nRF52 Ble Peripheral Example - ble_app_blinky not showing led/button service
Hi I have run a few peripheral examples ok and now move to evaluation of ble_peripheral also.
I'm using this version of the SDK....
If I program the softdevice and then the application hex file into board using the files shown below the led 1 turns on as expected.
Using rfConnect I can connect to "Nordic Blinky" and the led 2 turns on and led 1 turns off. However in the list of services I see there is not one showing for the Led/Button.
Using the blinky app for Android to connect I get a message indicating the "Device does not have the required services".
I checked the code in sdk_config.h to see if the service was enabled and this looks ok...
Looking at the help for the application at this link http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk%2Fdita%2Fsdk%2Fnrf5_sdk.html
I think I have done things correctly so I am now looking for some ideas/support to move forward please.
Regards MPH
  • Hi Martin
    I don't think we have any other examples using the led/button service, no. The main purpose of this service is to act as a simple example of a proprietary BLE service.
    What model of phone do you have, and what Android version is it running?
    Do you have some other phone(s) available that you can test with?
    Alternatively, do you have another nRF52 or nRF51 kit?
    Then you can use the nRF Connect Desktop application to connect to your kit from the PC, rather than using the phone apps.
    Another thing to try is to run a full chip erase before flashing one of the examples, to make sure that you have removed any traces of the old examples.
    This can be done either by running "nrfjprog --eraseall" in a command line, or by running "Target -> Connect J-Link" and "Target -> Erase All" in Segger Embedded Studio.
    Best regards
    Torbjørn
  • Hi Torbjørn
    Well I was hoping the Android App would work on my phone (Samsung Galaxy SM-A520F) or you may have a fix but it seems to be not that robust. So I borrowed an iPhone 5 and Blinky app works on that. I'll get a backup Apple device but the question is how to fix Android App for a wider coverage?
    Thanks and have a great weekend.
  • Hi Martin
    I can report the issue to our app developers and see if they have some input.
    Can you check what Android version the phone is running?
    I am using the app on a number of Android devices without any issues, but we mostly test the app on high end devices like the Nexus phones, Samsung Galaxy S phones and similar.
    Best regards
    Torbjørn
  • Hi Torbjørn
    The Phone has Android 8.0.0 loaded.
    I also downloaded Blinky app from GitHub and it compiles ok but when i get to debug on my phone the App closes shortly after attemtping to run.
    The reason for wanting to use this more simplistic App and embedded project is to use it as a basis for modification with out too many variables etc.
    BR Martin and thanks
  • Hi Martin
    One thing we could try is to change the BLE address, and see if it improves the situation. Some phones could have issues reconnecting to a device with the same BLE address if the services change.
    To try this out please add the following code to the gap_params_init() function of the blinky example:
    ble_gap_addr_t ble_address = {.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
                                                      .addr_id_peer = 0,
                                                      .addr = {0xC3,0x11,0x22,0x33,0x44,0xFF}};
    err_code = sd_ble_gap_addr_set(&ble_address);
    Best regards
    Torbjørn
