Using nrf52832 as SPI master to get data from sensor
Hi All,
I'm trying to use the nrf52832 as the SPI master to get sensor reading through spi from another sensor. I want to base my firmware on the spi_pca10040 example but I don't know what the change except the pin number for CS, MISO, MOSI, and SCLK and the length of the tx and rx buffer. (since the sensor send 32 bits data)
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t       m_tx_buf[4];           /**< TX buffer. */
static uint8_t       m_rx_buf[4];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = 29; //SPI_SS_PIN;
    spi_config.miso_pin = 28; //SPI_MISO_PIN;
    spi_config.mosi_pin = 4; //SPI_MOSI_PIN;
    spi_config.sck_pin  = 3; //SPI_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    NRF_LOG_INFO("SPI example started.");
    while (1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(200);
This is what I have so far. Any advice?
Vincent
  • Hi Marjesic,
    I tried the code to read value from the INFO register but all I get from Termite is
    " <info> app: Transfer completed. "
    over and over again.
    Seems like the tx_buffer coming out from mosi is never received by the maxim chip.
    The following is the code I used.
    #include "boards.h"
    #include <string.h>
     * @param event
                           void *                    p_context)
    uint8_t adress=0x0F;    //The adress of the INFO register
    uint8_t message= (adress<<1)+1;     //Add the Read command
    m_tx_buf[0]=message;
        spi_config.ss_pin   = SPI_SS_PIN; //29
        spi_config.miso_pin = SPI_MISO_PIN; //28
        spi_config.mosi_pin = SPI_MOSI_PIN; //4
        spi_config.sck_pin  = SPI_SCK_PIN; //3
        while (1)
                __WFE();
            NRF_LOG_FLUSH();
            nrf_delay_ms(1000);
    As for the hardware side, I connect the following:
    nrf52832 --> max30001
      SS                   CS
    MOSI                SDI
    MISO                SDO
    SCK                  SCK
    Where did I messed up? Is it software or hardware problem?
    Thank you,
    Vincent
  • Hi Vincent,
    You also need to connect GND together.
    BR,
    Marjeris.
  • Hi Marjeris,
    Yes, I did connect the both GND together. I also tried using logical analyzer (analog discovery) and see the signal coming from nRF52832 with SPI master firmware. But I couldn't see any signal. However, I'm certain that the firmware works because when I connect nRF52832 with SPI master firmware and nRF52840 with SPI slave firmware, it did work.
    Any suggestion?
    Vincent
  • Hi Marjeris,
    So after some logical analyzer debugging. I'm now able to see signal from SS,MOSI, and SCLK but not MISO. Here's a screenshot of the result.
    DIO4 is SS.
    DIO5 is MISO
    DIO6 is MOSI
    DIO7 is SCLK
    Here's the code I used
    #include "boards.h"
    #include <string.h>
    //#include "MAX30001t.h"
    static uint8_t       m_tx_buf[4] = {0x0F,0x55,0xaa,0x55};           /**< TX buffer. */
     * @param event
                           void *                    p_context)
        while (1)
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, 6));
                __WFE();
            NRF_LOG_FLUSH();
            nrf_delay_ms(1000);
    I tried reading from both the INFO register (0x0F) and the ECG register (0x21). But the results both show no signal in MISO.
    Thank you,
    Vincent
  • Hi Vincent,
    You can try to increase the RX buffer to 8 bytes and see if you get something else than zeroes. It can be that the first bytes of data from the sensor are dummy bytes.
    It seems like the SPI is working fine in the nRF52 side, but you are only getting zeroes from the maxim chip. You will need to match the SPI configuration of the maxim chip to be able to read data from it.
    If you want to do a quick check that your MISO pin in the nRF52 is working find you can do a loopback test, just connect MOSI to MISO in the nRF52 DK and read the received bytes in Termite. But it seems like everything is working fine on the nRF52 DK side, so there have to be something in the way we send data that is not matching to what the maxim chip is expecting.
    Sometimes we have to check if the sensor is expecting MSB or LSB first, and which SPI mode the sensor is expecting. You can configure this in by changing NRF_DRV_DEFAULT_CONFIG in nrf_drv_spi.h
    The spi master example is configured in SPI mode 0 (SCK active high, sample on leading edge of clock, CPOL=0/CPHA=0) and MSB is shifted out first by default. But this should be compatible with the maxim chip (page 36 of the datasheet) so I don't know what the problem could be. I recommend you to take a look at the timing diagrams of the maxim chip and see if there is something we have missed out. And try a little bit more of debugging, you can try to send LSB first instead of MSB for example and see if that works.
    Best Regards,
    Marjeris
