetooth cache in the bluetooth system app in the App info settings (oneplus 6T,  Android 9, OxygenOS 9.0.17), which solved the issue completely and the connection is now stable again.
    I'm not sure whether the problem OP has is the same, but since I was looking for solution to this multiple times and didnt find anything, thought I'd share so ppl who have the same issue can try this.
