long range
Hello All,
I am having trouble changing the 'ble_app_multiperipheral_pca1056_s140' example to work with long range. I have read a few of the blog posts and similar devzone posts but I can't seem to find an answer that works.
Here is my code for configuring the gap advertising set:
   // only extended advertising will allow primary phy to be coded
    NRF_LOG_INFO("Advertising type set to EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED ");
    //adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    // Start advertising.
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.p_peer_addr   = NULL;
    adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
    adv_params.interval      = APP_ADV_INTERVAL;
    adv_params.duration      = 0;//APP_ADV_DURATION;
    NRF_LOG_INFO("Setting adv params phy to coded phy .. ");
    adv_params.primary_phy     = BLE_GAP_PHY_CODED;
    //adv_params.secondary_phy   = BLE_GAP_PHY_CODED;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
The error I get is :
<info> app: Setting adv params phy to coded phy ..
<error> app: ERROR 7 [NRF_ERROR_INVALID_PARAM] at :0
PC at: 0x00000000
<error> app: End of error report
Any help where I am going wrong or anything that I have missed would really be appreciated.
Cheers
Michael
8ball
  • Hi
    Good spot, as you say that wouldn't help. I would love to say that this has solved my problem, but even after I move the line to below the memset (clr),I still get the same error 7 code.
    "app: ERROR 7 [NRF_ERROR_INVALID_PARAM] at :0 "
    This is my modified code as you suggested:
    #define LONG_RANGE_SELECTED 1
    #if  defined(LONG_RANGE_SELECTED)
        //NRF_LOG_INFO("Advertising type set to EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED ");
        //adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED;
        memset(&adv_params, 0, sizeof(adv_params)); //clear Advertising memory
        adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED;//MD moved to here below the memset
        adv_params.duration      = APP_ADV_DURATION;
        adv_params.scan_req_notification =1; //recently added MD 7/9/18
    #else
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;  //MD changed for extended broadcast range -old
    Any further suggestions?
    Disappointed relieved
    Cheers
    Michael
  • It is working in my project.
    Did you set scan_rsp_data to NULL?
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
  • Hi
    Yes that has cleared up the error. Do you know if there is a white paper or similar document from Nordic that describes the setting requirements to enable some of these modes (and there dependencies)??
    I understand that the Infocenter document holds a lot of information about the SoftDevice API (including defines, Enumerations, functions and structures) .... but as far as I can see it doesn't tell you a lot of information for the requirements to enable a particular connection type (in my case the long range).
    For example a search of 'long range' in the Infocentrer it returns no results.
    If I search 'BLE_GAP_PHY_CODED' one of the returned functions is for the  sd_ble_gap_phy_update function, which has a note :
    "Note: BLE_GAP_PHY_CODED is only supported as an experimental feature in this SoftDevice."
    None of the returned information is of any real help into what I need to set as opposed to what I can set - I guess that is why this is a common question on the devzone site??
    Thanks for your help
    Cheers
    Michael
  • I'm glad you got it working Michael. :)
    I am not aware of any whitepaper, or step by step tutorial for long range or other "modes", that clearly list the dependencies. But there are some examples that use long range:
    https://github.com/NordicPlayground/nRF52-ble-long-range-demo
    https://github.com/NordicPlayground/nrf52-ble-app-uart-long-range
    ATT_MTU Throughput Example (For the connection, not advertising or scanning)
    There are several resources to give a more general understanding of long range (I know that is not what you are asking for, but for completeness, I want to add links for others to see):
    https://www.nordicsemi.com/eng/Products/Bluetooth-5
    https://blog.nordicsemi.com/getconnected/tested-by-nordic-bluetooth-long-range
    https://blog.nordicsemi.com/getconnected/things-you-should-know-about-bluetooth-range
    https://devzone.nordicsemi.com/b/blog/posts/testing-long-range-coded-phy-with-nordic-solution-it-simply-works-922075585
    I agree that it could be more explicitly stated in the API that the scan response data must be NULL when the advertising type is non-scannable.
    It is said more implicitly under GAP Advertising types
    "Scan response data can only be specified for a @ref ble_gap_adv_properties_t::type
    that is scannable."
    and under GAP advertising data buffers:
    "non-scannable types do not support scan response data."
    And when you add too many implicit parameters on top of each other mistakes get easy to make.
    I will check internally if someone wants to clean up the API a bit or make a blog post about advertising- and connection phys. (I assume this is what you mean by "modes" but feel free to specify it more).
    Good luck with your project.
     -Håvard
  • Hi
    I'm sure a blog post would be welcomed and appreciated by the community as more people  use these newly introduced modes, feature and functions.
    Thank you very much for your help and support
    Kind regards
    Michael
