nRF5_SDK_12.3.0_d7731ad - BLE Peripheral:Eddystone Beacon Application - cannot connect
I was able to successfully make the BLE Peripheral Eddystone Beacon Application in "nRF5_SDK_12.3.0_d7731ad" in Windows 7 32-bit (pca10040), using GNU Tools ARM Embedded version "7 2018-q2-update".
I used nRFgo Studio-Win32 version 1.21.2 to program my nRF52-DK with the hex file, as well as S132.
I can view the app on "nRF Beacon for Eddystone" on my Moto G5 Android 7 phone which has the latest kernel and patch.  However, I cannot connect to it, the progress wheel keeps rolling.  Referring to:
http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.gs%2Fdita%2Fgs%2Fnordic_tools.html&cp=1_1
I am never prompted to "Enter the beacon manufacturer lock code" on the Android app.
When I press button 1 on the DK, LED3 illuminates solid, but when I press Connect on the Android app, LED3 switches off, LED2 illuminates solid and LED1 again starts flashing, as if somehow the DK goes back to Broadcast mode.
Any ideas?  I can successfully launch the Eddystone URL using other Android BLE apps.
Thank you.
  • Thank you for the feedback Joakim,
    I programmed my nRF52-DK with the following pre-compiled hex:
    D:\Nordic\nRF5_SDK_15.2.0_9412b96\examples\ble_peripheral\ble_app_eddystone\hex\ble_app_eddystone_pca10040_s132.hex
    Same behaviour on my Moto G5 - when I click connect on the app, the progress circle goes around forever and never connects...
    Best regards
  • Hi again.
    Thanks for testing the new SDK.
    Could you try erasing the chip before reprogramming the ble_app_eddystone_pca10040_s132.hex file?
    Also, try turning off bluetooth on your phone for around 30 sec. before testing the example again.
    Make sure that you follow these instructions when testing the example.
    Do you have some logs or maybe a sniffer trace from when you try to connect to the beacon?
    Joakim
  • Hi Joakim
    I did first erase the DK with nRFgo Studio 1.21.2.10, and then programmed it using the hex file.
    Waiting 30 seconds before turning on BT did not make any difference.
    I am using the test instructions as you've provided - I never reach step 6.
    I used Sweetblue to capture a log on my phone, as attached, hopefully it helps
    12:07:06  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [queue empty]
    12:07:06  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Connect(QUEUED nrf5x_eddys_05A6 254165051 )]
    12:07:06  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Connect(QUEUED nrf5x_eddys_05A6 254165051 ), Scan(QUEUED 42397820 )]
    12:07:06  2018 Info/P_TaskQueue: UPDATE(13545) print() - Connect(EXECUTING nrf5x_eddys_05A6 254165051 ) [Scan(QUEUED 42397820 )]
    12:07:07  2018 Warn/P_BleDevice_Listeners: UPDATE(13545) onConnectionStateChange_updateThread() - GATT_ERROR(133) STATE_DISCONNECTED(0)
    12:07:07  2018 Info/P_NativeDeviceWrapper: UPDATE(13545) updateNativeConnectionState() - STATE_DISCONNECTED(0)
    12:07:07  2018 Info/PA_Task: UPDATE(13545) setState() - Connect(FAILED nrf5x_eddys_05A6 254165051 ) - 412
    12:07:07  2018 Warn/P_ConnectionFailManager: UPDATE(13545) onConnectionFailed() - NATIVE_CONNECTION_FAILED, timing=EVENTUALLY
    12:07:07  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Connect(QUEUED nrf5x_eddys_05A6 142994609 ), Scan(QUEUED 42397820 )]
    12:07:07  2018 Info/P_TaskQueue: UPDATE(13545) print() - Connect(EXECUTING nrf5x_eddys_05A6 142994609 ) [Scan(QUEUED 42397820 )]
    12:07:08  2018 Info/P_BleDevice_Listeners: UPDATE(13545) onConnectionStateChange_updateThread() - GATT_CONN_SUCCESS(0) STATE_CONNECTED(2)
    12:07:08  2018 Info/P_NativeDeviceWrapper: UPDATE(13545) updateNativeConnectionState() - STATE_CONNECTED(2)
    12:07:08  2018 Info/PA_Task: UPDATE(13545) setState() - Connect(SUCCEEDED nrf5x_eddys_05A6 142994609 ) - 463
    12:07:08  2018 Debug/BleDevice: UPDATE(13545) onNativeConnect() - BOND_BONDED(12)
    12:07:08  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [DiscoverServices(QUEUED nrf5x_eddys_05A6 17425814 ), Scan(QUEUED 42397820 )]
    12:07:08  2018 Info/P_TaskQueue: UPDATE(13545) print() - DiscoverServices(EXECUTING nrf5x_eddys_05A6 17425814 ) [Scan(QUEUED 42397820 )]
    12:07:21  2018 Info/PA_Task: UPDATE(13545) setState() - DiscoverServices(TIMED_OUT nrf5x_eddys_05A6 17425814 ) - 1026
    12:07:21  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Disconnect(QUEUED nrf5x_eddys_05A6 221160727 ), Scan(QUEUED 42397820 )]
    12:07:21  2018 Warn/P_ConnectionFailManager: UPDATE(13545) onConnectionFailed() - DISCOVERING_SERVICES_FAILED, timing=TIMED_OUT
    12:07:21  2018 Info/P_TaskQueue: UPDATE(13545) print() - Disconnect(EXECUTING nrf5x_eddys_05A6 221160727 ) [Scan(QUEUED 42397820 )]
    12:07:21  2018 Warn/BleManager: UPDATE(13545) update() - Update loop took longer to run than the current interval of 20ms
    12:07:21  2018 Info/P_BleDevice_Listeners: UPDATE(13545) onConnectionStateChange_updateThread() - GATT_CONN_SUCCESS(0) STATE_DISCONNECTED(0)
    12:07:21  2018 Info/P_NativeDeviceWrapper: UPDATE(13545) updateNativeConnectionState() - STATE_DISCONNECTED(0)
    12:07:21  2018 Info/PA_Task: UPDATE(13545) setState() - Disconnect(SUCCEEDED nrf5x_eddys_05A6 221160727 ) - 1027
    12:07:21  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Connect(QUEUED nrf5x_eddys_05A6 166952196 ), Scan(QUEUED 42397820 )]
    12:07:21  2018 Info/P_TaskQueue: UPDATE(13545) print() - Connect(EXECUTING nrf5x_eddys_05A6 166952196 ) [Scan(QUEUED 42397820 )]
    12:07:21  2018 Info/P_BleDevice_Listeners: UPDATE(13545) onConnectionStateChange_updateThread() - GATT_CONN_SUCCESS(0) STATE_CONNECTED(2)
    12:07:21  2018 Info/P_NativeDeviceWrapper: UPDATE(13545) updateNativeConnectionState() - STATE_CONNECTED(2)
    12:07:21  2018 Info/PA_Task: UPDATE(13545) setState() - Connect(SUCCEEDED nrf5x_eddys_05A6 166952196 ) - 1028
    12:07:21  2018 Debug/BleDevice: UPDATE(13545) onNativeConnect() - BOND_BONDED(12)
    12:07:21  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [DiscoverServices(QUEUED nrf5x_eddys_05A6 31171309 ), Scan(QUEUED 42397820 )]
    12:07:21  2018 Info/P_TaskQueue: UPDATE(13545) print() - DiscoverServices(EXECUTING nrf5x_eddys_05A6 31171309 ) [Scan(QUEUED 42397820 )]
    12:07:33  2018 Warn/BleManager: MAIN(13516) startScan_private() - A startScan method was called when there's already a scan task in the queue!
    12:07:33  2018 Info/PA_Task: UPDATE(13545) setState() - DiscoverServices(TIMED_OUT nrf5x_eddys_05A6 31171309 ) - 1590
    12:07:33  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Disconnect(QUEUED nrf5x_eddys_05A6 123849717 ), Scan(QUEUED 42397820 )]
    12:07:33  2018 Warn/P_ConnectionFailManager: UPDATE(13545) onConnectionFailed() - DISCOVERING_SERVICES_FAILED, timing=TIMED_OUT
    12:07:33  2018 Info/P_TaskQueue: UPDATE(13545) print() - Disconnect(EXECUTING nrf5x_eddys_05A6 123849717 ) [Scan(QUEUED 42397820 )]
    12:07:33  2018 Info/P_BleDevice_Listeners: UPDATE(13545) onConnectionStateChange_updateThread() - GATT_CONN_SUCCESS(0) STATE_DISCONNECTED(0)
    12:07:33  2018 Info/P_NativeDeviceWrapper: UPDATE(13545) updateNativeConnectionState() - STATE_DISCONNECTED(0)
    12:07:33  2018 Info/PA_Task: UPDATE(13545) setState() - Disconnect(SUCCEEDED nrf5x_eddys_05A6 123849717 ) - 1591
    12:07:33  2018 Info/P_TaskQueue: UPDATE(13545) print() - Scan(EXECUTING 42397820 ) [queue empty]
    12:07:43  2018 Warn/BleManager: UPDATE(13545) update() - Update loop took longer to run than the current interval of 20ms
    12:07:44  2018 Info/P_ScanManager: UPDATE(13545) update() - Restarting paused scan...
    12:07:47  2018 Info/PA_Task: MAIN(13516) setState() - Scan(SUCCEEDED 42397820 ) - 2143
    12:07:47  2018 Info/P_TaskQueue: MAIN(13516) print() - no current task [queue empty]
    12:07:47  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Scan(QUEUED 201292711 )]
    12:07:47  2018 Info/P_TaskQueue: UPDATE(13545) print() - Scan(EXECUTING 201292711 ) [queue empty]
    12:07:51  2018 Info/PA_Task: MAIN(13516) setState() - Scan(SUCCEEDED 201292711 ) - 2314
    12:07:51  2018 Info/P_TaskQueue: MAIN(13516) print() - no current task [queue empty]
    12:07:51  2018 Info/P_TaskQueue: UPDATE(13545) print() - no current task [Scan(QUEUED 177500532 )]
    12:07:51  2018 Info/P_TaskQueue: UPDATE(13545) print() - Scan(EXECUTING 177500532 ) [queue empty]
    12:08:01  2018 Info/P_ScanManager: UPDATE(13545) update() - Restarting paused scan...
    Thank you
    Regards
    Jacques
  • Hi.
    I didn't see anything from the Log that indicates what the issue is.
    I'll keep digging and see if I can find what the cause of this might be.
    Joakim
  • Thank you Joakim,
    I received a free nRF Dongle at the Nordic Tour here in Cape Town on Monday, so will try use that to implement the Sniffer & send some logs.  :-)
    Best regards
    Jacques
