how does the nrf52832 decide to enter the swd mode?
hi
my question is really basic, but i am not able to find an answer anywhere else. I am trying to program the nordic using its SWDIO and SWCLK pins and am stuck as i get " emulator not found" error. I am wondering what the problem could be. How does the nrf52832 detect a swd programmer connected and decide to enter the debug mode as against running its existing code if any?
is a reset or some specific signal on any other pin necessary?
I have used the nrf51822 before and i only connected SWDIO, SWCLK, VCC and GND and everything worked well. but with the nrf52832 i am having issues programming the IC.
thanks in advance for the answer
  • thanks
    reading the following gave a clearer picture
    http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0314h/Babdadfc.html
    To update on the programming issue, i tried another set of custom PCB with nrf52832 with same result. The device is initially detected, softdevice  is programmed and while downloading the application i get an error. After this happens the my laptop refuses to detect the device. Any subsequent power up cycles and effort to connect to the device fail.
    I am afraid my programmer may be damaging my device in some way.
  • nrfjprog --eraseall --log
    nrfjprog version 9.7.3
    nRF_open_dll
    . nRFXX_open_dll
    . . nRFXX_dll_version
    nRF_enum_emu_snr
    . nRFXX_enum_emu_snr
    nRF_enum_emu_snr
    nRF_connect_to_emu_with_snr
    . nRFXX_connect_to_emu_with_snr
    . . nRFXX_is_connected_to_emu
    . . nRFXX_connect_to_emu_without_snr
    . . . nRFXX_is_connected_to_emu
    . . . nRFXX_enum_emu_snr
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 Firmware: J-Link ARM-OB STM32 compiled Aug 22 2012 19:52:04
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 Hardware: V7.00
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 S/N: 20151216
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 Feature(s): RDI,FlashDL,FlashBP,JFlash,GDBFull
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 TELNET listener socket opened on port 19021
    . . nRFXX_connect_to_emu_without_snr:	JLink:	WEBSRV  Starting webserver
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0031ms, 0039ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	WEBSRV Webserver running on local port 19080
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0034ms, 0042ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	  returns O.K.
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0037ms, 0045ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_GetHWStatus(...)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	  returns 0x00
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0004ms, 0053ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("Device = NRF52832_xxAA", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	C:\Program Files (x86)\SEGGER\JLink_V622g\JLinkDevices.xml evaluated successfully.
    . . nRFXX_connect_to_emu_without_snr:	JLink:	Device "NRF52832_XXAA" selected.
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0237ms, 0293ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	  returns 0x01
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0297ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("DisableFlashDL", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0300ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("SetDbgPowerDownOnClose = 1", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0303ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0306ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_TIF_Select(JLINKARM_TIF_SWD)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0003ms, 0310ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_SetSpeed(2000)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 0313ms total)
    nRF_read_connected_emu_snr
    . nRFXX_read_connected_emu_snr
    . . nRFXX_is_connected_to_emu:	JLink:	JLINK_IsOpen()
    . . nRFXX_is_connected_to_emu:	JLink:	  returns 0x01
    . . nRFXX_is_connected_to_emu:	JLink:	 (0002ms, 0316ms total)
    nRF_read_device_family
    . nRFXX_read_device_family
    . . nRFXX_is_connected_to_emu:	JLink:	 (0003ms, 0320ms total)
    . . nRFXX_read_access_port_register
    . . . nRFXX_coresight_configure
    . . . nRFXX_coresight_configure:	JLink:	JLINK_CORESIGHT_Configure()
    . . . nRFXX_coresight_configure:	JLink:	 >0x10B TIF>
    . . . nRFXX_coresight_configure:	JLink:	 >0x10F TIF>
    . . . nRFXX_coresight_configure:	JLink:	 >0x0D TIF>
    . . . nRFXX_coresight_configure:	JLink:	  returns 0
    . . . nRFXX_coresight_configure:	JLink:	 (0009ms, 0330ms total)
    . . . nRFXX_power_debug_and_system_regions
    . . . . nRFXX_write_debug_port_register
    . . . . nRFXX_write_debug_port_register:	JLink:	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    . . . . nRFXX_write_debug_port_register:	JLink:	 >0x0D TIF>
    . . . . nRFXX_write_debug_port_register:	JLink:	  returns -1
    . . . . nRFXX_write_debug_port_register:	JLink:	 (0004ms, 0336ms total)
    . . . . nRFXX_write_debug_port_register:	JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -1.
    . . . nRFXX_power_debug_and_system_regions:	JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -102.
    nRF_close_dll
    . nRFXX_close_dll
    . . nRFXX_is_connected_to_emu:	JLink:	 (0002ms, 0339ms total)
    . . nRFXX_disconnect_from_emu
    . . nRFXX_disconnect_from_emu:	JLink:	JLINK_Close()
  • the processor doesn't detect it - the debugger connects, powers up the debug port which is a separate piece of hardware inside the cortex-M and then halts the processor, or resets it or reads registers. There really isn't a separate debug mode, there's just running with and without the debug port powered up and in-use or not. Of course with the DAP powered bits of the power and clock systems remain running all the time so the chip can't go into low power mode (for instance).
    To your point in the next mail - a debugger can't damage the device, so you're getting it into a state it's not being responsive to what you're trying, however it's undamaged.
  • yes, i searched for the error i am getting in the log, looks like many such cases for the nrf52.
    . . . . nRFXX_write_debug_port_register: JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -1. . . . nRFXX_power_debug_and_system_regions: JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -102.
    after this is the device getting "locked" in some way and there is no way to program it using SWD?
    Many threads with similar say it many be due to unstable power or RESET pin being not connected.
    I tried PCBs with 2 different layouts and power and i do not really doubt power issue on that. The RESET pin however unfortunately i left unused and is not brought out of the QFN. i might have to try and actually solder something on the QFN ic to pull the RESET to 3V.
  • have you tried
    nrfjprog --recover
    because it's possible the debug port is locked and so it won't power up. As far as I can tell from guessing what the logfile means it's trying to do a write to the DP SELECT register which is a fairly basic operation.
