nrfutil dfu ble seems to fail suddenly.
It was working a few times, then suddenly I started to get these errors, which I only got previously when not running as root (perhaps because it did not have permission to open the serial port), but now it happens all the time.
I have rebooted, and still the same.
I have tried to open the serial port with minicom and it works, seems to be sending the same few bytes every half a second.
I have installed the nrfutil with:
# pip install intelhex
# pip install nrfutil
Never a problem, and did not change anything...
So no idea why... Help would be greatly appreciatted as it is urgent to get that working again.
# nrfutil dfu ble -p /dev/ttyACM0 -ic NRF52 -pkg /home/david.fernandez/src_mgt/rowesolutions/Doorlock/_build/DoorlockFull_dfu.zip
No target selected. Default device name: DfuTarg is used.
  [------------------------------------]    0%
  File "/usr/bin/nrfutil", line 11, in <module>
    load_entry_point('nrfutil==3.5.1', 'console_scripts', 'nrfutil')()
  File "/usr/lib/python2.7/site-packages/click/core.py", line 722, in __call__
    return self.main(*args, **kwargs)
  File "/usr/lib/python2.7/site-packages/click/core.py", line 697, in main
    rv = self.invoke(ctx)
  File "/usr/lib/python2.7/site-packages/click/core.py", line 1066, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/lib/python2.7/site-packages/click/core.py", line 895, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/lib/python2.7/site-packages/click/core.py", line 535, in invoke
    return callback(*args, **kwargs)
  File "/usr/lib/python2.7/site-packages/nordicsemi/__main__.py", line 838, in ble
    dfu.dfu_send_images()
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu.py", line 117, in dfu_send_images
    self._dfu_send_image(self.manifest.softdevice_bootloader)
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu.py", line 90, in _dfu_send_image
    self.dfu_transport.open()
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 450, in open
    self.dfu_adapter.open()
  File "/usr/lib/python2.7/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 106, in open
    self.adapter.driver.open()
  File "/usr/lib/python2.7/site-packages/wrapt/wrappers.py", line 562, in __call__
    args, kwargs)
  File "/usr/lib/python2.7/site-packages/pc_ble_driver_py/ble_driver.py", line 126, in wrapper
    raise NordicSemiException('Failed to {}. Error code: {}'.format(wrapped.__name__, err_code))
pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: 13
  • OK, I'll wait to hear from you guys.
  • David,
    We have never tested this with Fedora Linux, and we do not have any PCs with Fedora native install. So it is hard to debug for us. Since the error occurs on dfu_transport_open() we wanted to know if there was any prior activity on UART at all. Can you sniff the UART port by a logic analyzer and post it here so that we can see if the UART port was opened before and to see if there was any activity on these lines after the command started.
  • Hi susheel,
    I do not have any logic analyzer here (they are quite expensive, and we are a small company.
    I usually turn on the board and quite soon I run the command... It would be really rare to have any activity on it.
    I wonder if we can debug this by getting you logs or other kind of software traces, either using the standard ble driver or any debug version you want me to run.
    Regards
  • Hi David,
    Sorry for the late reply Can we make this ticket public, probably we can get some help from other Linux users who might have faced it.
« 3 4 5 6 7
