board nrf52840
sdk 15.2
hi i have one problem in connection, once i connected the device and disconnect means ,the device stops advertising..if i reset means it will show.
how to solve this.
board nrf52840
sdk 15.2
how to solve this.
Hi.
I just debugged your project and found an error right away.
<warning> nrf_sdh_ble: Insufficient RAM allocated for the SoftDevice. <warning> nrf_sdh_ble: Change the RAM start location from 0x20002210 to 0x20002250. <warning> nrf_sdh_ble: Maximum RAM size for application is 0x3DDB0. <error> nrf_sdh_ble: sd_ble_enable() returned NRF_ERROR_NO_MEM. <error> app: Fatal error
As you see from the error code you are out of memory, this is because you have added a lot of services and characteristics to your project.
You would have spotted this error if you had debugged your project, please do this next time your project doesn't work.
- Andreas
thank you so much. could you please explain how to debug like this
Hi.
You can find detailed information on how to debug in the infocenter.
Debugging in ARM Keil MDK.
Debugging in Segger Embedded Studio.
I suggest you read the development tutorial for your IDE in infocenter.
I also suggest you take a look at this question in the DevZone.
- Andreas
OK thank you i will make chances and will try
and i also want to read temperature and pressure value from bmp180 sensor.do you have any examples for that
