UART, ADC, BTLE, Timer 1msec
Currently working on an app which will utilize the ADC component of an NRF chip.
The app will use the full bluetooth stack SF132;6.0.0, adc, and will need to have ability to send uart.
First: I need to initialize the ADC for multiple channels and to not be triggered by a timer, but by the app.
Second: BLE will always be advertising/listening for a host device.
Third: UART will stream a small data packet ~10 Bytes, every second or so.
What do I need to do so that I can call the ADC read for all channels?
What would be the best way to get a 1msec tick, not a SysTick as I will need it to work even when the device is asleep.
How should the UART be initialized so that it will run even when the softdevice is handling btle packets?
Thanks.
  • (continuous mode)
    Einar,
    I'm not sure how to setup the PPI to do this.
    What would I need to interconnect to sample all registered adc channels in quick succession?
    And how would I trigger the event to start this off without using a task specific interrupt.
    P.S. I've recently (last two hours) been informed that the ADC sample request could happen as fast as every 100 useconds.
    From what I understood you want to sample multiple channels at the same time, but you want to trigger each series manually. Then you set up multiple channels to use scan mode, and trigger sampling of all channels by triggering the SAMPLE task once. This can be done from PPI (if you want a timer to do it), but as you wrote that you want to do it from the application you just have to write 1 to the SAMPLE task instead. Using the driver, this is typically done by calling nrf_drv_saadc_sample() after first calling nrf_drv_saadc_buffer_convert(), as described in the driver documentation. (You can also test with simply using nrf_drv_saadc_sample_convert() which is a blocking call that does everything in one go, but since it is blocking this is probably not sensible in a real application).
    If you mean that you in your project want to sample as fast as every 100 µs, then triggering sampling from the application (CPU) every time does not seem sensible. If so, you should use PPI instead. For that, I recommend you refer to the SAADC example in the SDK. It only uses one channel, but it does not need much adjustment to add another.
  • Einar,
         That is a great post. My only real question left on ADC is, once all channels are initialized will the ADC read be triggered on all channels, or will I need to do some trickery in the adc handler?
    In addition, how will I know what channel was just read in the handler?
    Thanks for any help.
    When you sample multiple channels using scan mode you only need to trigger sampling once. Then all channels will be sampled, and you will get a single event in the end. At that point you know that you have a new sample for each channel. The samples for all channels are put in the same buffer, but interleaved so that if e.g.  you have two channels, then you will find the samples for channel 1 in index 0,2,.. and for channel 2 in index 1,3,... Therefor the buffer size always has to be a multiple of the number of enabled channels (see driver doc).
