nrfutil dfu ble seems to fail suddenly.
It was working a few times, then suddenly I started to get these errors, which I only got previously when not running as root (perhaps because it did not have permission to open the serial port), but now it happens all the time.
I have rebooted, and still the same.
I have tried to open the serial port with minicom and it works, seems to be sending the same few bytes every half a second.
I have installed the nrfutil with:
# pip install intelhex
# pip install nrfutil
Never a problem, and did not change anything...
So no idea why... Help would be greatly appreciatted as it is urgent to get that working again.
# nrfutil dfu ble -p /dev/ttyACM0 -ic NRF52 -pkg /home/david.fernandez/src_mgt/rowesolutions/Doorlock/_build/DoorlockFull_dfu.zip
No target selected. Default device name: DfuTarg is used.
  [------------------------------------]    0%
  File "/usr/bin/nrfutil", line 11, in <module>
    load_entry_point('nrfutil==3.5.1', 'console_scripts', 'nrfutil')()
  File "/usr/lib/python2.7/site-packages/click/core.py", line 722, in __call__
    return self.main(*args, **kwargs)
  File "/usr/lib/python2.7/site-packages/click/core.py", line 697, in main
    rv = self.invoke(ctx)
  File "/usr/lib/python2.7/site-packages/click/core.py", line 1066, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/lib/python2.7/site-packages/click/core.py", line 895, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/lib/python2.7/site-packages/click/core.py", line 535, in invoke
    return callback(*args, **kwargs)
  File "/usr/lib/python2.7/site-packages/nordicsemi/__main__.py", line 838, in ble
    dfu.dfu_send_images()
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu.py", line 117, in dfu_send_images
    self._dfu_send_image(self.manifest.softdevice_bootloader)
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu.py", line 90, in _dfu_send_image
    self.dfu_transport.open()
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 450, in open
    self.dfu_adapter.open()
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 106, in open
    self.adapter.driver.open()
  File "/usr/lib/python2.7/site-packages/wrapt/wrappers.py", line 562, in __call__
    args, kwargs)
  File "/usr/lib/python2.7/site-packages/pc_ble_driver_py/ble_driver.py", line 126, in wrapper
    raise NordicSemiException('Failed to {}. Error code: {}'.format(wrapped.__name__, err_code))
pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: 13
  • Those folders do not contain anything... that is why running it fails... Maybe that is the problem with the module you provided... it does not install the required libraries there, like the mainstream installer do.
  • Sorry David, we saw that build only included the Windows drivers and missed the Linux files. We have initiated a new build to include Linux drivers and will include that here as soon as it builds.
  • The driver for linux is being submitted to pip just now. Can you do pip install like below
    pip uninstall pc-ble-driver-py
    pip install pc-ble-driver-py
    and verify that version 0.11.4 gets installed.
  • Done:
    # pip install pc-ble-driver-py
    WARNING: Running pip install with root privileges is generally not a good idea. Try `pip install --user` instead.
    Collecting pc-ble-driver-py
      Downloading https://files.pythonhosted.org/packages/38/6f/0bd202ea117a2c944234992f4d9f8c8b68964470dacc34164f20111712a9/pc_ble_driver_py-0.11.4.tar.gz (8.0MB)
        100% |████████████████████████████████| 8.0MB 158kB/s
    Requirement already satisfied: enum34 in /usr/lib/python2.7/site-packages (from pc-ble-driver-py)
    Requirement already satisfied: wrapt in /usr/lib/python2.7/site-packages (from pc-ble-driver-py)
    Requirement already satisfied: future in /usr/lib/python2.7/site-packages (from pc-ble-driver-py)
    Installing collected packages: pc-ble-driver-py
      Running setup.py install for pc-ble-driver-py ... done
    Successfully installed pc-ble-driver-py-0.11.4
    Still get the same problem:
    $ nrfutil dfu ble -f -ic NRF52 -pkg _build/Doorlock_59Full_dfu.zip
    Please select connectivity serial port:
            0 : /dev/ttyACM0 - 000682668605
    Enter your choice: : 0
    Board already flashed with connectivity firmware.
        args, kwargs)
      File "/usr/lib/python2.7/site-packages/pc_ble_driver_py/ble_driver.py", line 127, in wrapper
